hdrox88
2001 Tahoe daily driver
Were those factory holes under the tahoe
If you are talking about the grounding to the frame I recently did, yes, those holes in the frame were already there.
Wood has been purchased and cuts have started. Still unsure how I want to finish this one though.
Bedliner...with a royal blue port
You must have read my mind. I was thinking the same thing, or maybe a white port.
Lol white would be nice but you have to make sure all the bad areas look good
I think I inhaled more than enough dust today. Got all my cuts made, now it just needs put together.
I used some scrap mdf to make the rod type brace instead of spending the money on 1.5" dowel rod. Came out well enough.
My inner port wall seems to double as a small table.
Baffles are cut and ready.
I stopped here for the night to let the glue dry before further assembly.
Coming together nice...table saws are grest when building boxes
Thanks, it's looking good so far. I am happy to have the table saw at my disposal. I fired up the 10" miter saw yesterday as well. My grandfather left behind a small wood shop in a shed in the backyard when he passed. There is stuff in there I don't even know how to use yet. Rabbets and biscuits and dados, oh my!
Picked out some paint today. I'm hoping this all comes together well.
Edited by hdrox88
Awesome to see the variety!
I used to use the same Bondo body filler too until I discovered Half-Time and for this stuff I doubt I'll ever use anything else again.  Far quicker to sand and better finish than I ever got using the Bondo.
Will have to give that a try next time around. This is my first time using body filler on wood, let alone soft mdf. I see what you mean about sanding. Knocking down the Bondo without shredding the mdf took some time. The 80 grit was killing it, I ended up using 220 grit with both a block and an orbital. It's slow, but the finish seems to be smooth enough for spray-on bed liner.
Looks like somebody going with the blue
I will be trying this stuff
Yup, satin sapphire to be exact. And wouldn't you know...I ran out. It's coming right along though. The shade should be just right once the top goes on.
So you is a air gun for the box...if so what kind and nails...I always used screws and wood glue sucks when trying to route the edges...
Why paint the whole interior of the enclosure if its not gonna be seen?
Looks good so far.
I am just using screws and wood glue. I just use the screws as my clamping force. Once the glue is dry, the screws come out so flush trim and round over is a non issue.
Looks good so far.
Who said its not going to be seen?
Just speculation, i knew it was a reason :P:
Looks good so far.
Im going to try that on my next box
The reason shall be revealed soon enough.
Test fitting the baffle layers before I glue them together and paint.
Not a bad gloss for a rattle can and no sanding between coats. Going to have to remember this can for the future.
Looks clean maybe gain some dbs
Awesome!!
I almost went with mirrors on the enclosure in the Jimmy.
