altoncustomtech
Great amp for running a complete active setup?
Ran across this on the eBay and thought it looked like a great buy, especially for someone looking for a simple all in one solution for an active setup.  The Zapco I5100 is a seven channel amp that is rated for 50wrms x 4, 25wrms x 2 and 400wrms x 1 all @ 4 ohms.  By bridging the 4 channel section you get a rated 175wrms x 2 plus the 25wrms x 2 and the 400wrms x 1 and the sub section is rated 600wrms x 1 @ 2 ohms.
In my mind the 2 x 175 would be great for a mid, the 2 x 25 would be great for tweeters and the sub section great for many subs on the market.  It seems like a fantastic solution to simplifying an active setup as far as the amplification is concerned and at $270 it seems to be priced great as well.
Here's the link to the listing - Zapco I5100 $270
Just tossing this up for discussion and comments.  I'm sure since it's the Zapco I series amp it's not the same quality as their reference and competition series but I can't see it being a bad one either.
Curious how big it is. A pair of 900.4's might be the same size and would net even more flexibility...especially for those of us that don't care so much about the sub portion of the system.
The dimensions are 2.25" H x 10.75" W x 24.5" L according to the manual.  So yeah, it's not real small but essentially not much larger than two of the P900.4's end to end.
Good find!
I've always been more partial to multiple 2 channel amplifier setups, but that seems like a very nice amplifier !!!
looks like a nice amp, zapco would probably hold decent value. i agree with bridging the 4 channel section for a 2 way + sub. probably wouldn't run a 3 way + sub on that power though.
Multiple 2 channels would definitely be more versatile, hell even multiple 4 channels as Sean had mentioned.  When I run across this my thoughts were simply that it would simplify the setup for such a system with only one power and ground to mess with, only having to find room for one amp, things like that.
My thoughts when I posted it was solely for the 2 way + sub type setup.  I definitely agree it wouldn't be enough power for a 3 way + sub.
I'd like to see someone make a nice bus connection for 4chn amps to do the same. Modular ftw. Although I love me some Zapco. Miss the ones I had.
Jl has a 6 (XD600/6) and 8 channel amp (XD800/8)
The xd600/6 has a very small footprint, smaller than the likes of the ppi 900.4 (granted the JL not as much power)
I have the XD800/8 waiting for install, and the footprint is significantly larger than the 600/6 almost comparable to my mono subwoofer amp.
In the warmer days Im gonna go active and the 8 channel leaves me options for rear fill or even bridge mode if need be.
JL manufactures and sells some great amps, I'd never argue that but that XD800/8 sure as hell isn't nearly as budget friendly as the Zapco.
Please refresh my memory  on multichannel amplifiers ... Say if you have a 6  channel amplifier and you only need 4 channels for your front stage and plan to run rears later. This will leave 2 open and unused ports, but the amplifier has those ports powerd up. Will this hurt the amplifier ???
Is there a way to disable unused ports (channels) ???
I've always understood that you should not have any unused active channels running on an amplifier ...
Like I said earlier ... I've only used 2 channel amplifiers and only used more if application calls for it at that time of the install ...
Thanks in advance ...
Randal, what happens if you have a 2chn amp. In one channel your signal is 1v in the other it is 0.001v. Does the amp care?
That's not what I'm asking ... 0.001v is still something going into that channel because it is physically connected to a source.
I'm talking about leaving the RCAs open with no load on the outputs, and the amplifier powered up ... Will it hurt the amplifier ???
Edited by Cablguy184
so if i set the balance all the way to one side that will damage the amp? no, leaving channels disconnected or otherwise can't hurt an amp.
I would think that if you set the balance, that would be the same thing as turning the volume all the way down ...
If you have a source RCA hooked up to only half of the ports, what is the other side of the amplifier going to do ??
Is is just going to set there at idle ?? or being that you have only one power supply feeding voltage to ALL channels ... is is going to try and make some kind of power and create heat ???
Go measure air with your voltmeter. There is no such thing as "no voltage".
Ok ...
If you take a 4 channel amplifer and set it on a test bench, and ONLY connect the ground, positive, and remote wires up and fire up a solid 12.6 volts ... the amplifier should set there at idle ??? or is it common practice to ALWAYS connect RCAs up to an amplifier before startup ???
What would happen if you turn the gain up in this application ???
You'd amplify the signal on the input channels.
Go measure air with your voltmeter. There is no such thing as "no voltage".On top of that, if you have an 8chn and need 6chn bridge two. ;)
Ok ...If you take a 4 channel amplifer and set it on a test bench, and ONLY connect the ground, positive, and remote wires up and fire up a solid 12.6 volts ... the amplifier should set there at idle ??? or is it common practice to ALWAYS connect RCAs up to an amplifier before startup ???What would happen if you turn the gain up in this application ???
No matter how you phrase the question, the answer is the same.
No, it will not damage or hurt anything.
Even if you use a shit ton of ellipses and question marks, lol
Go measure air with your voltmeter. There is no such thing as "no voltage".On top of that, if you have an 8chn and need 6chn bridge two. wink.png
OK ... Thank you Sir
LOL ... Whatever
LOL ... Whatever
Here, you should read this and take note of when they should be used. It will help people not assume you are an idiot before even reading what you type. When it is a visual shitshow with all sorts of screwed up grammar it forces the reader to preconceive what to expect.
http://en.wikipedia.org/wiki/Ellipsis
LOL ... Whatever
It is all good brother. I just do that to piss you off since you are the only one that complains about it.
Don't stress about it
Just makes you look like an idiot. Keep it up, at this point it just makes me laugh. Like always you won't accept help even when your way is jacked. Enjoy that attitude.
  • Recently Browsing   0 members
    1. Recent Topics
        • 7 comments
        • 284 views
        • 1 comment
        • 318 views
        • 1 comment
        • 119 views
        • 1 comment
        • 112 views
      1. Box for 1 15" SSA ICON
        • 3 comments
        • 967 views
        • 8 comments
        • 1,882 views
  • Similar Content
    • By Tirefryr
      Selling off everything but a few things.  All items are BNIB unless otherwise noted.  I am NOT interested in trades, sorry.
      SOLD!
    • By Dragon76
      Just wondering has anyone used the Zapco amps with built in DSP. I was informed that they are the same ones minidsp uses and could I use these for an active set up?
    • By altoncustomtech
      Okay, we were finally able to get the vehicle that will be replacing the van as our daily driver.  I found a nice 2010 Traverse AWD with everything the wife wanted in it and a little more with decent miles on it and I even got a decent deal on it.  Now, the wife realized before we even got serious about shopping for one that we should probably tone down the size of the install in the new vehicle.  While she was/is still wanting some good sounding speakers and some bump going to the the size and extent of the build in the van was more than we need for this one.  One of the biggest reasons for that was simply because of the damage the Q's caused the van.  Before I installed them it was QUIET, not one interior panel rattled or made noise, not hardly a hint of sheet metal rattling could be heard.  At this point now not only is there a great deal of noise coming from the interior panels (particularly in the rear) but the Q's even managed to tear a spot welded seam in the floor of the van loose.  We simply don't want to repeat that in the new one.
      For this build we're looking at something smaller, possibly along the lines of a pair of 10's if the space is right, single 12, etc.  Something like the DCON, GCON or ICON come to mind, SSD's, possibly even IA or something else I've not got a chance to try yet as well.  We'll be running 1,000 to 1,500 watts on the subs and no more than that at all.  What goes in will depend completely upon the space available and which sub choice will work best with that space.  I'm going to try to keep the rear of the vehicle as usable as possible so I'm probably going to be building an enclosure with the subs firing downward and the port to the side.  The enclosure will likely consume all the space available on the width and depth behind the 3rd row seat and my limiting factor will be that we're trying to keep the enclosure height to about half the total height of the 3rd row seat.
      The wife wants another Kenwood HU so we'll likely be ordering a DDX491HD and a Maestro RR integration unit this weekend for the source and to keep all the factory wheel functions and such.  I'm looking to use a PPI P900.4 for the highs and a similarly sized subwoofer amp to run the subs and those will be tucked away in the storage compartment under the floor in the rear with added ventilation if necessary.
      That brings me to my biggest frustration with this build, lol.  Before we got serious about shopping for a vehicle the wife was COMPLETELY on board for me doing whatever was necessary to install the Bravox 603's.  Fiberglassed custom door panels were in the plans for whatever that vehicle was going to be, uh, well, right up until we picked up the Travy.  Now it's, "You aren't really going to cut it up and put holes in the doors are you?"    and "There's already places for tweeters, you can just use those right?"  then finally "You can just use the factory places for now, I want it to have a good sounding stereo but not know it until you hear it, as in can't see nothin'."
      So, there goes anything remotely close to what I was wanting to do.  I thought if the Bravox's wouldn't work out I might do a dedicated full range/midbass setup, or maybe even the equivalent of the Arc Audio Black 6.2 speakers in the SB Acoustic's mid and tweeter that Arc is using, or something really and truly worth a damn to do.  Nope.  She gave me a pretty much open budget for speakers but I don't see the point in spending any kind of good money on a set of components that cannot be optimally installed.  So I'm not completely sure where I'm going to go with the highs.  I have found a hell of a deal (<$250)on a new set of Kicker QS65.2 components which I'm leaning toward but I have to verify if there's any possibility of getting that tweeter behind the A pillar.  I've also looked at the MB Quart QC216 set which has a nice looking large format tweeter but since Maxxsonics has their nasty hands in MBQ now I'm kind of shying away from them as well.  As soon as I can figure out what the hell to do (still need to verify some measurements) I'll pull the trigger on equipment and get it coming.
      Although the Travy is pretty quiet from the factory I'm still going to be ordering some SDS to treat the doors and all of the rear to start with.  I'll work on the floor and roof after we've had it a little while.  It has the sun roofs so I'm not in a real hurry to tear all that interior off the roof, nor am I in a hurry to figure out how to tear all the seats, center console, and carpeting out to treat those areas just yet.  I also have to pull the door panels off to see what kind of baffles I'll need to construct for it.  Luckily with the lower power I'm looking at running and the 170A factory alternator I shouldn't be looking at having to do anything too major on the electrical side of things.  Probably just the BIG 3 in 1/0 with Knu Kolossus.
      So, that's the, um, kind of the plan, for what little plan there is.  The more I can verify as far as fit in this thing the better the direction for what/where it will go is going to look.  I hope to have all that figured out and to be ordering equipment and supplies this weekend.
      Here's a quick shot of the Travy.  I just grabbed it to show to a co-worker.
      Any input is welcome, especially from anyone who's done some install work in one of these as the entire Lambda platform is completely new to me.
  • Recent YouTube Posts
