altoncustomtech
1992 Olds 88 Royale LS - Build on the Cheap(er)
Alright got some updates again.  I got the amp mounted and wired up and the HU installed in the dash but I'll have to get pics of them taken and posted.  I had too little time working on it yesterday to take the time out to take pictures.  I tested the Dayton's for operation and I have to say I think they're definitely going to do the job.  Good and tight response and they have good enough output for what I'm doing with them.  I was able to get to the doors this morning and they're almost completely done now!!  I got the baffles trimmed up to fit the door panels properly and still clear the connectors for the power window controls.  I glued them to the door, got the grille fabric attached to the factory grilles and the grilles reattached to the door panel.  It's time to attach the speakers to the baffles, hang the door panels back on the doors and tune it all in!
Here's some pics from the progress this morning.
I missed this picture on the last updates, both the grilles drilled out.
A9D56E61-67CA-4671-B56F-E16997A4ECF2_zps
Here's the baffles test fit and outlining the parts of the panel that need trimmed up.
92D54CC8-E388-4FEF-9E39-12D023168DD7_zps
B28625CF-EBD1-4E95-9841-ABDF85C27F68_zps
The panel all trimmed up for the least amount of interference with the speakers.
9BC3012E-7B97-4CEA-9707-1C8221127DF0_zps
58F772B5-911C-4601-9160-2C904E05551E_zps
Grille fabric on the first factory grille.
6FA7DD05-59DD-416B-B198-CDCEBC8E2B76_zps
Here's both door panels with the factory grilles all finished up and reattached.  Not much left to do now!
C5E50EE0-2338-42F3-80EF-FA468CC795A8_zps
20FFADF4-5637-4CE2-B237-0D78A75749AD_zps
looks factory!
looks factory!
Thanks man, I appreciate that.
I finished the car up yesterday!  I got the 4x6's mounted to the bafffles on the door panels and reattached the door panels to the car.  I spent a little bit of time tuning it and I'm pretty happy with it so far.  It doesn't sound like the van or the Jimmy but it's a VAST improvement over the crap it sounded like before.  The Aura's aren't quite as smooth as I had hoped they would sound like but for the money I paid they could sound A LOT worse.  The Dayton's however are doing extremely well.  They could definitely use a little more power but they have a great punchy sound that's full and natural.  I didn't have time for many pictures yesterday, I'll get some more taken today and get them posted up.
Haha, I bet it's awesome to see your vision come to life, that's awesome!
Pics. Pics. Pics.
It is.  Although this vision is fairly minimal in comparison to the build in the Jimmy it's always good to see it come to life.
Pics. Pics. Pics.
Yes, yes, yes!  Though I have to appologize, I've somehow lost the pictures of the actual mounting of the 4x6's but I have a few to share.  I do have a small rattle behind the 4x6 on the driver's side that I think is the factory speaker wire rattling on the plastic vapor barrier, or it's just the vapor barrier.  Anyway, when I pull the panel back off to look into that issue I'll get some pics of all the behind the scenes part of the mounting, fit, etc. at that point.  I grabbed a picture of the door panel back on the car to show it still looks factory and of the finished amp install in the trunk.
As you can see, it looks almost the same as it did when I took it off.
F682026F-0EF0-442A-86F4-088490D6D8C8_zps
Here's a few of the amp mounted in the trunk and all the wiring completed.  It's nice to open the trunk and not even be able to tell any of it is in there.
381D133A-A5DB-4020-AD06-FC0BE1165A1E_zps
D9EDC631-FC94-4209-8902-E82EE42332E7_zps
3B0C1DA7-B617-4619-B91B-50B188798873_zps
I've gotten a little bit of time driving and listening to it and I can honestly say those Dayton's are some of the smoothing sounding woofers I've had the pleasure to play with.  It's probably got a lot to do with the fact they're being ran IB so there's no ill effects to be caused by an enclosure but they really are wonderful to listen to.  Detail and impact without being overbearing or muddy.  The 4x6's continue to leave something to be desired but I think there's an ill effect from the installation itself that's lending to the problem.  It reminds me of the issues was having with the Bravox components in the Jimmy.  The sound is a little dull and lifeless, like they're playing inside a closed cardboard box BUT the tweeters seem to shine fine and the stage/image is actually spot on.  Doesn't make a great deal of sense but that's what I hear.  Overall it's a fantastic improvement over the factory speakers which almost sounded like a big set of overear headphones mounted to the doors.
  • Recently Browsing   0 members
    1. Recent Topics
        • 1 comment
        • 89 views
        • 1 comment
        • 59 views
        • 1 comment
        • 58 views
      1. Box for 1 15" SSA ICON
        • 3 comments
        • 911 views
        • 8 comments
        • 1,837 views
        • 1 comment
        • 97 views
  • Similar Content
    • By BigDaddy13440
      Am currently looking at subwoofers to upgrade from my lowly Powerbass S-10D's. Have been running a Lightning Audio 1001.d monoblock @ 1 ohm for the last year, and every time I get it cranking, the amp shuts off after 10-15 minutes, blowing fuses. I am running a 250 amp alternator, and a brand new 1000ca/800cca battery, with 1/0 run back to my distribution block, and a 14" 4ga run to the amp, with the big 3 under the hood. Will be adding a second battery, under the hood, as there is a second battery tray. I really don't want to run much more power than what I already have, as I don't want to get into having to add a dual alternator, or putting another battery in the back. Probably looking at a1200-1500 watt amp, possibly Skar or Audiopipe, just depends on what I can find for a deal.
      The Powerbass subs are only rated at 350 watts rms, I'd like to be able to run a clean 600-750 to each. I haven't found much out there for a sub that has a high sensitivity, other than the Dayton's below. Most 10" subs that can handle 500 watts rms or more only have a sensitivity from 83-87db, these Dayton's are supposedly 90.5db. If I remember correctly, it takes double the power to achieve 3db more in output - if that's so, then these Daytons with 600 watts would have the same output as a different sub pushed by 1200 watts at a 87.5db sensitivity, or 2400 watts pushing a sub with 83.5db sensitivity.
      I know that Dayton is primarily a home audio company, but these have me intrigued. Specs look decent, and what other content I've found online seems to agree.
      If not these, then make another suggestion for a higher-sensitivity 10" sub, that will work in a 1.25-1.3cu ft enclosure (mine is about 2.8 cubes, less sub and port displacement).
      https://www.parts-express.com/dayton-audio-rss265ho-44-10-reference-ho-dvc-subwoofer--295-463
    • By SacredTanakh
      One of the biggest and most powerful amplifiers ever made. They didn't make very many of these so they are quite rare. one was recently tested by oldschoolstereo.com and made over 12,000w rms between the two channels at 1.6ohm per channel. Here is the link I recommend watching it as he goes into the history of this huge amplifier.
      And here is the manufacturers underrated specifications:
      Output Power at 14.4V and ≤1% THD+N (CEA-2006):
      2 x 2600W @ 4 ohms
      1 x 8110W @ 4 ohms
      1 x 7400W @ 1 ohm
      S/N Ratio: 65dBA (1 Watt, 4 ohms)
      Effective Damping Factor: 6.39 @ 4 ohms
      Freq. Response: 10Hz ∼ 270Hz (-3dB)
      Fuse: 600A internal (external 500A minimum)
      Dimensions: 29.38" x 23" x 6.5" (74.6cm x 58.4cm x 16.5cm)
      Weight: 88 lb.
      Only selling because I'm moving agian and need the extra space. The top beauty/mounting plates are in automotive primer ready to be painted to match your build.
      Condition is excellent. Price is $1500 picked up in the Dallas Texas area, or best offer, don't bother low balling Id rather keep it to be honest. It's only going to gain value considering how rare these amplifiers are getting. I would be willing to ship it if you cover the costs for shipping. Call or text me  for questions: 907-227-8213
    • By Shogen
      Parting with my beloved 80PRS .... Don't really want to see her go but I'm not one to waste amazing hardware
      SOLD
       PayPal verified only ...
      Unit is in great condition. Comes with bluetooth mic and TA mic. Also has wiring harness and remote plus faceplate case
      Photos below (sorry if not great but taken with iphone 7 plus aka my next listing)
    • By Tirefryr
      Selling off everything but a few things.  All items are BNIB unless otherwise noted.  I am NOT interested in trades, sorry.
      SOLD!
  • Recent YouTube Posts
