DedicatedEnthusiast
(2) 12'' Fi Q'S with cooling or (2) 12'' AA Havoc&
Now days the new Fi Q's are rated for 1500 RMS stock, 1700-1900 RMS with cooling while the AA Havoc is rated for 1250. In searching older reviews and comparisons I have read that for the most part the Havoc plays better down low but I don't know if it will handle the 1800-1900 watts RMS daily the Crescendo BC3500D will be giving it. I would like for the enclosure to be 5.0 net cubes tuned to a medium of 31 Hz either way and I prefer lower end deep and ground-pounding bass in the 28-36hz range more than anything. I want to flex my car to bitts and pieces and "feel" the music more than merely hear it. I want to violently shake everything and make it feel as though my car is falling apart on the lows. My only other consideration would be a Fi Bl but I am afraid it will be lacking on the lows for me as I mainly listen to chopped and screwed music and decaf down low (27-34hz)
I'd pick the Q's but that's just me. It's the woofer I want most from Fi, but I adore my BTL. Fi and AA are both awesome, so you won't go wrong. Hopefully some owners of those subs will chime in.
And lol fi and are like, nottttt really a different company lol. All the same people s :)
Edited by SpeakerBoy
Thanks man do you know if the cooling option takes away from the low end or sound quality? I've heard its negligible in a ported enclosure but it does alter the specs somewhat.
Not enough to pass it up. I have an obsession with tuning lower and lower to get them notes out; my BTL has everything (loaded, so with cooling included), and it makes every other woofer I've owned tap out. My twelves were tuned lower, but this monster didn't get the memo.
I'd be content with only Fi woofers from here on out :)
Box design will overrule smaller things like that; so utilize the available space wisely. For 5 cubes net you might want to consider tens, or sealed twelves. You could also save some money with a single fifteen in that space.
I like the Fi Q's
why are you even looking at the Q's when you should be looking at something like the Bl's. why would the bl lack low end? have you modelled any of these subs?
I've got 1 12" bl. It's a low end monster, I don't know where the lacking lows would come into play. If you tune @ 31 like you said, the lows will devastate your ear drums. Mine is at 32 hz. The bl seems to shine from about 40 hz down. Although car acoustics will play a role the bl would be an awesome option.
I've had a couple Q's. Box and car will play a huge role but the 12" in about 2 cubes tuned low 30's in my buddy's car digs deep for a single 12. Love the way it sounds.
Going by your description of what your looking to get from your system, look elsewhere. Get a BL or find a used btl.
Edited by smashedz28
I figured two 12's would yield a better turnout due to the advantage of cone area over a single fifteen and is 5.0 net cubes not optimal for two 12'' Fi Q's? The website recommends 1.8-2.5 per speaker. Also I thought that generally speaking ported gets louder and goes lower? Lithium I did not know I should be looking into something like the Bl's and I never said that they did lack lows just that I didn't know if they could play them with the same level of authority as the Q's.
Edited by DedicatedEnthusiast
model them and see for yourself. a lot of subjectivity has been thrown around here
The Fi Q is my favorite woofer. Other than my RE XXX v3 =]
more subjectivity. come on guys..
Fair enough so IF I went with the dual 12'' Q's would a 5.0 net cubed ported/vented enclosure tuned to 31Hz off a Crescendo BC3500D at one ohm on strong electrical be acceptable? Just making sure I am not far off on anything here in aiming for the best overall output out of these speakers.
lithium could you please explain to me the difference in sound quality/output I could expect from an SQ/"SQL" type speaker (the Q) vs more of an SPL oriented speaker such as the BL??
If you tune to 30 Hz at that volume for the Qs, havocs, sundown x, Icon, and supply them with clean power, you will be able to clear up the low notes without a problem. Tuning as low as 27Hz will take away from all the mid range, but if that's what you want, its worth a try to your liking.
To be honest I'm not sure I have an adequate understanding of SQ vs SPL. I just know that I like songs that dig DEEP and LOW such as walk with a waddle, thuggin, swing my door, itchin, soul survivor, I cook etc.
This would be a very nice sounding and loud set up. This would be my dream set up =]
cloud77 what do you mean by mid range? For example if I tuned to 28 Hz how high above that 28 could I play with extreme authority?
like 40-60Hz. If you tune to 31-32 you will hit these frequencies very loudly with 12's.
I know that typically one can play 2-3 Hz below tuning frequency but how high above tuning can one play without fading off into less of a noticeable response?
Ok...I know there are few even Decaf songs that go below 30HZ and my favorite range being 30-32 I figured I would tune to 31 so I could still play low (26-30) and mid range (30-36)
I would say when you tune to 32Hz, It gives you the ability to play about 10Hz below tuning and sound well and also get good mid range bass from the woofers. That's why they recommend this tuning in their cut sheets. The Fs of the Q 12 D2 is 34, so I wouldn't tune much farther below 32.
  • Recently Browsing   0 members
    1. Recent Topics
        • 7 comments
        • 373 views
        • 1 comment
        • 478 views
        • 1 comment
        • 179 views
        • 1 comment
        • 158 views
      1. Box for 1 15" SSA ICON
        • 3 comments
        • 1,024 views
        • 8 comments
        • 1,953 views
  • Similar Content
    • By Subwoofer Stokes
      Wassup guys I'm doing a port swap in the next few days and trying to get opinions/suggestions. I have a box 39.5h x 41.5w x 13.5" d (outer dimensions) with a port 12h x 10w x 40" l which gives me 6.8 cubes tuned at 31hz with 17.75 port per cube. It's just not giving me as much pressure I want on lows. The new port is 12" o.d. Pvc (11.5" I.d.) x 36" l with 2-4" external. This will give me about 8 cubes tuned at 29 with 14.25 p.p.c. I don't have anything to lose, and I'm not building a new box until I design a 6th. So what are your thoughts on what I have now?
    • By antoinez28
      I have for sale two crescendo bc 2000 for sale both are about 1 1/2 years old good deal power by two g31 batt juciebox, and crescendo logic...pushing 2 18" ethos strapped at 2ohm never seen below 12volt...I had to push them....got warm in this hot Kansas City weather...both will come with bass noobs and one with owners books the other might be lost during a move with both boxes from crescendo...I love these things they both went to db-r for repair but nothing major I had a bad ground and thought I blew them both
      Crescendo BC2000D
      Stable down to .5ohm on strong electrical.
      Up to 16.8v capable on BC2000
      Remote Bass/Gain knob with Clipping Indicator.
      Custom tooled, proprietary Multi-piece Thermal optimized Heatsink with patent pending interlocking slide-out CNC engraved top plate.
      2 stage copper anodized removable top plate.
      Silver plated high end hard-wired Tiffany RCA inputs and oversized 1/0 Power/Ground Inputs for efficient current transfer.
      Overbuilt Power supply with heavy copper traces and Military spec PCB/heavy duty standoffs for extreme vibration resistance.
      Manufactured using some of the highest quality and most reliable electrical components, with many 3% tolerance components throughout.
      Full 4-Stage Intelligent protection Circuitry 1 Year/1ohm comprehensive warranty with 2 year/.5ohm optional extended warranty available.
      Rated Power Output(RMS)
      Clean RMS power on 13.8v standard electrical system:
      Ohm Load
      BC2000d
      1ohm
      2250
      2ohm
      1100
      4ohm
      700
      Dimensions: BC2000: 16"L x 2.75"H x 9.5"W (at widest point)
      I want 550.00 for the pair or 300.00 each shipped no lower
      I'm upgrading to a bigger amp dd-m4a
    • By antoinez28
      So I'm been on the web looking at different types of 5k amps that are linkable amps, so I can upgrade my current amp set up...I'm looking for a amp out of these new or used- dd m4a, sundown audio 4500, crescendo bc5500, dc audio 5k, ampere audio 5000.1. It has to be able to do around 3800-4000 wire down to 1.3ohms.
      Running 3-18s DSS ethos box is in the works....
      Electrical is dual alts stock will run the truck, mid, and highs the singer 270amp will run only for the battery bank. 4 juice box blackcherry battery back, two runs of 1/0 wielding wire.
      ( would like more batts if space would allow)
      ( playing music daily and burbs on comps)
      I'm not looking for a father and son conversation here just wanting to know which amp would be better suited for my set up that's all thanks for reading.
    • By sps1989
      My current setup consists of:
      -Advance auto parts group 34/78 up front
      -stinger spp1500d in the back
      -mechman 270a alt
      -Crescendo bc2k
      -Crescendo c1100.4
      -Knu konceptz 1/0 all around including big 3
      I was wanting to upgrade to something bigger (maybe a dc level 6 18). I am tore between 2 options...(both options will have c1100.4 and same batteries plus some later down the line)
      1st:
      -Taramps hd5000
      -2 positive runs of sky high 2/0 from front to back
      -3 positive runs to the amp
      -Big 3 in sky high 2/0
      2nd:
      -Another bc2k strapped to the other one
      -1 run of sky high 2/0 from front to back
      -2 runs of knu 1/0 or 1 run of sky high 2/0 to each bc
      -big 3 in sky high 2/0
      I can save money going with another bc, but would the more efficient taramps be a better option? Im just curious of yalls thoughts on the taramps.
  • Recent YouTube Posts
