Quentin Jarrell
ETHOS PARAMETERS AND RECOMMENDED BOXES
THE FOLLOWING ARE THE FINALIZED PARAMETERS FOR THE 12 INCH AND 15 INCH DSS ETHOS TRANSDUCERS  (NOTE: physical dimension will be added soon)
12 INCH DSS ETHOS
re           3 ohms
Le          2.94 mH
Qms       5.91
Qes       .54
Qts        .49
Fs          28.24 hz
Mms      326.15 grams
Cms      .1 mm/N
BL         21.43 T/M
Vas       33.1 liters
spl         84.99 1w/1m
sd         490.87 cm^2
xmax     32.5mm per 70% Bl rating
recommended power 1,800 watts
15 INCH DSS ETHOS
re           3 ohms
Le          2.94 mH
Qms       10.6
Qes       .69
Qts        .64
Fs          25.78 hz
Mms      362.9 grams
Cms      .1 mm/N
BL         21.43 T/M
Vas       95.93 liters
spl         88.22 1w/1m
sd         804.25 cm^2
The design goals of these drivers were to create around 3 db of ripple and a f3 of 28 hertz in a recommended ported enclosure of 3 cubic feet for the 15 and 1.5 cubic feet for the 12 tuned to 32 hertz.  Below is a screen print of the 12 and 15 in their respective enclosures.
  Ethos12and15atrecommendedbox_zpsd8612e26
Edited by Quentin Jarrell
Thanks Quentin. You should delete my post, sticky this, and lock it!
3cubes for a 15 dammmm that's small ported? doesn't say ported nor sealed?
scratch that winisd says "Vented"
Edited by Dictator
edited for you.  This is why it's not locked.  I have a bad habit of forgetting the details.
When you get a chance will you put the table with the different enclosure's and there respective info.
Hell yeah!
