Whatshisface176
2 SAZ-1200's on Fi SP4 15?
I have the saz-1200 on a fi sp4-15 dual 2 for right now. Was wanting to know if strapping 2 saz-1200's to the sub wired @ 1 ohm would work out well??
If they are strapped you have to use a 2 ohm load.
You can't do it with that sub. Only 4 or 1 ohm.
Edited by pmureika
Oh.. Why can't you wire the amps to 1 ohm?
Do you have a manual. When you strap them it goes to 2 ohms only.
I can't wire both amps to 0.5 ohm to get 1 ohm?
It's the sub you wire to get the ohms you want. When amps are strapped they are 2 ohms!!!!!!!!!!
http://www.sundownaudio.com/index.php/products/amplifiers/item/saz-1200d.html
Edited by pmureika
Oh okay, sorry i'm not to familiar with impedance and amplifiers. Especially with strapping... So if i wire the sub to 1 ohm, and strap the amps together. The amps will be at 2 ohm and the sub will be at 1?? Sorry if i'm wrong
I'm trying to figure this out
Yes the sub would be at 1 ohm but the amps strapped can't go below 2 ohms.
You need a d1 or a d4 sub to get to 2 ohms. That is what the strapped amps will put out.
Edited by pmureika
Wire the sub in series
scratch that.got my head up my ass lol
