shizzzon
Taramp's Group Buy Amps, processors, etc...
Taramp's Official Group Buy
The Group Buy will end February 16, 2014 11:59pm EST on a Sunday night.
We expect all orders to come in and ship out domestically between week one and two of March. We expect all orders to be delivered to customers in the Group Buy before SBN 2014 which is March 22-23, 2014.
All prices set below for immediate payment include shipping and is good for the lower 48 states. Shipping to Alaska, Hawaii, other territories of the US and all International orders are subject for custom shipping quotes which shall be done via contacting me at- [email protected]
All amplifiers (unless otherwise noted) come with custom Wire inputs used to run extra or larger cables to amp to prevent unwanted voltage drop.
It IS POSSIBLE that some amps may not have their inputs manufactured on time(mid March).  If this happens, we will let you know and ship them out for free immediately after receiving them.
We just want to let everyone know this just in case our deadline is not met.
Warranty coverage is 1yr from manufactured date.
We offer alternate warranty coverage that is described in this link-
And now, the pricing-
HD Series
Full Range SMD(Surface-Mounted Device) Technology based Class D amps.
These amps range from 5Hz-10HZ - 15KHz, Power rated at 0.3-0.5% THD and have on-board subsonic, low pass and bass boost* with efficiency ranges in the 72-78% range at low ohm stability range.
When placing your order, PLEASE put into text field which ohm stability version you wish to purchase!  The power rating next to the amp model will be it's capability at specified ohm version.
IE- 1,439w amp can be built for 1 or 2ohm rating.  Certain amps may or may not have additional ohm versions but ALL versions will be listed next to each amp.
Power supply range- 10.5v-16vDC
HD8000
9,595w @13.8v @0.5% THD
Ohm versions- 1 or 2 ohm
Dimensions (WxHxD): 9.02" X 2.56" X 19.57"
Weight: 13.47lbs
Wire input adapter- Triple 1/0 - 4/0 Insert with Protective Insulation
Price- $795 shipped PayPal-IntegrationPage-PaymentBTN-BuyNow
HD6500
7,796w @13.8v @0.3% THD
Dimensions (WxHxD): 9.02" x 2.56" x 18.82"
Weight: 11.46lbs
Wire input adapter- Triple 1/0 Insert with Protective Insulation
Price- $729 shipped PayPal-IntegrationPage-PaymentBTN-BuyNow
HD5000
5,997w @13.8v @0.3% THD
Dimensions (WxHxD): 9.02" x 2.56" x 17.6"
Weight: 11.44lbs
Price- $659 shipped PayPal-IntegrationPage-PaymentBTN-BuyNow
HD4000
4,798w @13.8v @0.3% THD
Dimensions (WxHxD): 9.02" x 2.56" x 14.76"
Weight: 9.08lbs
Price- $615 shipped PayPal-IntegrationPage-PaymentBTN-BuyNow
HD3000
3,598w @13.8v @0.3% THD
Dimensions (WxHxD): 9.02" x 2.56" x 11.34"
Weight: 6.86lbs
Wire input adapter- 4awg to 1/0 terminal
Price- $469 shipped PayPal-IntegrationPage-PaymentBTN-BuyNow
HD2500
2,998w @13.8v @0.3% THD
Dimensions (WxHxD): 9.02" x 2.56" x 9.53"
Weight: 5.73lbs
Price- $425 shipped PayPal-IntegrationPage-PaymentBTN-BuyNow
HD1600
1,919w @13.8v @0.3% THD
Ohm versions- 1, 2 or 4 ohm
Weight: 5.52lbs
Wire input adapter- 6awg to 1/0 terminal
Price- $376 shipped PayPal-IntegrationPage-PaymentBTN-BuyNow
HD1200
1,439w @13.8v @0.3% THD
Dimensions (WxHxD): 9.02" x 2.56" x 8.08"
Weight: 4.37lbs
Wire input adapter- Unavailable
Price- $332 shipped PayPal-IntegrationPage-PaymentBTN-BuyNow
HD800
959w @13.8v @0.5% THD
Frequency Range- 20Hz - 30KHz
Dimensions (WxHxD): 7.68" x 2.2" x 7.91"
Weight: 3.53lbs
Price- $295 shipped PayPal-IntegrationPage-PaymentBTN-BuyNow
HD400.4S
All ratings are at 0.02%THD at 13.8v
Ohm versions- 2 ohm only
4x100w @2Ω / 2x100w @2Ω + 1x200w @4Ω
4x60w @4Ω / 2x200w @4Ω / 2x60w @4Ω + 1x120w @8ohm
4x33w @8Ω / 2x120w @8Ω / 2x33w @8Ω + 1x66w @16ohm
Frequency Range- 10Hz - 38KHz
HPF / LPF Fixed @80Hz
Dimensions (WxHxD): 5.94" x 2.01" x 7.99"
Weight: 1.4lbs
Price- $174 shipped PayPal-IntegrationPage-PaymentBTN-BuyNow
T Series
Besides the T500, this line is Taramp's extreme high output series with efficiency ranges from 71-89% at 1ohm(and at 1 or 2ohm on T500). These amps are also full range for use for bass and midbass\range as well going up to 5KHz with subsonic and low pass filter.
All power ratings based on 12.6v with power supply voltage range from 10.5-15.0v.
T20.2KW
20,200w @0.3%THD
23,800w @13.8v
Frequency Range- 5Hz - 5KHz
Ohm versions- 1 ohm only
Dimensions (WxHxD) - 11.46" x 2.2" x 28.74"
Weight: 31.09lbs
Price- $1829 shipped PayPal-IntegrationPage-PaymentBTN-BuyNow
T14.2KW
14,200w @0.3%THD
16,800w @13.8v
Weight: 29.76lbs
Price- $1659 shipped PayPal-IntegrationPage-PaymentBTN-BuyNow
T10.9KW
10,900w @0.3%THD
12,890w @13.8v
Dimensions (WxHxD) - 11.46" x 2.2" x 24.88"
Weight: 22.71lbs
Price- $1399 shipped PayPal-IntegrationPage-PaymentBTN-BuyNow
T500D
500w @0.5%THD
599w @13.8v
Bass Boost
HPF / LPF fixed at 100Hz
Dimensions (WxHxD) - 8.27" x 6.61" x 2.05"
Weight: 2.65lbs
Price- $189 shipped PayPal-IntegrationPage-PaymentBTN-BuyNow
Edited by shizzzon
TS Series
This line of amplifiers come in 2 or 4 channels. These amps come in 1ohm or 2ohm stability models and all ratings below are of 1ohm model. Expect slightly higher efficiency with 2ohm models.
All amps in the TS line use FIXED Crossover points.
Power supply range- 10v-16vDC
T1300x2
Rated Measurement- 13.8v @0.45%THD
2x780w @1/2ohm
2x468w @2/4ohm / 1x1559w @2/4ohm
2x257w @4/8ohm / 1x935w @4/8ohm
1x514w @8/16ohm
Frequency Range- 15Hz - 38KHz
Efficiency- 80%
Power Supply- 9vDC minimum
Bass Boost
Dimensions (WxHxD): 7.68" x 2.2" x 12,2"
Weight: 4.87lbs
Wire input adapter- Optional $20 (6awg to 1/0), not included
Price- $359 shipped PayPal-IntegrationPage-PaymentBTN-BuyNow
T1200x4
Rated Measurement- 13.8v @0.5%THD
4x360w @1/2ohm
4x237w @2/4ohm / 2x720w @2/4ohm
4x130w @4/8ohm / 2x474w @4/8ohm
2x260w @8/16ohm
Efficiency- 80%
Bass Boost
Dimensions (WxHxD): 7.68" x 2.2" x 14.25"
Weight: 6.06lbs
Price- $399 shipped PayPal-IntegrationPage-PaymentBTN-BuyNow
T800x4
4x240w @1/2ohm
4x150w @2/4ohm / 2x480w @2/4ohm
4x72w @4/8ohm / 2x300w @4/8ohm
2x144w @8/16ohm
Frequency Range- 20Hz - 40KHz
Efficiency- 78%
Bass Boost
Dimensions (WxHxD): 7.68" x 2.2" x 12.44"
Weight: 5.18lbs
Price- $319 shipped PayPal-IntegrationPage-PaymentBTN-BuyNow
T600x4
4x180w @2ohm
4x108w @4ohm / 2x360w @4ohm
4x60w @8ohm / 2x216w @8ohm
2x120w @16ohm
Frequency Range- 10Hz - 40KHz
Efficiency- 80%
Dimensions (WxHxD): 6.61" x 2.13" x 10.04"
Weight: 3.35lbs
Price- $249 shipped PayPal-IntegrationPage-PaymentBTN-BuyNow
T400x4
Rated Measurement- 13.8v @0.05%THD
4x100w @2ohm
4x63w @4ohm / 2x200w @4ohm
2x126w @8ohm
Efficiency- 80%
HPF / LPF fixed at 90Hz
Power Supply- 8vDC minimum
Dimensions (WxHxD): 5.28" x 1.65" x  7.99"
Weight: 1.96lbs
Price- $179 shipped PayPal-IntegrationPage-PaymentBTN-BuyNow
T150x2
2x75w @2ohm
2x45w @4ohm / 1x150w @4ohm
2x25w @8ohm / 1x90w @8ohm
1x50w @16ohm
Frequency Range- 18Hz - 40KHz
Efficiency- 80%
Dimensions (WxHxD): 6.54" x 2.01" x 3.62"
Weight: 1.12lbs
Price- $109 shipped PayPal-IntegrationPage-PaymentBTN-BuyNow
Crossovers
CRX2
Channels - 2
Subsonic Filter: Variable Bypass /20/60/80Hz (-24dB/ 8deg 4deg order Linkwitz-Riley )
Bass Boost: 0 to 10 dB (40Hz)
Low Pass Filter: Variable from 100Hz to 10KHz (-12dB/ 8deg 2deg order Butterworth)
High Pass Filter: Variable from 100Hz to 10KHz (-12dB/ 8deg 2deg order Butterworth)
Input Impedance: 27K ohms
Output Impedance: 440 ohms
Maximum Input L/R: 4.57 V RMS @ 15.4 dBu
Output Level L/R: 9.3 V RMS @ 21.6 dBu
Max. Output of the Pass Thru L/R: 9.3 V RMS @ 21.6 dBu
Frequency Response: (-1dB) of 10Hz to 100KHz
Total Harmonic Distortion (THD): < 0.01% at 1KHz
Crosstalk (Separation between channels): >90dB
Power Supply Voltage: 10 to 16 VDC
Nominal Consumption: 250mA @ 12.6 Vdc
Protection: Reverse Polarity and short circuit
Dimensions (WxHxD): 6.18" x 1.65" x 5.71"
Weight: 1.01lbs
Price- $134 shipped PayPal-IntegrationPage-PaymentBTN-BuyNow
CRX4
Electronic Crossover 12dB/ 8nd with 4 channels
LOW: With variable cut(LPF) from 45 to 275Hz and bass enhancement of 6dB ( "bass boost") adjustable from 20 to 65Hz
MID-LOW: With initial cut (HPF) variable from 25Hz to 140Hz and final cutting (LPF) variable from 300Hz to 7.5KHz
MID-HIGH: With initial cut (HPF) variable 200Hz to 4.6KHz and final cutting (LPF) variable of 1.2KHz to 12KHz
HIGH: With variable cut (HPF) of 550Hz to 12KHz
Individual level Controls for channel
Track LOW and MID-LOW mono, with independent inputs
Tracks HIGH AND MID-HIGH stereo, separated from inputs LOW and MID-LOW
Dimensions: 7.48" x 5.71" x 1.58" (L x W x H)
Weight: 1.24lbs
Price- $159 shipped PayPal-IntegrationPage-PaymentBTN-BuyNow
CRX5 Plus
Quantity of channels - 4 + 1 Pass Thru
Track Pass Thru (R L)
Phase Selectable: 0/180 Degrees
Variable Level: -infinity to 6dB
Via Low (R L) Mono
Subsonic Filter: Selectable (Bypass 40/60/80Hz ) (-24dB/ 8nd) butterworth
Low Pass Filter: Variable from 100Hz to 2KHz (-12dB/ 8nd Linkwitz-Riley )
Bass Boost: Variable 0 to 10 dB (40Hz)
Variable Level: -infinity to 10dB
Via Low Mid (R L) Mono
High Pass Filter: Variable from 30Hz to 600Hz (-12dB/ 8nd Linkwitz-Riley )
Low Pass Filter: Variable from 600Hz to 10KHz (-12dB/ 8nd Linkwitz-Riley )
Track High Mid (R and L) Stereo
High Pass Filter: Variable from 400Hz to 3KHz (-12dB/ 8nd Linkwitz-Riley )
Low Pass Filter: Variable from 5KHz to 20KHz (-12DB/ 8nd Linkwitz-Riley )
Track High (R and L) Stereo
High Pass Filter: Variable from 2KHz to 10KHz (-12dB/ 8nd Linkwitz-Riley )
Input Impedance: 10K Ohms
Output Impedance: 470 Ohms
Maximum Input Level R/L: 4.57 V RMS @ ( 15.4 dBu)
Maximum Level of Output R/L: 9.3 V RMS @ ( 21.6 dBu)
Max Output Level of Pass Thru R/L: 9.3 V RMS @ ( 21.6 dBu)
Crosstalk (separation between channels): >85dB
Power Supply Voltage: 10.5 to 16 VDC
Nominal Consumption: 420mA @ 12.6 Vdc
Protection: Inversion of Polarity
Dimensions (WxHxD): 9.37" x 1.65" x 5.71"
Weight: 1.54lbs
DTX 2.4s
Filters: Per DSP, 24-bit/ 48KHz, (-24dB/ 8th) - 4TH order (Butterworth)
VIA LOW (L/R)
cut-off Frequency (HPF): 9 preset adjustments 20/25/30/35/40/45/50/55/60Hz
cut-off Frequency (LPF): 19 preset adjustments 60/70/80/90/100/110/125/140/160/180/200/225/250/280/320/360/400/450/500Hz
TRACK LOW MID (L/R)
cut-off Frequency (HPF): 11 preset adjustments 60/70/80/90/100/110/125/140/160/180/200Hz
cut-off Frequency (LPF): 25 preset adjustments 200/225/250/280/320/360/400/450/500/570/640/720/800/900/1K/1.1K/1.2K/1.4K/1.6K/1.8K/2K/2.2K/2.5K/2.8K/3.2KHz
TRACK HI MID (L/R)
cut-off Frequency (HPF): 21 preset adjustments 200/225/250/280/320/360/400/450/500/570/640/720/800/900/1K/1.1K/1.2K/1.4K/1.6K/1.8K/2KHz
cutoff Frequency (LPF): 9 preset adjustments 5.1K/5.7K/6.4K/7.2K/8.1K/9.1K/10K/11K/12KHz
VIA HIGH (L/R)
cut-off Frequency (HPF): 17 preset adjustments 2K/2.2K/2.5K/2.8K/3.2K/3.6K/4K/4.5K/5.1K/5.7K/6.4K/7.2K/8.1K/9.1K/10K/11K/12KHz
Input Impedance: 18K ohms
Output Impedance: 470 ohms
Maximum Input L/R: 4.0 V RMS @ ( 14 Dbu)
Maximum Level of Output L/R: 4.0 V RMS @ ( 14 dBu)
Frequency Response: 20Hz to 23KHz (-3dB)
Signal / Noise Ratio: >90dB
Crosstalk (separation between channels): >80dB
Nominal Consumption: 0.50A @ 12.6 Vdc
Dimensions (WxHxD): 9.76" x 1.65" x 5.32"
Weight: 1.52lbs
Additional Functions: Adjustments of phase, gain, alignment and mute
Price- $229 shipped PayPal-IntegrationPage-PaymentBTN-BuyNow
Equalizers
DEQ-1000
Frequency Selection:
15 Bands separated by 2/3 octave (25Hz, 40Hz, 63Hz, 100Hz, 160Hz, 250Hz, 400Hz, 630Hz,
1KHz, 1.6KHz , partials close , 6.3KHz , 4KHz, 10KHz, 16KHz) Mitigation
/ Enhancement: up to 12dB in steps of 0.5dB
Signal / Noise Ratio: >100 dB
THD: < 0.01%
Frequency Response: 15Hz to 23KHz (-3dB)
Maximum Level of Input Signal: 2.0V RMS
Maximum Level of Output Signal: 2.0V RMS
Input Impedance: 22K OHMS
Output Impedance: 330 OHMS
Operating Voltage: 8V to 16V DC
Maximum Consumption: 400mA
Dimensions (WXHXD): 7.6" x 1.7" x 4.72"
Weight: 0.68lbs
Limiter with 6 levels of attenuation: (-3dB/ -6dB/ -9dB / -12dB / -15dB / -18dB)
Filter HPF (subsonic): (Fc = 30Hz / 40Hz / 50Hz / 60Hz / 70Hz / 80Hz) with attenuation of
24dB/ 8nd
Filter LPF: (Fc = 500Hz / 1KHz / of 1.5khz / 2KHz / partials close ) with attenuation of 12dB/ 8nd
screen Saver with VU
VU Bargraph leds with TI CLIP
Power Supplies
TEF-30A
Dual voltage Power Supply: automatic (127 / 220V AC)
Operational range 127V: 100 to 140V AC
Operational range 220V: 200 to 240V AC
Rated Current max. output: 30 Amps
Efficiency: 85% Consumption
Maximum Current Draw 127V: 5.6 Amps
Maximum Current Draw 220V: 4.0 Amps
Maximum Floatation at full load (30A @ 12.6V): < 3%
Input Fuse (internal): 10A, quick action
Dimensions (WxHxD): 6.54" x 2.05" x 5.71"
Weight: 2.36lbs
TEF-50A
Operational range 127V: 105 to 140V AC
Operational range 220V: 210 to 240V AC
Rated Current max. output: 50 Amps
Output Voltage (Selectable): 12.6/ 13.8v/ 14.4vDC
Maximum Current Draw 127V: 8.0 Amps
Maximum Current Draw 220V: 5.0 Amps
Maximum Floatation at full load (50A @ 12.6V): < 3%
Dimensions (WxHxD): 10.55" x 2.83" x 6.22"
Weight: 5.51lbs
Price- $339 shipped PayPal-IntegrationPage-PaymentBTN-BuyNow
TEF-100A
Operational range 220V: 190 to 240V AC
Rated Current max. output: 100 Amps
Maximum Current Draw 127V: 16.5 Amps
Maximum Current Draw 220V: 12.8 Amps
Maximum Floatation at full load (100A @ 12.6V): < 3%
Protection Threshold against overload/ short outlet: 120A
Dimensions (WxHxD): 10.55" x 2.83" x 11.42"
Weight: 9.48lbs
Price- $449 shipped PayPal-IntegrationPage-PaymentBTN-BuyNow
TW Master/Slave
CHARACTERISTICS OF the TRANSMITTER (TW-MASTER):
Operational Range of Radio Frequency: 2.4GHz ISM band (2.404GHz to 2.476GHz)
Maximum Power of RF transmission: 20.2dBm (105mW)
Connectivity: Up to 4 receivers (Slave)
Input Impedance: 10K ohms audio (RCA) and 1K ohms (WIRE)
Maximum Level of audio input L/R (RCA): 2V RMS ( 8dBu)
Frequency Response: 10Hz to 22KHz (-1dB)
Total Harmonic Distortion (THD): 0.01% the 1KHz
Signal/Noise Ratio: >90dB
Power supply Voltage: 10 to 16V DC
Maximum Consumption: 160mA @12.6
Consumption in Stand-by: 10mA
Protection: resettable thermal fuse (PPTC), internal protection against polarity reversal
Dimensions (WxHxD): 3.47: x 1.18" x 4.65"
Weight: 0.22lbs
CHARACTERISTICS OF RECEIVER (TW-slave):
Output Impedance: 470 ohms audio
Output level of audio L/R: 2V RMS
Nominal Consumption: 100mA @12.6
Consumption in Stand-by: 40mA
Maximum Current output from remote: 250mA
Dimensions (WxHxD): 3.47" x 1.18" x 4.65"
Weight: 0.22lbs
Additional Slave device-
Price- $94 shipped PayPal-IntegrationPage-PaymentBTN-BuyNow
Universal Antenna-
TFM1080i
The TFM 1080i Antenna has a universal application. It can be installed in any vehicle, secured by double-sided tape, developed with high performance, active circuitry that ensures clean reception, free of interference and noise. Great signal reception from AM and FM. Its design comes from meeting with the market trend, lightweight and discreet.
TFM 1080i antenna universal electronic windshield printed Rod 10.25"
SMD Technology amplified
8' 6" Cable from the antenna
Connector in brass surface treated to eliminate oxidation
Red LED
Connection PLUG DIN
Universal Application, can be installed in any vehicle
Price- $19 shipped PayPal-IntegrationPage-PaymentBTN-BuyNow
Voltmeters-
VTR-1200
Innovative Digital Voltmeter
Unique design, lightweight, transparent, functional and practical; very easy to be installed.
Displaying BLUE showing the mark of innovation that TARAMPS provides to its consumers.
For its connection, the connector system is detachable facilitating ease of installation.
Technical Data:
Voltage Range: 10.2 to 27V DC
Maximum Current output remote (OUT) 650mA
Maximum current Consumption: 60mA
Dimensions: 4.72" X 3.47" X 1.18"
Weight: 0.22lbs
Price- $59 shipped PayPal-IntegrationPage-PaymentBTN-BuyNow
For RCA Cables and T-Line High Voltage amps(115v-390vDC), contact [email protected] for custom price quote.
I know some guys in Indy that will be participating in this ;)
May have to grab myself a HD8k if my budget allows :)
I wouldn't hesitate. Finally got my other hd8k back from repair. Man these things put out hella power. I wish I could buy 2 more lol.
the price on the HD8000 makes me sad I bought amps recently
Hurry!
Group buy ends tonight!
It's over....now get me & the Indy guys our amps!! ;)
Edited by chicagofan
  • Recently Browsing   0 members
    1. Recent Topics
        • 7 comments
        • 434 views
        • 1 comment
        • 594 views
        • 1 comment
        • 214 views
      1. Box for 1 15" SSA ICON
        • 3 comments
        • 1,083 views
        • 8 comments
        • 2,005 views
        • 1 comment
        • 164 views
  • Similar Content
    • By Sencheezy
      My old build log was deleted when DSS lost their section. So I have to start from scratch. Here is the update for my truck for the 2015 season. This build will be complete by October 2015 and will consist of the following hardware.
      6 Team SSA 15" subwoofers
      3 Taramps HD30kSPL amplifiers
      3 JuiceBox LiFePo4 80ah batteries and 1 20ah.
      Single Reflex Bandpass Enclosure 10 cuft sealed, 35 cuft ported, 900cuin port area
      The end goal is to do a 165 any where. My last build loudest score was 162.3 outlaw with 6 15" DSS Ethos and 3 Taramps HD8000
      This is still my only vehicle that I own.
    • By antoinez28
      My goals to be able to hit a 155.0
      With a window line box and being able to demo low note and burp high notes like in the 50s
      My build came a long way ...
      Working on getting that iPhone 6 slow mo cam is great
      https://m.youtube.com/watch?v=VOoaSMFNRbw
    • By sps1989
      My current setup consists of:
      -Advance auto parts group 34/78 up front
      -stinger spp1500d in the back
      -mechman 270a alt
      -Crescendo bc2k
      -Crescendo c1100.4
      -Knu konceptz 1/0 all around including big 3
      I was wanting to upgrade to something bigger (maybe a dc level 6 18). I am tore between 2 options...(both options will have c1100.4 and same batteries plus some later down the line)
      1st:
      -Taramps hd5000
      -2 positive runs of sky high 2/0 from front to back
      -3 positive runs to the amp
      -Big 3 in sky high 2/0
      2nd:
      -Another bc2k strapped to the other one
      -1 run of sky high 2/0 from front to back
      -2 runs of knu 1/0 or 1 run of sky high 2/0 to each bc
      -big 3 in sky high 2/0
      I can save money going with another bc, but would the more efficient taramps be a better option? Im just curious of yalls thoughts on the taramps.
    • By Sencheezy
      Ok guys, here is MY personal Review of the Taramp HD8000
      I personally own Three of them. I purchased two use from DangRebel here, and the third directly from Shizzzon. One of used ones from DangRebel went into protect immediately upon hooking up. And the BNIB from Shizzzon also went into protect while demoing Sunday afternoon while at Slamology.
      Here is a few pictures of my installation for Reference.
      On the chargers.
      So to explain my experience in total. My system consist of One DC Power 240XP, 100ft of 3/0, Ten Batteries. I also should mention I run each amp at 1.5 ohm, the amps are the Two ohm version.  Now, the drive down to Indiapolois is about 5 hours long. For the better half of the trip, I would turn the gain up half way, couldn't take much more than that, (pressure wise). So the most my voltage would drop would be .1-.3 Volts. During some testing at the shop, we clamped 3200 watts starting at 2.7 rising to 8.1 pulling a little over 300 amps of current.
      The first time demoing there that Friday night, I was able to burn up 2 300 amp fuses while playing full tilt after 2 or 3 songs. Replaced the fuses, back up and running.
      Saturday, I beat ALL DAY. Was still having engine issues. So for 87% of my demos were at battery voltage. Since the engine was off, that also means no rear A/C to cool them, still no issues. Yes, they did get warm. On sunday, got warm enough to not hold your hand longer than 30 seconds. But again, it wasn't THAT hot lol.
      To describe how the amps are mounted. The rear wall is 3" thick of High Quality MDF. Which an another layer of 3/4" wood mounting plate is attached. Then the steel rack. Then the amps are mounted onto an 3/4" MDF mounting baffle, that is mounted onto the steel amp rack. Shizzzon informed me that there was still too much vibration, and wired too low, which is why the bottom amp failed. I was able to verify that the amps were indeed moving, but from what I could see, it was only becuase the truck itself was moving. Not much else I can do about that.
      So in sum, these amps, in my opinion, are the better choice for us in every aspect, EXCEPT durability. If you think of where these amps come from and their origin, it makes sense for what I see is their biggest flaw. These amps are MUCH more sensitive than Koreans. The output section especially. We had I believe 3 other Team IAK members whom amps failed as well. One was becuase the wrong gauge was used for the speaker cable. One was for no reason, there's mine, and one other.
      So, for advice for other users. It is ok to run these amps, they do power, cheap, small, and stupid efficient. To run these long term usage, have these key items.
      2-3 Group 31s PER HD8000. Use the appropriate size for the output section. 8 gauge min. Ensure there is NO to VERY min. vibration. And wire to the proper ohm load. I wouldn't even risk burping lower than rated. Do not count on box rise.
      Please note, that the ENTIRE weekend I beat the living piss out of my system lol. Most people, demo for 20-30 seconds at most per demo. I would play full songs full tilt, had no issues. I played my system for at least 4-10 hours in total over the weekend. The amps gave me no issues until Sunday afternoon. Which was a much hotter day, maybe 5-10 degrees more. There was no smoke, just protect light. Yes there was troublshooting performed. Turn system off, let cool down, unplug everything, let cool down, remove RCA/Speaker cables, etc.
      Moving forward, I will Continue to run these amps. At four ohms each for now, then at World finals run at 2 ohms.
  • Recent YouTube Posts
