Hey guys, I plan on building a system from scratch when I buy a new vehicle. Im planning on buying a Jeep Grand Cherokee and buying a BC5500d and I will have plenty of space in the rear of the SUV but I cant decide if I want to get 2 12"s sundown x-12s or an 18" SSA Evil. Those subs are just examples, Im not set on any one brand or sub. What do you guys think? 2 12"s or an 18" or something else possibly?
Matt
depends. how much space do you have?
Not sure the exact size but i dont plan on using the rear for anything else besides the subs, so ill have room for probably around 10 cubes
I would say the Evil, hands down. I see too many X coming up in classifieds to make me comfortable recommending them. My box builder is happy with his, but those X won't have a fair fight against the 4" coil Evil. Plus, I love single-sub setups.
Agreed :)
The first question should be how much room do you have followed by what does your front stage consist of to keep up with the amount of bass you are planning. Unless bass is all you want to hear.
Agreed :)
Awesome, thanks for the input. Any 18s "better" than the evil? Something that could be powered by one BC5500d?
Evil can. Could also look at the IA Warden and B2 XC
Sundown team 18" SSA evil 18" or Incriminator 18" would be my choice any of those is on a crescendo 5500 is gonna be rediculously loud. Your gonna need some electrical upgrades to support a 5500 watt amp. Big 3 Altenator and rear battery.
On +5000wrms I'd definitely put that to two subs versus one.
Why are you comparing two 12" subs to a single 18"? Enclosure requirements are vastly different and it sounds like you want to use all the space you have. If I had a Cherokee I'd use two 15" subs unless I walled it.
I'm like edouble I would use 2 15's or 2 18's for 5k watts+ in a suv. Should be plenty of room for a huge box and a couple of battery's.  I would measure first see how many cubic feet you have for a box then match the biggest subs you can fit to the power you have. 2 15's at 2500watts a piece should move a ton of air.
Im pretty sure he is gonna come back 3 years later and read this but carry on :roflmao:
What the hell this shit is years old why did it pop up and say 6 hours ago it was posted. It even said new in the forum head.
You may have fell pray to bad spam bot timing. They're notorious for posting in old threads, but then someone like yourself sees the new post and makes a reply right about the same time the spam post is deleted by the admins and this is the result.
curious what he decided to get? since this threads here now... lol
Well I'm old it could be a problem on my end lol I'm old to the bass scene but new to the blogging or forums or what ever it's called.
No worries.  As long as out dated threads are not being bumped up for no reason, you're fine.
  • Recently Browsing   0 members
    1. Recent Topics
        • 7 comments
        • 373 views
        • 1 comment
        • 478 views
        • 1 comment
        • 179 views
        • 1 comment
        • 158 views
      1. Box for 1 15" SSA ICON
        • 3 comments
        • 1,024 views
        • 8 comments
        • 1,953 views
  • Similar Content
    • By TLOTIS
      I’m looking to build a ported enclosure for (6) Ampere Audio AA-2.5 6.5” D2 subs. They will be run on a 5k/1 ohm stable amp wired at a 1.33 ohm load. There will be plenty of power as they are 500 rms and 800 max.  I can’t seem to get anything from Ampere Audio on the port size I need. With sub displacement my box needs to be 2.48 CF (+) port displacement. Does anyone have suggestions or know how to calculate the port size? Square inch and length is what’s needed. Hopefully someone can help on this
    • By codester
      Been awhile since Ive been on here but I Just purchased back my 2x 15" SSA Icon subs I first purchased around 11 years ago.
      I have/ had them in a 7.2 cubic foot box net tuned to 32 and it sounded great on the bass music and rap/ hip hop I used to listen to but not amazingly accurate/ punchy on rock, etc.
      Im looking to only use one of them in my 2010 Ram 1500.
      I currently have a 10" JL W7 in a sealed box in the truck and it sounds great and I love it but doesn't quite have the output Id like and planning to put 1 of the Icons in the truck.
      Im considering either Ported or sealed. I now listen to mainly bands like chainsmokers, club music, alt rock, heavy rock, and a bit of edm, etc. Looking for it to be very accurate on kick drums but also hit hard so you feel it in your chest.
      According to SSA optimal ported is around 3.5-4 net tuned to around 32hz but Im thinking about tuning a bit higher. Ive done some winisd modelling but its been a long time and just wanting to hear thoughts on these designs.
      My max dimensions are 20" wide, 24" deep by 22" high.
      This is one design i'm considering, is 2.25" wide too thin for port width? im worried about port velocity and noise
      Or if I go sealed this is what im thinking.
      Thanks again for any help
    • By Austin863
      Well, well, well, Look what the cat dragged in. super surreal to be back on the forum after pretty much a friggin decade.
      it’s nice to see most of y’all are still active here! Here’s the current build in the works for my 2005 forester.
      Plan/currently installed:
      -6.5 door upgrades (2 evil 6.5 up front paired to some evil tweets|2 coaxial alpine typeS in rear doors. Most likely going to make custom crossovers for the front)
      -1 Sundown Sax100.4
      -Sound deadening on the inner door skins removed all plastic lining on door skins aswell.
      -old ass pioneer Bluetooth double din head unit from 2012
      On the way to me:
      -1 SSA Evil 15” woofer d1 probably running on a half ohm to whatever amp I decide on.
      -Amp TBD and Currently taking suggestions(3-400 target price range)
      -1 ported enclosure tuned to roughly 30-31hz
      objective of this build is to be a SQ monster with the capability to be Very LOUD and lots of pressure.
      I got this car in a trade and have had to do a few maint repairs to it. But this is exactly the build I was thinking about when looking for this car. So I’m suuuuper stoked and have been brewing this build up for a while now. Feel free to ask questions and leave feedback on whatever!!
      Feels good to be back!!
    • By Ryann627
      Thanks in advance guys.
  • Recent YouTube Posts
