hayestc
Hello from Albuquerque
Hi SSA,
I have been looking around car audio forums and have decided that this would be the best place to join as I am trying to get honest answers to some questions that I have about a system that I want to build.
A bit of background on me.  I am a resident of New Mexico and have a degree in EE.  I have always enjoyed listening to all types of music and consider myself, at least somewhat, an listening enthusiast.
I had an '03 Toyota Matrix upgraded with two of the OLD Alpine type R 10" subwoofers, Alpine head unit and a whole host of different components powered off a 45W alpine 4 channel amp.  Alpine fan at the time.
I currently have an '08 Chevy Cobalt Coupe with fully upgraded exhaust, read LOUD, and completely stock, read SUX, stereo which I am looking to upgrade.
I did the custom look with everything exposed on the Matrix but I am looking to keep everything as stock looking as possible in my Cobalt.  (Don't want it to be a target.)
I will be starting another thread to ask about speakers and such for my listening style, hard rock to heavy metal including Double Bass and Violin.
Thanks,
Hayestc
Welcome
:WELCOME: to the forum!
:WELCOME:
  • Recently Browsing   0 members
    1. Recent Topics
        • 7 comments
        • 352 views
        • 1 comment
        • 447 views
        • 1 comment
        • 175 views
        • 1 comment
        • 154 views
      1. Box for 1 15" SSA ICON
        • 3 comments
        • 1,016 views
        • 8 comments
        • 1,932 views
  • Similar Content
    • By MJS_IraggiAlts
      PRV AUDIO Vocal Speakers....
      This may not make sense initially, but a high-quality speaker will have less bandwidth than a lower quality speaker... (for the most part)
      Just like a 3- or 4-way system is always better than a 1- or 2-way system.  The narrower the bandwidth the speaker must play the cleaner it will sound.  This will also keep you from asking the speaker to play up to its upper and lower frequency limits which are where it starts to sound "forced" to play those frequencies
      Pro Audio speakers are nothing new to car audio, but I see consumers not really knowing how to properly use them and having some issues which is understandable.  These are totally different than your standard coaxial speaker
      If you look at the graph on the 6mr500ndy, which sounds amazing, you'll see that it can play from 90hz to 12,000hz... but if you narrow it down to what is plays "best" and more "naturally" it’s closer to 200hz to 10,000hz.   Yes, it can play down to 50hz but not efficiently and not as well as 200 and up. Very low volume that would be fine but in what we do with the speaker you will want to cross it over closer to 200-300hz
      I get a lot of PMs asking if this speaker will pick up where my subs leave off?   … around 60-80hz.  I say no but the specs say "yes”. 99-13k so that may be a little confusing if you don’t look at the graph and understand what information it has in it
      So, for someone interested in using this speaker as a voice speaker, which I HIGHLY recommend, you will also need a "midbass" speaker to go with it such as a 10mb800 or 10mb500 or 8mb450.
      This leads me to another piece of information.  PRV model numbers have an "MR”, “MB", "SW" or "W" in between the size of the driver and wattage of the individual speaker. MR=midrange
      MB=midbass
      W=woofer
      SW=subwoofer
      This is a general guideline for what the speaker is geared towards. That doesn’t mean an 8mb450 can’t be used for midrange or and 8mr400 can’t be used for midbass.  That is where the graph and interpretation of the graph comes into play
      There is a lot more that goes into designing your front stage or your "voice" speakers that one of these days I’ll try and have a more in depth write up.   The possibilities are endless...
    • By DaViD12464
      Hello, I have problem with choosing speakers (I'm just new in car audio), but I got 2 power amplifiers - CONCORD CA 2075 (300W),they are both 2 channel. One of them is bridged and connected to bass tube (raveland 400W). Second one will be connected to 4 speakers (2 x front 165mm, 2 x rear 130mm) , and I need to buy them, but I don't know how to compute how much Watts those speakers should have when i will connect them to this 300W power amplifier, which would have 2 speakers connected to + and - "left" and next 2 speakers for + and - "right". (You don't need to give me models of speakers cause idk if they will be available in my country, just give me how much watts they should have and I would really happy ;D)
      And my question is can i connect wires going out of radio (normally to speakers now they are going to power amplifier) and cinch wires both at the same time??? (just got both with this stuff and I don't especially know if it's right :P
      Ps. sorry for any mistakes caused by my english abilities :/
    • By DedicatedEnthusiast
      Hello everyone, long time no see. I am selling a pair of Dual 2-ohm (technically D1.7) 12" Sundown X v.2's built by Dave Leib a.k.a "Strongman Designs."
      Reason I am selling them is because I realized upon testing to see if my digital multi-meter was working correctly that one of the coils is reading higher on the one sub indicating that too much heat had been applied to it recently so rather than risking any further damage to it I am going to assume that I have too much power for these.
      Having said this in all honesty, let me make it perfectly clear here that both subs are still in perfect working order as we speak, even the one that is reading differently. Had I not thrown my multi-meter on it to test it in order to see if it was working properly (the multi-meter itself) I would have never known there was any difference or discrepancy between the two.
      However, because one of them is reading off now and I do not know what is to be expected out of it's performance long-term I will be letting these go for $500+ shipping (that includes both).
      Any further questions or concerns please feel free to text me at 440-915-2309
      Phil
    • By Jburns2422
      Hello all!! New here and just have a quick question to get me started, picked up an 18" soundqubed sub and i'm going to build a ported enclosure with blueprints from soundqubed; problem is they don't specify what type of wood to use or the thickness, some info here would be greatly appreciated!! TIA! Jesse    i included a photo of the build specs for all who is curious!
  • Recent YouTube Posts
