frogcase2002
needing help with front stage
If I'm trying to do a 2 way front stage. With a 3 way crossover that has the hpf 's I need for the Mids and tweeters how would I cut them off where they need to be if I have no controls on the amp for them? Subs are from 25-60. So was going to cross the Mids around 60. And tweeters around 4-5 k ......
Use the 3 way crossover.
Perhaps I read the question wrong, but you state you want to do a 2 way active with a 3 way crossover and your amps have no crossovers...to me that is a benefit, I would much prefer up front controls.
Your crossover points sound a bit strange, more information would be helpful.
Ppi 600.2 for my 4 pwx's And ppi 200.2 on tweeter (haven't decided which ones) American bass 3.1r crossover. . Am I able to cut off the Mids with that. Not just hpf. Don't really know much about the front stage yet but wanting to learn
That isn't a 3 way crossover that will work for what you are trying to do. That is a 3 way crossover meant to crossover components that already have a crossover but no low frequency protection. No way to use it to run a 2 way active set.
What would you suggest to use with them mids and amps and whatever tweeters I get? I could use the 300/4 I have but wanted more power
What would you suggest to use with them mids and amps and whatever tweeters I get? I could probley use the 300/4 I have with that crossover but wanted more power
The problem IS the crossover, you need a different one. I'd recommend an active capable headunit.
