Quentin Jarrell
ETHOS 12 PARAMETERS AND DIMENSIONS
All info on the 12 inch Ethos will be located here.  Still working on large signal parameters.  For now here are the physical dimensions of the driver.
Well these are the specs i'm talking about!
enclosure rec???? please
For the 12? If so I believe Quentin told me 1.5 @ 32 or 34 depending on what kind of response you are looking for.
still working on finalizing as I'm waiting on final large signal parameters.  They will be 1.5 cubic feet tuned ~32 hertz.  I won't be able to give final specs until.  However I have sample parameters which are as followed.  These are in the ball park but I added mass to the cone and adjusted the spider pack a bit.
well I don't have a Klippel viewer on this computer give me about 30 minutes while I download one
below is the sample and is not final production.  You will see when modeled a dip or saddle in response in the 40-60 ish range when modeled in the recommended 1.5 tuned ~32.  This has been addressed and why I'm awaiting final parameters.
re     1.5
qms    9.48
qes     .36
fs     28.8
mms     347.6 grams
cms      .09 mm/n
B/L     16.95
vas     29.926 L
sd     490.87 cm^2
spl 85.3
Do you have this measurement for the 15" version?
