Recently Browsing 0 members
Recent Topics
- 7 comments
- 352 views
- 1 comment
- 447 views
- 1 comment
- 175 views
- 1 comment
- 154 views
- 3 comments
- 1,016 views
- 8 comments
- 1,932 views
Similar Content
By mikebingham34
Hello all, I have been away from the forums for some time since graduating college and started working again. Now that I have some money to finally move away from these seemingly low powered setups (6 systems since 2012), I am looking for help with my wall build. I am going to be building the base to the wall in my 2016 Ford Focus sedan in a week or two, and there is a lot of room to work with (over 30 cubes). I will be running 2 18" ZCONs on (undecided) either a 5.5k or 6.5k amp with supporting electrical (batt bank, lots of OFC wire, and HO alt). This is my daily, and I just want a ground pounder with no care to what numbers it'll put up in the lanes. I would like to demo a lot. I'm thinking 8 cubes per sub (16 cubes net) tuned to 32 Hz is a good place to start (recommended by SSA). I'm thinking either a center slot port, or a top port.
** I listen to ALL kinds of music, Decaf/DJSNT, rap, hip hop, metal, rock, 80s/90s pop, jazz, country, movie scores, blues, dubstep/electronic, classic rock, oldies, etc, etc..**
Now... my questions are: How much port area do y'all recommend? Is 8 cubes of net volume per sub a good amount? Should I be alright running an underrated 5500 watt amp, or go with the 6500? What port orientation shall I go with?
If I think of more questions, I will be sure to post them.
P.S. Sorry if I am asking some questions that are common knowledge among these builds, but this is my first "loud" and "high powered" setup. My two loudest systems thus far have been a single Obsidian Audio 15 on about 900 watts, and 2 Sundown Ev3-12's on 1300 watts.
Thank you for your time and patients everyone! Cheers.
By Jon
I recently purchased a SSA Evil 18in sub, and a 3k rms amp. my first ever real set up so im pretty new to car audio. but i have a question and in need of advice. when i turn up the volume it almost sounds like the subwoofer is bottoming out or making a clicking noise. is this normal or do i need to lower the power on it. or is there more to it than just that?
By spanky1975
I am trying to run the auto-eq on my unit. I keep getting an error message for outside noise.
I am running in 3-way active mode. Internal amp is turned off. I did reset the head unit and tried again and still had the same error. I am performing the auto-eq in a very quiet closed garage.
Any suggestions or help is greatly appreciated.
By antoinez28
2005 tahoe running
2 runs of 1/0 cca and
3 batts juicebox black cherry, apple, and crescendo logic 31
Order a 270 amp 6 phase power coated red
So I went ahead and order a stinger alt and was wondering a few things being the fact that I never had a beefed up alt before...would that be a problem running my stock and a stinger alt if not do I need extra part to do that.
Do I have to run to different lines from the alt to the batts or can I just do alt to alt to batts...if so do I have to run the stinger alt first than the stock ???
Recent YouTube Posts
