Here's the thing, i was considering getting 2 - 12" older model p3s, 2ohm subwoofers,
Power Handling (Watts RMS): 400 Watts RMS
800 Watts Max
With this amp
http://www.rockfordfosgate.com/products/details/p1000x2
Rated Power
(RMS Continuous Power): 300 Watts x 2 @ 4-Ohm
500 Watts x 2 @ 2-Ohm
wired with the 2ohm version
If i can't find the older ones in 2ohm, i've come across the 4ohms, but wiring them would only deliver 300 watts, is this enough or do i have to get the 10"(which only require 300)?
going in the trunk of a car, have 39" width and want to do less than 8" deep, ~16-18 high(considering leaving a spot on the box for the amp). will post up a drawing later(i have a couple tasks i need to take care of when i get home)
The one you missed was using the second configuration but bridging at the amp for 1k @ 4ohm.
I'd just run 4 ohm x 2.
huh? its 400w rms, so i wouldnt push it past 850
if i cant find the 2 ohms? or is there a reason for choosing 4 ohms over 2 ohms?
this option would send 200w less to each sub and be 100w under the suggested power lvls
You can't hear a 100w difference.
why limit yourself to RF? Tons of options
my dad had rf in his old truck and it was legit, basically good experience. im open to suggestions though. also, i dont like the cosmetics on the pioneer and some of the other models, i like the simplistic look of the older rf
Oh yeah, budget wise, i only want to spend about 600 tops on the sub and amp, that was one of the main reasons. I considered the alpine shallows, but they are hella expensive(300ish ebay/amazon for sub and then alpine amp 2-300) . The kenwoods are closer to 4"(i believe) and i want the box to be about 6-8" deep tops(going in car trunk). also, i heard mb quarts are like almost 3", but i'm not familiar with the brand.
