Notorious97200
How much room I need to leave in front of a port ?
Hello ,
I am building a box with a round port. I'll try to flare the openings to have a nice flare port :)
It will be a 6" port or an 8", I don't know yet !
How far from the box side can I have the port ?
How much "room" does it need to play correctly, safely ? I know I can use an elbow, and I will if it's necessary.
Thanks in advance for your advices.
If it is on the side why not just build a slot.  You can still flare it if you like to reduce the overall needed area.
i only have about 4 inches   from my port to my trunk wall
i looked this up a while ago i kept reading.
atleast half of your port length.
so if your port is 6" long you need atleast 3" from whatever(hatch, wall, ect)
Port length is 8".
But I am talking about the space in front of the port IN the box.
Box is 16" tall. 3/4" mdf
So : 14.5 - 8 = 5.5" in front of the port(the air entry) in the box.
Is that enough ?
If not, I will have to use an elbow.
Port is firing up. No problem, there is room.
The slot flared port is another idea.
I'll think about it.
But I can adjust the round ports easier.
It isnt half the port length but rather half the port diameter I have even read some references that claim a distance equal to the port diameter.
Port Flares
Fared ports are typically made out of a plastic material. Slot ports are normally made out of the wood you are building the box with. Port fares can be a weight savings.
IIRC I read a study where the author proved that the air velocity was less with a flared round port tube compared to a slot port with equal surface area. So this means that you can have a smaller fared round port tube compared to a larger equally performing slot port. This is beneficial for reducing port length which reduces net enclosure size and helps reduce overall weight. I also think that enclosures using flared round ports are easier to build.
It's what I thought, edouble101.
I need all the room I can save for the DD9515 : it needs box volume. I am getting 3.8 ft3 net, at 35 HZ.
RAM designed the box for me, but I wanted to check some things, here !
He told me that I would not need elbow; with the height of the box, and the port length.
Thanks, guys.
