Robert Christman
Subwoofer Dilemma!!!!!!!!
Hello everybody
         I'm trying figure out what would be  a good spl subwoofer that i can throw in my 2003 chevy tahoe i got 1k saved for subs cant fig out should i go with 4 12's 4 15's OR 2 18's I only got a 48"x48" space because im keeping the rear seats in taking out the tired row only  48x48 i can do 6 12s   or 4 15's maybe 3 18s  If i wanted to.....
So the dilemma is what brand i wanting to spend any were from 350-400 per a sub
Fi BTL
Re audio even tho there not like they used to be
soundqubed
DD
sundown
Hello everybody
Fi BTL
soundqubed
DD
sundown
SSA zcon !8 teens X2.
Four 15" SSA GCONs
given you have enough space to give the 15s what they need how is 4 12s vs 4 15s a comparison lol. if you have the pesos do 4 15" icons. :)
Do you have everything else you will need? Batteries, amps, an alternator etc? How much power do you want to run and what are your goals?
I am SO confused.
Are your max dimensions 48"x48" with the third row seats in or out? What about that whole third dimension?
I would scratch the BTL idea only because they aren't produced anymore and I think it would be difficult to find that many of them used with the same configurations.
And since the math doesn't add up I'm guessing your budget is flexible?
Edited by Frostedflakejake
48x48x22 is how big i can go, yes i got 3 batts and big 3 setup, No amp No alt because i dont have the subs yet ill buy that when i get the subs so i can match them up..... Also what are my goals i want hair flying window flexing BASS
Four 15" SSA GCONs
Bet that would be loud! Wish I had an extra grand floating around.. 4 15" gcons would sound good in MY 2003 Tahoe
what about bigger how are the zcon and the xcon icon or even the new one?
They are all awesome capable woofers but I was trying to stay near your $1000 budget
The ssa EVIL is a lot more $. For your budget gcons may be the best option for 4 15's
would they be good for comp the gcon?
Definitely
what about 4 of the xcon 18s or 15s
They'd all be great in a properly designed and built enclosure
Ok im looking at the xcon 15 or 18 what one would i be able to hit good LOWS and be able to beat my buddy 2 orion 15 hcc ran off a 3k hifion
I would put any of the SSA woofers up against the HCCAs. The "lows" will be enclosure dependent.
If you have the money, go with the XCONs. You can't go wrong with the GCONs or ICONs though
you said 1G .... so wouldn't 4 -15" Xcons break that budget????
just wondering, I mean we all have pipe dreams ... lol
remember im getting 4 of them
H
By what $300 no biggy i Got the money and I make good money
Do these subs like  a open box like 48wide 18 tall 28deep
Have you considered zcons? What is it about the xcon that has you interested in them?
  • Recently Browsing   0 members
    1. Recent Topics
        • 7 comments
        • 373 views
        • 1 comment
        • 478 views
        • 1 comment
        • 179 views
        • 1 comment
        • 158 views
      1. Box for 1 15" SSA ICON
        • 3 comments
        • 1,024 views
        • 8 comments
        • 1,953 views
  • Similar Content
    • By TLOTIS
      I’m looking to build a ported enclosure for (6) Ampere Audio AA-2.5 6.5” D2 subs. They will be run on a 5k/1 ohm stable amp wired at a 1.33 ohm load. There will be plenty of power as they are 500 rms and 800 max.  I can’t seem to get anything from Ampere Audio on the port size I need. With sub displacement my box needs to be 2.48 CF (+) port displacement. Does anyone have suggestions or know how to calculate the port size? Square inch and length is what’s needed. Hopefully someone can help on this
    • By Ryann627
      Thanks in advance guys.
    • By Aaron Clinton
      A brief introduction to the all new SSA Demon, but first a farewell to its predecessor.
           Our very long running SSA Dcon has ridden off into the sunset, or at least taking a breather.  The SSA Dcon was our second subwoofer model we ever launched.  At the very beginning, we had the Icon and as it gained traction we saw there was a need for a pure SQ sub of more modest power rating than that the Icon.  So in early 2008, the first SSA Dcon was launched.  (The Xcon followed shortly after).  That being said, the Dcon was almost an immediate hit, with a long 2" copper coil (rarity to have one made in the USA) triple stack motor, rear vent.  The Dcon was very affordable, well made, quite efficient, clean across the entire range, and flexible with enclosure demands.  It is interesting as there are some SSA Family members who swear by their Dcon and will not give it up ever.  (It even became a favorite of some of the home audio crowd).  All that being said, the Dcon evolved a bit for its second generation, we made a leap forward in motor force moving to what is best described as a scaled down Xcon motor, with a large single slug, solid pole, and deeply bumped back plate, while beefing up the suspension and leads.  We were able to bring the power handling up 33% while not hurting the sound that made the Dcon successful.  There was a stretch of a few years, before we ran out of stock, that the SSA Dcon 12 was our all time best selling subwoofer.  So its existence was very important to SSA.  Well with changes in the market (read:customer demands and amps getting much cheaper), as well as sky rocketing material costs, building the Dcon in the USA no longer was an option, so production stopped early 2017 for both the Dcon (and Gcon) and inventory ran out later that year.
           Late last year, due to the long lay off with out the Dcon (and Gcon), we started development of an updated Dcon at a new build house.  The quality and performance of our SSA Evil1 tweeters were above our expectations, so we decided to send more production to that same build house.   As we saw that the market slowed overall for modest power rated subs due to power getting cheaper and people wanting higher power handling subs, so the market began to really start heating up in the 500 - 1200 watt range, I knew we needed to address it.  There is an 8" model developed, but it will not make it this first production run.
           The new model had to handle more power and have more xmax while not sacrificing the balanced and clean sound the Dcon had established for nearly a decade.  That meant larger motor, larger coil, more suspension, larger leads, thicker cone, taller surround, etc.  In the end, all of the changes that happened to the over all design, we could no longer call it a Dcon.  In sticking with the theme of the Evil, a model name that has become so well known, while respecting the Dcon, the Demon name was selected.  The Demon is a great blend of the previous Dcon and Xcon, both in design and appearance.  In prototype testing, the SSA Demon thrived smaller to mid-sized ported and mid-sized sealed enclosures.
      Quick SSA Demon stats:
      2.5" copper coil Aluminum former Aluminum Shorting ring Solid pole, non-vented bumped back plate Large single slug motor Pressed pulp cone Tall roll surround Push terminals Dual Nomex progressive spiders Stitched tinsel leads Large dome dustcap I will list T/S specs and enclosure recommendations shortly.  We are very excited about the SSA Demon as it bringing back to our line up a pure sound quality subwoofer that will be affordable, while still having the characteristic SSA warmth and output.
    • By DedicatedEnthusiast
      B2 Audio X2C 15
      $650 shipped!
      Contact at 440-915-2309 for further questions/concerns.
  • Recent YouTube Posts
