Recently Browsing 0 members
Recent Topics
- 7 comments
- 450 views
- 1 comment
- 665 views
- 1 comment
- 226 views
- 3 comments
- 1,101 views
- 8 comments
- 2,027 views
- 1 comment
- 184 views
Similar Content
By DedicatedEnthusiast
Crescendo BC3500D is approximately six months old, has never been exposed to low voltage and has no scratches, dings or dents whatsoever. Does 3,875 watts RMS at 13.8v
Xs power XP3000 battery is sitting at over 12.7v after being out of my car for several weeks now and is rated to support 3,000 watts rms power
2/0 welding wire is rated to support over 400 continuous amps of current and has already been heat-shrinked and fused for both positive and negative runs from front to back plus the big three upgrade and an additional trunk ground if you so wish to use it
WIRE CAN BE HAD FOR $120 SHIPPED FORGOT TO PUT PRICE AMONG OTHER INFO ON SALES SHEET
So i've seen several differing opinions on this was jw what the correct thing to do is now days when dealing with 12v xs power batteries such as the d5100R
By codester
So Im looking to add another battery to my truck as Im wanting to have no electrical issues. I have a 2003 Dodge Dakota crew cab with 4.7L V8 and will be recieving and installing my Singer 250 amp alt in about 2 weeks. I have a XS power D2700 in the front and a positive and neg run of Knu OFC 0 guage to back. My problem is I want to put a new battery under my false floor and only have like 6-6.25" max of height and about 16" depth by 16 width approx. I was going to get a XP2000 but even on its side I dont have the height, my question is: will running two XP950's be much less power than an XP2000? I know on paper its not much. Also will this be adequate for a Crescendo BC2000d at one ohm and a 300- 500rms approx 4 channel to maintain 13+ volts?
Recent YouTube Posts
