1two3
Help with WinLSD parameters not working
sub in question here is a xcon 15
this is my first time using this or any sub enclosure design software
when i put in the qts, qms and qes parameters this is what happens:
Help a noob out! :)
dont fill in qts.  Let it calculate it itself.
^^^ What he said-  I hit tab after each entry- and if it autofills the next block(unless it is way off), I leave the calculated #.  Also inportant as a newbie to the program is to pay attention to the units of measurement next to the boxes. They can mess you up too.
thank you!
it corrected itself to .419
i tried that before but it didnt work, but this time i hit tab and i guess that did it :D
Edited by 1two3
It doesn't allow rounding so it'll error out if you force it to be rounded.
