khinds94
Mirror flex on 750 watts
you're playing off a stock deck, bro
So do I
I know that, I haven't put in a HU yet considering my dash configuration makes it more difficult. I think its a double din thats why. But How much do you gain switching from AUX
how do u like the amp? my friends just about to buy one of those bad boys
The amp definitely puts out what it says. When I got mine in I had a shop install it. They told me that the amp did not work and I ended up purchasing another from their store. Months later I installed the amp myself to find out it actually works and sounds noticeably better. The only issue I am currently having is that the amp turns off after about 5mins when the car is running. And i just need to restart the car. Im sure the amp probably got messed up in shipping.
Sounds like you don't have the gain set right or something.
The amp will go into protect mode.
Check to see if the amp is getting hot.
Edited by pmureika
I have fooled around with the gain and it does not help. I am sure it doesnt have to do with low voltage because it will turn off when im driving even if I had not turned the bass up. It doesnt even go into protect, it just turns off. I think its either because of a faulty amp or because the grounds.
If it restarts when you turn the car off and back on then its going into protect mode.
Also are you using any bass boost?
Plus like you said check all the wiring, even the speaker wires.
I have fooled around with the gain and it does not help. I am sure it doesnt have to do with low voltage because it will turn off when im driving even if I had not turned the bass up. It doesnt even go into protect, it just turns off. I think its either because of a faulty amp or because the: grounds.
No I dont use bassboost.
Im gunna try redoing the ground cause I dont think it is touching a lot of bare metal.
Have you done the Big 3?
sounds like loose ground or speaker wire, had the same thing happen. check all conections.
what amp did u have before that this one sounds noticably better?
Why only when its running?
Thats what I don't understand!
theres alot of factors that can influence it cutting out. say your driving and u hit a pot hole, bump, take a sharp turn ext. its even possible that the vibrations caused by the engine could loosten it out if not properly secured.
when mine was cutting out i could be standing at a red light or driving on a perfectly smooth road and it would still do it. for me it was the speaker wire input on the amp that got loose.
also if your amp is mounted directly on your box with nothing inbetween to dampen the vibrations it could loosten the screws that way.
easiest way would be to check all conections at all ends to make sure its good that way. then go from there
I had the EV1500m, it sounds better probably because that amp doesn't do anywhere close to rated.
No not yet. I have been planning on ordering some wire to do it though.
oh god sound storm. i made the mistake and tried getting one of their 2 ch amps. worst decision of my life. rma that shit if u still can
Yeah after hooking up the SQ I knew that there is no way the 1500m does 750 @ 2 ohm lol
