I'm running a single saz2500d and I was wondering what battery setup I should run to keep my volts up? Also should I run 1 or 2 batteries? Thanks guys
also is it worth the money to buy a HO alternator? If so how many amps and what brands should I look at?
I would get at least a 300 If you can. Plus at least one 3100 series battery.eek5wavey.gif
all depends on imp load and box rise but like has been said  start with the biggest alt you can fit . also do the big 3 upgrade and get a volatge meter to keep an eye on volatge drop if you drop below your battery resting volatge then start with aux batts
I'm throwing one xs power d2400 under the hood and one in the back and I'm gonna check the voltage after that. and I already have the big 3
I run my saz2500 on my 150 amp alt and a g31 diehard platinum. When I get some free time ill see what my voltage drop is for ya.
That'd be awesome! Thanks!
