llplayboypep
setup help
ok the box got alot of air flow..an the person im trying to be louder than has 4 cvrs 2 ohms on two lanzar 2000 watt amps.
my brother has the same subs on two 2200d audioque amps...
Build a good box with your equipment and you might be able to be louder. 2 totally different systems with you and your friend.
I'm going to try and make this as simple as possible.
If you are trying to compete, you will want a completely different box tuned much higher, closer to 50hz for competitions (assuming you are doing burps). (Which won't give you the loud lows because frankly competitors don't use low frequency burps to compete because they aren't as loud).
As far as speaker wire from the amp to the sub, nothing larger than 12 ga. is necessary, and will not yield any discernible improvement.
As far as an improvement in the amplifier department, what is your budget?
Lastly a properly built box is the single greatest improvement you can make in any system.
^^Listen to this OP. As stated before, you need to change your box before blowing money on amps....will make a much bigger difference than just replacing amps.
Ok a solid box or seal
Use a ported box!
More seriously neither. Ported is what you need.
Ok thats what im.going to go with mdf board
But you need to make sure its the right size and is ported to the proper frequency. The right box is the most important part of the build!
Ight thts.what imma do
