So I have a SoundStorm (SSL) EV4000D. I've had it for about a year and a half, and never have had a problem with it, except that I have blown two Subs with it. The first one was a Pioneer TS-W3002D4 which lasted about 8 months and then the most current one which blew today was a Kicker CompRT12. So i need suggestions of what kind of sub i should get because obviously the last two were a fail. I want something that will thump my price range is up to $250. Hope I can get some feedback.
The problem here is quite obviously your misuse of the products.  The problem isn't the amp blowing the subwoofers, the problem is you blowing the subwoofers.  Properly used subwoofers don't just blow.  You need to figure out what you are doing wrong and fix that before you replace the subwoofer, otherwise it will simply end up blown as well.  My initial guess would be improper amplifier settings in conjunction with not understanding when a driver is stressed.  But we need more details to figure out what exactly is going wrong.
Give us more details of your previous setups, including enclosures used and system setting (amplifier gain/bass boost, any headunit settings, subsonic filter settings if any, etc).  Otherwise it's pointless to look for a new sub, unless you just like throwing money at new subwoofers.  If you knew how the drivers failed (thermal or mechanical) that would be helpful as well.
those speakers failed because of YOU.. not the amp.
some one could run a jensen 10 on a 7K and not blow it.
 you need to adjust your settings and figure out what your doing wrong.
Edited by bigjon
Well first of all the box that I use is Sound Ordnance BB12-150v, The Input sensitivity is 100mV-2V, The Subsonic Filter is around 36Hz and the bass boost has been close to +13DB. The first sub that I had failed due to mechanical. The second one which failed today I don't know what failed on it. I did check all connections, fuses and wires. Hooked up a sub to my amp and made sure it was my sub but other than that, I do not know what went wrong on the Kicker.
Where did you have the gain set in that range?
Bass boost should be at zero.  You had it set to +13 ?
Does your HU have any adjustements?  What HU do you have?
As Q said, you overpowered all of the drivers which is what lead to the failure.  The problem that lead to that situation was likely improper system settings.
The input level was about 4/5 turned. I did not know bass boost should be at zero.
My HU is a JVC KD-S48, I do have adjustments on the head unit.
Bass boost needs to be at 0.  That alone could quite easily be the source of your problems.  Long story short, the bass boost asks the amplifier to output more power, in your case more power than it actually can.  This causes clipping which significantly increases the amount of average power over time it's outputting and the subwoofer is receiving.  If that average power is more than the subwoofer can handle thermally or mechanically, then it blows.  As you've found out wink.png  There is a "proper" way to use bass boost, but I'm not going to explain it because there is absolutely zero need ever in car audio to use a bass boost.  Just simply leave it at zero.
I couldn't find anything quickly online that gave the preamp voltage of your HU.  It looks like a lower end model, so I'm guessing it's fairly low (not that this is inherently "bad", but it does affect gain position to a degree).  And given the small input sensitivity range with that setting (looks like it can also be adjusted for 2V - 8V, I'm assuming you had it in the 100mV - 2V range), it's possible that your gain was set correctly.  That said when you install a different sub, you need to reset your gain and verify it's set to a level that isn't over-driving the amplifier or the subwoofer.  This is one of the few times I'd suggest you read and follow the sticky in the amplifier section regarding how to set a gain with a DMM.  Normally I'd suggest setting by ear based on driver stress.....but given your history it doesn't appear you can readily identify driver stress smile.png
Without knowing the actual tuning frequency of your enclosure, it's hard to say for certain but just as a guesstimate I'd venture to say your subsonic filter (SSF) was set atleast to a safe level.  Many prefab boxes are tuned pretty high, normally close to or a little higher than 40hz.  So a 36hz SSF setting should be sufficient.  If the enclosure is tuned lower than 36hz then you could possibly lower the SSF a bit.  While we're on the topic, whatever sub you choose next, it would be wise to spend a little extra & have an enclosure custom built.  If you can construct it yourself we can help you design it.  But a prefab enclosure is going to restrict your ability to extract full performance out of your subwoofer.
Can't give you advice on headunit settings without knowing what those features are and the available settings.
Thank you Impious for helping me out tonight. I will def. look into getting a custom box for my sub which i am currently still open for suggestions to!! and also will make sure that i keep the bass boast at zero...unless what if i was to get a more powerful sub that could handle the the raise of the bass boast (the RMS increase) from my sub.. ?
DON'T use the bass boost, it's as simple as that.
Ok let me find a work around. I want a sub that rattles my eardrums and makes my body vibrate while being able to hear me coming from a  block away
must be truconcepts again.....
Ok let me find a work around. I want a sub able to hear me coming from a block away
Yay, another one who has no regaurd for the law, hasn't been taught the moral about having respect for others around him. I give you two big thumbs up.
  • Recently Browsing   0 members
    1. Recent Topics
        • 1 comment
        • 46 views
        • 1 comment
        • 36 views
        • 1 comment
        • 42 views
      1. Box for 1 15" SSA ICON
        • 3 comments
        • 892 views
        • 8 comments
        • 1,815 views
        • 1 comment
        • 79 views
  • Similar Content
    • By Wolfram Audio
      Now available on the SSA store!
      I do NOT check PMs on here. For any questions, email [email protected]
      Wolfram Audio W-3000.1:
      RMS Power @ 1 Ohm : 3,000 Watts x 1 Channels (14.4v) RMS Power @ 2 Ohms : 2,000 Watts x 1 Channels (14.4v) RMS Power @ 4 Ohms : 1,150 Watts x 1 Channels (14.4v) RMS Power @ 2 Ohms (Linked) :  6,500 Watts x 1 Channel (14.4v) Frequency Response : 10hz~350hz (+/-1db) Working Voltage : 10V-16V Signal-to-Noise Ratio (Sensitivity) : >90dB Efficiency @ 4 Ohms : 86% Low Level Input (Gain) : 8V - 200mV Low Pass Filter : 30Hz - 250Hz Bass Boost : 0 ~ 12 dB Subsonic Filter : 10Hz - 60Hz Phase Shift : 0-180 Degrees 4-Way Protection Circuitry Built-in (Thermal, Voltage, Speaker, DC) LED Power & Protection Indicators Master / Slave (Linkable) : Yes Recommended Fuse Rating : 300 Amps 1/0 Gauge Power and Ground Terminal Inputs Remote Level Control Knob Included
      Wolfram Audio W-1500.1:
      RMS Power @ 1 Ohm : 1,600 Watts x 1 Channels (14.4v) RMS Power @ 2 Ohms : 900 Watts x 1 Channels (14.4v) RMS Power @ 4 Ohms : 530 Watts x 1 Channels (14.4v) RMS Power @ 2 Ohms (Strapped) :  3,200 Watts x 1 Channel (14.4v) Frequency Response : 10Hz - 350Hz (+/- 1db) Working Voltage : 10V-16V Signal-to-Noise Ratio (Sensitivity) : >90dB Efficiency @ 4 Ohms : 86% RCA Line Output : Yes Low Pass Filter : 30Hz - 250Hz Bass Boost @ 45 Hz : 0 ~ 12 dB Subsonic Filter : 10Hz - 60Hz Phase Shift : 0-180 Degrees 4-Way Protection Circuitry Built-in (Thermal, Voltage, Speaker, DC) LED Power & Protection Indicators Master / Slave (Linkable) : Yes Fuse Rating : 150 Amps (Linked: 300A) 1/0 Gauge Power and Ground Terminal Inputs Remote Level Control Knob Included
      Wolfram Audio W-600.1:
      RMS Power @ 1 Ohm : 700 Watts x 1 Channels (14.4v) RMS Power @ 2 Ohms : 380 Watts x 1 Channels (14.4v) RMS Power @ 4 Ohms : 200 Watts x 1 Channels (14.4v) RMS Power @ 2 Ohms (Strapped) : 1,400 Watts x 1 Channel (14.4v) Frequency Response : 10Hz - 350Hz (+/- 1db) Working Voltage : 10V-16V Signal-to-Noise Ratio (Sensitivity) : >90dB Efficiency @ 4 Ohms : 86% RCA Line Output : Yes Low Pass Filter : 30Hz - 250Hz Bass Boost : 0 ~ 12 dB Subsonic Filter @ 24 dB Slope : 10Hz - 60Hz Phase Shift : 0-180 Degrees 4-Way Protection Circuitry Built-in (Thermal, Voltage, Speaker, DC) LED Power & Protection Indicators Master / Slave (Strappable) : Yes Fuse Rating : 30A x2 4 Gauge Power and Ground Terminal Inputs Remote Level Control Knob Included
      Wolfram Audio W-125.4:
      RMS Power @ 2 Ohms : 175 Watts x 4 Channels (14.4v) RMS Power @ 4 Ohms : 125 Watts x 4 Channels (14.4v) RMS Power @ 4 Ohms (Bridged) : 330 Watts x 2 (14.4v) Frequency Response: 15hz to 35khz Low Level Input Adjustment: 0.2v to 8v Signal to noise Ratio: >90 dB Minimum Impedance: 2 Ohm Low Pass Filter: 50hz to 500hz (500hz to 5khz [x10]) High Pass Filter: 50hz to 500hz (500hz to 5khz [x10]) T.H.D. Continuous @ 4ohm : 0.05% Operating Voltage : 10v ~ 16V Fuse Rating : 40A x2
    • By Godsmack
      - 27 Raptor 1/0 AWG Ring Terminals $20
      - Install Edge 5 pack remote wires [IEC P 3x5-6] 6 feet $15
       - 2 packs Install Edge 6.6 ft RCA cables [IRC GAC2] $7 each or $10 for both
       - 8 4 way Knu Konceptz 1/0AWG in 4 8AWG out $8 each or all for $55
       - 50ft 16AWG speaker cable spool $5
      - Install Edge Remote wire [IEC P18 X5-6] 18AWG $5
      - Knu Konceptz kolossus Flex 1/0 AWG Red power cable 44 ft $125; 8ft $25; 10.5ft $35 (all for 175)
       - 13 ft Q power 1/0 AWG Super Flex on spool $25; 15ft on spool $30
      - Approx 400 ft 16AWG Q power speaker wire on spool $40
       - Stinger 150 amp circuit breaker $25
      - 6 Install Edge Speaker Savers [IEC CAP 133] $6 per pack or all 6 pairs for $30
       - 2 2packs Rockford Fosgate 8AWG Ring Terminals $5 each or both for $7.50 -
       2 Rockford Fosgate Side mount battery terminals $9 each or both for $15 -
       Rockford Fosgate 2 output top mount battery terminal $10
      - Rockford Fosgate RCA coupler $5
      - Rockford Fosgate 10 AWG Amp kit (no RCA wires) 17 ft $30
       - Rockford Fosgate pack of 2 100amp MAXI fuses $10
       - Knu Konceptz Negative top mount terminal $10 -
      Metra Honda Harness [BB-WHHDI] $10 -
       Metra Inpala/Monte Carlo [XSVI-2105] $35 - Metra GM 88-05 22 pin harness [70-1858] $5
      - Pair of Dynex square box terminal cups $2
       - Dynex OEM Ford Radio removal tools $8
      - Stinger Blue HPM voltage meter [SVMB] $15
      - Tsunami Marine ANL fused distro, 1/0 AWG IN, 2 1/0AWG out $20
       - Generic ANL fuse holder, no cover $5 -
       Mini RCA stereo Y cable $2 - 14ft Raptor RCA cable $10
      - 16 ft Monster RCA cable $20 -
       Stinger 1/0 AWG ring terminal $4 -
       2 2male 1female RCA adapter $5 each or both for $7.50
      - 1 RCA to RCA dual male wire 9" $2 -
       2 Street wires RCA cables in bags 19.69 ft [ZN1260] $7.50 each or both for $10 -
       ANL fuses, 2 200amp, 4 250 amp, 2 300 amp, 4 100 amp, 2 500 amp. 500 amp are $5 per pair others are $3 per pair, or all for $30
      Total price when purchased individually: $761 Buy the whole lot: $650
      Open to trades, Nikon FX lenses and other photography equipment are of special interest. Feel free to contact with questions. Thanks for looking!!
      - Viper 500.4, missing xo cover, and right mounting feet. $300
      - MTX Road Thunder XO's for componants. $20 for the pair
      - Eclipse SC-8355/8365 XO's for componants $50 for the paid
      - Phoenix Gold Octane 4.0 2 amp. $150
      - JL Audio 500/1. Missing some side screws. Not 100% on what the guts condition is, and last I remember looking it was fine. $125
      - Digital Designs DD C1. $140
      ORIGINAL RE XXX 12" to come, as well as more amps. I'd love to sell everything as a lot, and am willing to make deals. Only thing trade wise I would be after is Nikon FX lenses, but feel free to offer up. Pics are all on the link below.
    • By matj1990
      So looking for some info about amplifier and efficiency.
      I have a xcon dual 1ohm 10"  so i can run at either .5ohm or 2ohm What i would like to know is  1500w @ .5ohm or 1500w @ 2ohm the 2ohm amplifier would be drawing more power to make its wattage because of the higher resistance correct ?
    • By GarrettHarvey
      Getting two hds212s and wanna know what amp to get(sq brand) , and if i should get dual 2 ohm or dual 4 ohm. And if youve done this build, what are the box measures
  • Recent YouTube Posts
