Trent Hari
Kenwood vs Pioneer SQ and Ease of Use/ SQ setup
sweet, i just wondered, because my door panel really hugs the sheet metal, theres like a piece that cups the speaker, so all the sound is funneled out the grill.
What about those pre-made baffles i see for like 8 bucks? they look like they just bolt right in with the speakers. I apologize if that is a dumb idea, but it looks like they would be easy to install and inexpensive.
Edited by Trent Hari
If you're referring to the formed foam baffles, they're almost worthless. When it comes to the rings that can be bought, they're okay but still don't quite serve the purpose. The idea behind using the baffles is to give the speaker a very solid surface to mount to with much more mass to it than the plastic and sheet metal of the typical factory door speaker installation provides. The stiffer and heavier mounting location helps to minimize losses in output and helps to reduce issues with resonance since the extra mass lowers the resonant frequency of the panel.
Every teeny tiny little thing affects the sound that is reproduced by a speaker. Sure, plenty of it is determined by the speaker itself, but it's even more dependent on how it's installed and it's that installation which should not be skimped on both in effort and budget. An optimal installation for a cheap set of speakers can wipe the floor with a crappy installation for a very expensive (and considered great) set of speakers.
Well at least i didn't skimp on the speakers ;).  - again, i am on a budget temporaraly.
This is what i was looking at - http://www.sonicelectronix.com/item_9441_Metra-81-4300.html?utm_source=google&utm_medium=cpc&utm_campaign=productads&device=c&network=g&matchtype=&gclid=CIenx9e9r7cCFUlxQgodjggAWA - It  looks like it gives the speaker a small sealed enclosure, instead of the whole door panel ( Which flexes enough to feel even with some dynamat) . and  if i wrap the baffle in dynamat , it would add a lot of mass. Would i get a benefit from that or would it hurt? ( i saw a review of possible overheating)
I would use that until i get a chance to build a proper baffle.
 If it is likely to be better if i just wait until i have a chance to do it right, i will. although, it will probably be several months because work is getting more busy, getting ready for the hay season.
Well at least i didn't skimp on the speakers wink.png.  - again, i am on a budget temporaraly.
Well that is very debatable, you did pick a speaker notorious for strong treble response (iirc type r components/coaxials come with metal tweeters which can be harsh).
But I would steer clear of the foam baffle, although it does dampen some of the back wave resonance; I have never had good luck with them.  The pockets are flexible, and in turn move with the speaker.  I would focus on adding weight (sound deadening) the inner door panel, or using a mdf mounting ring between the speaker and the metal door panel, at the very least.
The weak midbass your are referring to, immediately makes me think of the fact that the type-r's don't have a particularly efficient midbass, every experience I have ever had with them has involved some sense of lacking.
You could possibly cross the subwoofer over slightly higher, to help reinforce that ~80-150 hz range.  Also your tweeters could be crossed over at too high of a frequency or too steep of a curve.  This could be solved by going active and removing the type-r crossovers.  There is plenty of information here on going active.  It is another option that will give you so much more flexibility and control over your speakers.
Okay I knew that the type rs were a little weak in midrange,but when I mentioned that, I was told it was the installation. I think it may be a little of both.
I finally got some pics of my install, I'll upload them later when I get back from work. Maybe that will clear some stuff up
For now, I may not be able to go active yet due to limitations from my current Head unit.
 I  have a video of the sound taken with my new GS4 , it is a pretty accurate reproduction with just a little mic distortion, not much. It should give you guys an idea of how it sounds. and i also have a few pics of my speaker install, but im not sure how to post them, as my upload limit is full. Ill try Picassa
^^^Stock location
Baffles ^^^
^^^Screwed right into the factory holes
Mount speaker^^^
20130417_203425_zps52605ae9.jpg^^^Replace door panel
20130417_203508_zps05e4d141.jpg ^^^You would never know I was there
I put ebr between the panel and the baffle but you could use cld (dynamat) or whatever you have, even if you just use the baffle and no dampener you will hear a huge benefit. The baffles can be made for much cheaper than those pre made turds and yield infinitely better results. Keep in mind that keeping your speakers behind the panel is NOT ideal, but if you are like me and on a budget and not wanting to modify too much this is an easy way to get much more from your setup
That looks like it would work for me. Are those prefabbed? If so, where did you get those?
I notice that they do not do anything for behind the speakers. does it matter how large the enclosure (door panel) for the speaker is?
I looked at my install, and they do have one of those plastic rings around the speaker, along with a bracket.
looks like he made those
Heres a pic of my speaker install, and the door panel that goes around the speaker
and heres a link to the video that may work - It was recorded with my Galaxy S4. when i replayed it through bluetooth, it sounded very similar to the what it origionally sounded like. sorry if its not the best, i took it after working 7 hours on truck tires and I was pretty tired:/
https://picasaweb.google.com/lh/photo/uGyFXlH8YaNvLk4JCxYmsM8DDe7NDed5l14vuqIhEUA?feat=directlink
Where's the Dynamat?  I'm not seeing the whole picture I'm sure, but all I see is the factory plastic vapor layer.
You might have to trim the plastic ring that fits up to the speaker from the door panel a bit, but you can definitely benefit from a simple wood baffle.  Being bolted almost directly to the metal like that without anything on or around the speaker is far from the right way to do it.
I edited my post take a look at the video and let me know what you think.
the dynamat is retardedly on the exterior panel, i put it there to minimize noise from the traffic, and also i didn't want to have problems re installing the interior panel.(and i didn't have a clue what i was doing)  I put a little, not much, on the backside of the metal that the speaker is bolted to.
Heres the video again. Recorded with a GS4. its pretty close to how it sounded (Not quite as clear tho)
https://plus.google.com/photos/103700741015793191801/albums/5676924047589319649/5881871955783496610?banner=pwa&gpsrc=pwrd1&authkey=CICE1ve94fOJDQ&pid=5881871955783496610&oid=103700741015793191801
Im going to build a baffle soon
Damn, file won't play on that site and it's 251MB to download, too much for my slow internet connection to do right now, lol.
A little is better than nothing and depending on how much you put on there it may still be fine.  25% coverage is about the best amount of coverage to use since more than that is generally a waste.  A full treatment (including CCF and MLV) would help more than you can imagine.  Hell just the CCF in the Jimmy made a world of difference.
Did you try again with the new link?
( I did a new link- here https://plus.google.com/photos/103700741015793191801/albums/5676924047589319649/5881871955783496610?banner=pwa&gpsrc=pwrd1&authkey=CICE1ve94fOJDQ&pid=5881871955783496610&oid=103700741015793191801
Yeah i may be shopping for a set of mids sometime wink.png. Know of any good ones? jk thats a bad question, ill just look. Know of any that are Made in america?
What no comment on the video? How is that for SQ ?
anyway, im working on some baffles, do these look like they would work?
Heres a pic of inside the door panel
Heres a pic of my shop
Why would you ever pay for anything with tools like that?   HPDE makes nice baffle material.  Sure beats sealing the mdf.
Okay ill start cutting it out.
Does that video work for anyone? i want to upload another one sometime, but im not sure how to do it.
Any comments on the SQ would be good.
Im almost done, I haven't tested for fit yet though. should i bolt or screw it to the door?
Any tips? i dont really know what im doing lol
That is not possible.
Trace the stock plastic speaker mounting baffle onto the ones you have made and screw them to the factory holes. That is the easiest way with as little mod as possible.  The dynamat behind the speaker is good and if you have any left put it between the panel and the baffle.
X2 on sean's comment about your shop.  I would kill for access to a work space like that! Good luck with the install. Trial and error will teach you more than anything else. couple the experience with the advice given here and your install and your ears will thank you
I could only get one side done tonight, tell me what you guys think!  The only problem i see now is the speaker isn't perfectly in line with the grill. let me know if that's a problem.
Looks pretty good man!
Not bad at all sir. I don't think the not quite perfect alignment will be an issue unless the speaker is hitting the door panel. Looks good
  • Recently Browsing   0 members
    1. Recent Topics
        • 7 comments
        • 270 views
        • 1 comment
        • 269 views
        • 1 comment
        • 105 views
        • 1 comment
        • 97 views
      1. Box for 1 15" SSA ICON
        • 3 comments
        • 952 views
        • 8 comments
        • 1,870 views
  • Similar Content
    • By Second Skin
      The awesome guys at Colorado Car Audio just finished a sweet Dodge Ram 3500 Pro Master Van build with full sound and heat insulation along with a stereo upgrade and the work is very nice!!!
      They applied Spectrum and Damplifier Pro CLD to all of the metal to kill vibration noise and help with heat transfer through the metal. They used Luxury Liner Pro MLV+CCF next to block out unwanted airborne noise and thermally insulate the walls. And they used Mega Zorbe Hydrophobic Melamine Foam to absorb sound and thermally insulate the roof of this huge van!!!
      When the proper layers are applied to the correct locations, a huge difference in noise level reduction can be achieved. Setting the stage for a nice and clean platform for your stereo to perform in a much more enjoyable environment....especially with these tin can sprinter vans....treating them makes a HUGE difference in noise comfort levels.
      Thank you guys for the awesome work and pictures. Thank you for insisting on high-quality Second Skin products for all of your builds. #TeamSecondSkin #SecondSkinUSA #SecondSkinAudio #SecondSkinForTheWin
      Spectrum Liquid Sound Deadening
      Luxury Liner Pro Mass Loaded Vinyl with Closed Cell Foam infused
      Mega Zorbe Standard Hydrophbic Melamine Foam
      Damplifier Pro
      New Kenwood Touch Screen Head Unit
      Upgraded Stereo System
    • By Shogen
      Parting with my beloved 80PRS .... Don't really want to see her go but I'm not one to waste amazing hardware
      SOLD
       PayPal verified only ...
      Unit is in great condition. Comes with bluetooth mic and TA mic. Also has wiring harness and remote plus faceplate case
      Photos below (sorry if not great but taken with iphone 7 plus aka my next listing)
    • By Shogen
      Like the title says.... Getting rid of this bad boy, has all accessories (even the GPS antenna) except USB wire which you can pick up any where (USB extension cable).... I will let this go for $675 shipped....
      Price:  $675
      PAYPAL ONLY
      Shipping within continental US only
      ***MODs I took photo last night but had issues getting onto the PC hope yesterday date ok***
      Buy with confidence, long time member of the community...
    • By Thomas Iturraran
      Vehicle : 1973 VW Beetle
      Location in the vehicle: Rear cargo area; sub pointed up
      Space available (Length x Width x Height): 35" length x 12" depth x 12-15" height
      Subwoofer make and model: Fi SSD
      Subwoofer Size: 10
      Number of Subwoofers: 1
      Type of Port (Kerfed, Slot, Aero, etc.): Rectangle w/ 45's
      What type of music do you like?: EDM, RAP, Rock,
      Is your goal SPL or Everyday Music?: Everyday high sq
      Tuning Freq (Hz): 35 - 38hz?
      Volume : 1 - 1.5?
      Questions:
      So I have modeled up a few different enclosure in win isd but I just want some confirmation as to what you guys think will work best for my listening needs. From what I have read on this forum that I believe Fi recommends a tuning between 31-35hz and 1.5 cu ft. Modeled the box up they suggest and some of the numbers in win isd don't seem to comply with recommendations I find online, for ex. port velocity seems way too high ~ 130ft/s and output seems to lack around the 40-50hz region. From what I understand it seems as though when designing a box in a small vehicle such as my VW you can go a little bit higher due to cabin gain if I understand correctly. After modeling it seems as though 1-1.25 cu ft and a tuning of 38hz seems to produce a nice curve that also had minimal group delay and won't produce a ridiculous peak in output. My question is are there any other suggestion as to maybe more box volume or less and will there be any unforeseen issues with tuning to 38hz instead of 35? Also can someone give me any insight on how tuning affects subs ability to play in the 60-100 hz region? If I understand correctly tuning lower limits the sub woofers ability to play the higher notes?
  • Recent YouTube Posts
