nem
Team SSA 2012 Toyota Camry SE limited
Going to boost the bass a little.
Thanks Chop. :)
Couldn't you go from the hu to the speaker level inputs on the amp?
I was going to add rca's to the headunit, but these JBL greenedge units are digitally encrypted (no analog signal). My only option is to go this route unless I want to replace everything. The shop I bought the amp at just finished one up in a camry with the same factory system and they were telling me about it. I smiled and said yep I am getting ready to do the same thing because of that.
Sorry I misunderstood your question the first time.
I have to use the output of the jbl amp to get an analog signal which is 100 watts so they claim. I think that might be a little too much for high level input to filter without inducing noise. I would rather be safe than have a noise issue.
Makes sense.
Car manufacturers make it a pain when it comes to audio add-ons.
Honda's and acura's are the most user friendly.
You get a flat signal straight from the headunit.
Edited by eggyhustles
Makes sense.
I had called and talked to a tech at jbl and that is how I found that out. There are systems that you can use, they just cost too much currently. Back in the old days we just tore the factory headunits apart and solidered rca cables on the input side of the headunit amp.
Install completed. Man these new cars with the push button system are something. Finally found an accessory for the remote. Hits a little to hard for the wife so I turned the gain down a little.
Line level converter hidden nicely.
Nice work sir! :)
Thank you Aaron.
New skins for the Camry have arrived!
What are the specs?
Do these keep it grounded to the ground?
Lets hope, the wife drives almost like Aaron.
nice! Toyotas are awesome cars... Thinking about getting the same as your wife or jumping down in size to the 2013 Corolla... not sure yet, you know trunk space and all... lol
It is not a bad car, but I try not to let things go and do them before needed.
She did happen to see there is a TRD bolt on supercharger for it and now thinks she needs that. I just laugh it off.
That's no laughing matter, she needs it. ;)
Like I need to pay higher insurance and speeding tickets?
Bad enough she will cruise at 110 mph and say you can hardly notice you are going that fast!
Put a speed limiter setting in the ECU. haha
  • Recently Browsing   0 members
    1. Recent Topics
        • 7 comments
        • 266 views
        • 1 comment
        • 256 views
        • 1 comment
        • 102 views
        • 1 comment
        • 94 views
      1. Box for 1 15" SSA ICON
        • 3 comments
        • 949 views
        • 8 comments
        • 1,864 views
  • Similar Content
    • By spanky1975
      I am thinking about building a T-line for my 3 SSA DCON 12's. Has anybody here tried it or have any experience with T-lines?
      If anybody wants to give a shot at helping with the design it would be great.
      Before you comment that "The box will be huge!" , yes I know. Thanks.
    • By altoncustomtech
      Okay, we were finally able to get the vehicle that will be replacing the van as our daily driver.  I found a nice 2010 Traverse AWD with everything the wife wanted in it and a little more with decent miles on it and I even got a decent deal on it.  Now, the wife realized before we even got serious about shopping for one that we should probably tone down the size of the install in the new vehicle.  While she was/is still wanting some good sounding speakers and some bump going to the the size and extent of the build in the van was more than we need for this one.  One of the biggest reasons for that was simply because of the damage the Q's caused the van.  Before I installed them it was QUIET, not one interior panel rattled or made noise, not hardly a hint of sheet metal rattling could be heard.  At this point now not only is there a great deal of noise coming from the interior panels (particularly in the rear) but the Q's even managed to tear a spot welded seam in the floor of the van loose.  We simply don't want to repeat that in the new one.
      For this build we're looking at something smaller, possibly along the lines of a pair of 10's if the space is right, single 12, etc.  Something like the DCON, GCON or ICON come to mind, SSD's, possibly even IA or something else I've not got a chance to try yet as well.  We'll be running 1,000 to 1,500 watts on the subs and no more than that at all.  What goes in will depend completely upon the space available and which sub choice will work best with that space.  I'm going to try to keep the rear of the vehicle as usable as possible so I'm probably going to be building an enclosure with the subs firing downward and the port to the side.  The enclosure will likely consume all the space available on the width and depth behind the 3rd row seat and my limiting factor will be that we're trying to keep the enclosure height to about half the total height of the 3rd row seat.
      The wife wants another Kenwood HU so we'll likely be ordering a DDX491HD and a Maestro RR integration unit this weekend for the source and to keep all the factory wheel functions and such.  I'm looking to use a PPI P900.4 for the highs and a similarly sized subwoofer amp to run the subs and those will be tucked away in the storage compartment under the floor in the rear with added ventilation if necessary.
      That brings me to my biggest frustration with this build, lol.  Before we got serious about shopping for a vehicle the wife was COMPLETELY on board for me doing whatever was necessary to install the Bravox 603's.  Fiberglassed custom door panels were in the plans for whatever that vehicle was going to be, uh, well, right up until we picked up the Travy.  Now it's, "You aren't really going to cut it up and put holes in the doors are you?"    and "There's already places for tweeters, you can just use those right?"  then finally "You can just use the factory places for now, I want it to have a good sounding stereo but not know it until you hear it, as in can't see nothin'."
      So, there goes anything remotely close to what I was wanting to do.  I thought if the Bravox's wouldn't work out I might do a dedicated full range/midbass setup, or maybe even the equivalent of the Arc Audio Black 6.2 speakers in the SB Acoustic's mid and tweeter that Arc is using, or something really and truly worth a damn to do.  Nope.  She gave me a pretty much open budget for speakers but I don't see the point in spending any kind of good money on a set of components that cannot be optimally installed.  So I'm not completely sure where I'm going to go with the highs.  I have found a hell of a deal (<$250)on a new set of Kicker QS65.2 components which I'm leaning toward but I have to verify if there's any possibility of getting that tweeter behind the A pillar.  I've also looked at the MB Quart QC216 set which has a nice looking large format tweeter but since Maxxsonics has their nasty hands in MBQ now I'm kind of shying away from them as well.  As soon as I can figure out what the hell to do (still need to verify some measurements) I'll pull the trigger on equipment and get it coming.
      Although the Travy is pretty quiet from the factory I'm still going to be ordering some SDS to treat the doors and all of the rear to start with.  I'll work on the floor and roof after we've had it a little while.  It has the sun roofs so I'm not in a real hurry to tear all that interior off the roof, nor am I in a hurry to figure out how to tear all the seats, center console, and carpeting out to treat those areas just yet.  I also have to pull the door panels off to see what kind of baffles I'll need to construct for it.  Luckily with the lower power I'm looking at running and the 170A factory alternator I shouldn't be looking at having to do anything too major on the electrical side of things.  Probably just the BIG 3 in 1/0 with Knu Kolossus.
      So, that's the, um, kind of the plan, for what little plan there is.  The more I can verify as far as fit in this thing the better the direction for what/where it will go is going to look.  I hope to have all that figured out and to be ordering equipment and supplies this weekend.
      Here's a quick shot of the Travy.  I just grabbed it to show to a co-worker.
      Any input is welcome, especially from anyone who's done some install work in one of these as the entire Lambda platform is completely new to me.
    • By spanky1975
      I was on the forums awhile ago and got some great help designing a box from a member (can't remember who). Just wanted to show what he helped me do.
      I have 3 SSA DCON 12's in a 1999 Chevy Tahoe. I just metered on a TermLab and the results were great. I have had this system in for over a year and this is the first time I have had it metered. Thanks again for the help
      from the build...
      http://i1241.photobucket.com/albums/gg506/eddielong1975/376572_532111330147364_1694144002_n_zpsfdfeacd5.jpg
      http://i1241.photobucket.com/albums/gg506/eddielong1975/218079_532113020147195_1480755921_n_zps062b6a97.jpg
      http://i1241.photobucket.com/albums/gg506/eddielong1975/DSCF1556_zpsc40ae279.jpg
      http://i1241.photobucket.com/albums/gg506/eddielong1975/DSCF1555_zps13de709b.jpg
      http://i1241.photobucket.com/albums/gg506/eddielong1975/DSCF1552_zpsae1bfbf1.jpg
      TermLab results
      http://i1241.photobucket.com/albums/gg506/eddielong1975/20140403_182653_zps901abed9.jpg
      From the port
      http://i1241.photobucket.com/albums/gg506/eddielong1975/20140403_191109_zpse462b10c.jpg
      Up for sale is a used when I bought it single 4 ohm 15" SSA DCON sub.  It's in great condition showing the usual signs of having been mounted before.  I bought this from Sean (W140) awhile back with no real intentions except that it was a good price at the time.  I'm getting nickeled and dimed to death at the moment so I need it sold.
      $120 shipped to anywhere in the CONUS.
  • Recent YouTube Posts
