Garrett Tait
stereo install question (ground wire)
this is my first stereo install and im a little confused. i see that the harness that plugs into the stereo has a longer black ground wire. my adapter harness has a black wire for a ground wire to attach. ive heard that youre supposto ground the stereo to the metal inside the dash. will it be okay leaving the ground wire on the harness that plugs into the factory plug left un touched. will everything function properly?
should i NOT solder them but instead ground it in the dash?
also the p connect is for the remote wire right?
If the factory ground is good not really a reason to run a separate one unless you encounter a ground loop (alternator AC component that is audible due to different ground potential between equipment).
Using the factory headunit ground will work fine, unless your car is super old
okay great! i'll solder it right now. i have one more question tho,
the blue w/ white stripe is for my remote wire. can anyone confirm?
Every stereo ive touched blue with white strip is remote wire
Also by looking at your picture you have the little blue tag P.Cont "power control"
Edited by douglas12107
looks good man, nice touch with the zip ties....cleans it up real nice
thanks, this is how it ended up looking
too bad my buddy didnt tell me he had the upgraded jbl system so i got the wrong harness adapter. he has a 20 pin instead of 2 separate plugs -___-
Edited by gt58
