Shortening Serpentine Belt?
By
DanP, in Automotive and Performance
Recently Browsing 0 members
Recent Topics
- 7 comments
- 331 views
- 1 comment
- 405 views
- 1 comment
- 161 views
- 1 comment
- 148 views
- 3 comments
- 1,006 views
- 8 comments
- 1,920 views
Similar Content
By afearlesshunter
Alrighty, 2001 honda civic sedan ES1. Singer 320 Amp alternator. Came with a black bracket for the bottom and a spacer for the top. Was suggested to get a smaller belt by other people but it won't even go on with the factory size belt. Bottom brackets do not line up at all. Don't really know what to do. Pics
Alt with black bottom mounting bracket
Alt mounted on top with belt on.
Where the black bracket provided does not come close to fitting with the factory adjustable bracket.
By cloud77
I have an '04 Pontiac GP. Looking to buy a H/O alternator 200+ amp capabilities. Mechman, DC, singer, Excessive Amperage, exc.
Let me know what you have and your price if you want to sell!
By 808kikdrum
I'll start with the electrical rundown- EA 220 amp alt., big 3 in 0ga, xs d2400 under hood, deka 100ah g31 agm in trunk, 1 pos. run 0ga between batts, all cable is ofc. Now for the questions, first the alt- i was told that the bolts holding the alt in place are all the ground you need but i feel like i should have a 0ga ground also. good idea? unnecessary? Now for some fusing-how should my pos. between batts be fused? i have an aq3500d.1 about to go in, do i need to fuse for its 400 amp rating?,fuse for the max current capacity of the cable at 15-20ft?, fuse for the max amt of amps that my alt and front batt can deliver? Are there any performance differences in anl vs. the multiple midi mini fuses? Now for the cable- how beneficial is a run/s of neg. between batts? Is it necessary to do a 2nd run of pos.? Seems to me the one run should be more than adequate to carry all the current the alt+front batt can give to the back batt/amps but i have certainly been wrong before. Thanks in advance for any and all help, to those tempted to tell me that u never fuse and its not necessary u can save both our time and not post, thx.
Recent YouTube Posts
