spare69
Amplifier in protection HELP ASAP
The picture quality is too poor to see anything.
also, short out the caps and see if that fixes the problem.
i said this on page one
i copied out the brz manual
sorry 2 see it didn't work
Db-r is a repair place. I think they do other amps other than sundown, incriminator an RD.
if u want the power you was getting from running at .5ohm
then u should look into a big amp that can do that kind of output safely
yea i know i apoligize for not quoting you budd
well im going to get a quote from DB-r and see what they say. Hopefully good news of something easy and affordable.... I appreciate everyones help!
Try ARC .
Amplifier not fused running at .5 ohm daily? Full tilt on a stock alternator? I am going to assume your voltage dipped well below 13.5 full tilt and did cause permanent damage to your amp. If it doesn't make sense, it's not true. What your amplifier has went through would be like you running in a hot sauna without a break. You would die too.
I put it at full tilt with my voltage meter on it....multiple times, 2 different meters....read the same thing.......Im not a dumbass who thinks he can put that much power on a stock system......im just stating what ive personally seen and wittnessed with my car....
I wasn't insinuating that you are a dumbass. I'm just stating that your amp is wore out man. Hope you get it resolved. Good luck.
Here are some better pics of the board. i was quoted $120 to fix....thinking itd be better to just buy a new one for $200....PIC00004-1.jpgPIC00005-1.jpgPIC00006-1.jpg
If anybody sees a Hifonics BRZ 1700.1 for sale, used or a good price let me know!
The new Brz line is already out, my buddy runs a 2400d. I would say try something different like Crescendo BC2k or AQ2200d.
where can i buy online?
dayummmm, i like that! Think i should sell my working BRZ 1700 and get one of these? (the Hifonics)
Edited by spare69
My recommendation is crescendo been so from the start crescendo 3kwp
im guessing OP does not have the budget for those amps
You are correct sir!
nahh if u have a working brz1700 stick with it
the difference in the new models is a couple upgraded parts and the lights
nothing to make a real big difference
