Followers
0
Weird Sine Wave from Amp, please help!!!
By
mikebingham34, in Amplifiers / Head Units / Processors / Electrical
Recently Browsing 0 members
Recent Topics
- 7 comments
- 352 views
- 1 comment
- 447 views
- 1 comment
- 175 views
- 1 comment
- 154 views
- 3 comments
- 1,016 views
- 8 comments
- 1,932 views
Similar Content
By Ryann627
Thanks in advance guys.
By 121gigawatts
I just bought a zv5 15 thinking it was dual 2 ohm and it’s dual 1 ohm. I have a few questions. First, can it be recone to dual 2? Because I read some motors are only configured to function on the original impedance. Idk. And if I can’t get it recone, can I run that amp at .5 ohm unclipped on that zv5 and not overpower it? Should I run it at 2 ohms? I hope it can be reconed to dual 2. In need of help. Thank u.
By Nick88gm
Hey guys, I'm new here but been messing around with audio in my cars on an amateur level for quite a while. I recently decided to do an amp/sub install on my newly acquired 2006 Infiniti M45. It has a factory 14 speaker BOSE system. As far as the audio upgrades I've added is as follows.
-Sundown Audio SCV3000d amp
-1 Sundown Audio X12 @ 1ohm in ported box to spec
-0 gauge wiring ran to trunk to additional audio battery and capacitor
-6 gauge wiring from amp to sub
-LOC taped into the stock Bose sub inputs
Problem is that the sub doesn't sound nearly as loud as it should although the sound it does produce is very clear. I went from 2 SA12's in my last car with a 1500 watt amp and was impressed so I decided to upgrade power and sub to the X12. I also noticed that the amp is clipping anytime I turn the bass boost over 1/3 on the remote dial which also has the clipping LED indicator. The gain on the amp is maybe in the 10 o'clock position and I'm really just wondering if it's maybe the signal from the Bose amp that is causing this and/or if there is a better location to tap into for the bass signal.
By Travis
https://drive.google.com/file/d/1vLS1CNXDIP4PU7HHWnsw0193fRfQ9-sZ/view?usp=drivesdk my "new" 2003 s10 blazer 2wd. 75k miles. Zero rust. From out west (I'm in Ohio lol) going to order my singer alt tomorrow. Either a 370 or 390. Then the fun begins!
Recent YouTube Posts
