Looking for a bit of advice on purchasing a new amp/amps.
Ill be running a pair of D2 crossfire XSV2 15s tuned around 30hz.
My dilemma is whether I would get more out of (ie more power, less rise):
A pair of 2.5k amps (probably Skar 2500), bridged and wired to 1ohm each
OR
A single 5k amp run at .5ohm
Electrical is:
2 runs 1/0 OFC (one is knu, other is memphis) and 1/0 Big 3
Kinetic HC2400 up front
3 deka group 34 AGMs in the back (55ah a piece, 750cca)
270a-320a altenator (will be added after amps)
Thanks in advance for any help!
Edited by sexterra
The box will have to do with rise and not an amplifier, so that is not gonna get answered. I rather do one big amp but most people like strapping, it will come down to personal preference really.
The
Thats true, but the starting impedance will have to do with rise...
The box will be the same regardless of which route.
so im pretty sure i would rise to a lower load after rise if i ran a single amp at .5ohms than ran 2 amps at 1ohm each.
^is that correct?
Edited by sexterra
The
^is that correct?
Even so, I don't think there would be much of an audible difference if any at all.
Go on which is cheaper
Wouldn't both at 1 ohm be more efficient than the 5k at .5 ohms?
I can get either 2 skar 2.5k's or a nendo 5.5k for about the same price. So i guess its down to which id rather have.
I honestly dont know, thats part of my dilemma. I guess it comes down to which one will be nicer on my electrical
Rob from dc did testing on strapping 2 smaller vs 1 bigger amp and he got better results from the 1 bigger amp. That and I would take the Cendo over the skars anyday.
I would go 2 amps because if you are going to daily @ .5 ohms, i can imagine it wouldnt sound quite as good than if it was 1 ohm. im basing that off of the fact that the higher the impedance  typically means better SQ
I would run the Crescendo at .5 all day over running 2 Skar amps.
Is this for competition or strictly for street beating?
Just run the single amp, have to match everything on the two amps, and after rising and such none of it will ever be .5 ohms. Won't notice the difference in powers anyways.
single big amp. cendo
If you are strapping amps you don't need to match everything on both amps. You only need to set the master amp, just fyi.
Also, first post was a little unclear, each sub at 1ohm strapped would end up with a 2ohm nominal load, vs the .5 on single amp. Im thinking the two amps would be alot easier on my electrical and easier on the amps, but rise could be pretty bad.
Look into the flatline ba1. Serious 5k amp.
Id be interested, but theyre around 1500, that a decent bit more then what id be paying for my other options.
2 BC2000ds strapped
Id rather do the 3.5s strapped. Im looking into it.
Daily and demos. not in for numbers, just loud to the ear.
Learn something new everyday thank you sir.
I thought they were of the same brand. I would take the bc5500 over the skars.
If you had skars the amps would be at 1 ohm each.
Do you already have the subs? Is that why you need to have a final ohm load of .5 or 2? I'm not sure if you said it was for daily or not, but if it is, why not 2 bc2ks like R3dt34rz strapped? You won't hear a difference in output from the two amps strapped to the 1 bigger amp. Also the two bc2ks would be cheaper.
Stop worrying about impedance "rise".  The term as it's typically used is simply the impedance curve of the driver.....which you can't do anything about.
If this is for daily, why 5kw at all?  If you are really worried about "rise", you'd consider the fact that power compression is going to be very high at that level.
negative on same brand. Im pretty sure skars are chinese and crescendos are korean boards.
Right.
And yes, I have them already. Got them in a trade for me 05 re xxx + cash. pretty solid trade.
Id like a little more power than 2x2k on em, i had my aq2200d on one of em and it laughed at it. these bitches are STIFF
When I said same brand I meant comparing sundown amps or audioque or crescendo like comparing different amps from the same company.
You won't need 5.5k on them. You won't here a difference between 4k and 5.5k. It's kind of a waste if you want to spend more money.
Oh, wasnt sure which brands you were referring to.
And if i was going to go that route I already messed up by selling my AQ2200d haha. But I think I'll spend the money and get the 5.5k.
Yea it's your choice. At least your going to get a good amp though.
    1. Recent Topics
        • 7 comments
        • 254 views
        • 1 comment
        • 216 views
        • 1 comment
        • 92 views
        • 1 comment
        • 80 views
      1. Box for 1 15" SSA ICON
        • 3 comments
        • 938 views
        • 8 comments
        • 1,854 views
  • Similar Content
    • By ManzKea
      Hey guys manzkea back at it again! Lol. Finally got some equipment in. Excited to finally get this project I’ve had in mind for a while rolling . Gonna attempt a blow through in my single cab 2001 ford ranger long bed. Gonna make pods for the doors to house the 6.5s and replace the stock one with a 6.5 or if possible an 8” driver. All powered off the ssa ic150.4.  As for subs I’ll be using a 15” sp4 v2 I got from a friend for a deal. A taramps 5k will be used to push it.
      Unfortunately the evil mids I wanted was unavailable in 4ohms. So I went with these prvs.
      Well I’ll I’ll be updating this as I get it going. Possibly next week or so, really busy with work at the moment. Well here’s a pic of some goodies the mail man dropped off.  Cheee.
       Btw got something extra special in those two ssa looking boxes behind the ranger gear. But that’s on the back burner at the moment.
    • By BigDaddy13440
      Pretty much as the title implies.... I've got a 2004 Yukon XL, and I'm updating the entire system. Just replaced my alternator with a 253amp model from a 3500 series pickup (factory option! bolted right in!), will shortly be wiring up a second 1000cca battery. Dual 1/0 runs to the rear, fused at both ends. Currently only running (1) amp, and old Lightning Audio 1001.d @ 1 ohm, will be swapping that out, most likely to a Skar RP-1501.D. Two Powerbass S10-d (dual coil) subs in a 2.7-ish cu ft box built into the rear quarter panel. Tuning is way too low, probably about 24-25Hz. Factory speakers in the doors and rear pillars, will soon be changing them out - probably doing a pair of 6.5's in the front doors, a single 6.5 in the rear doors, and a pair of 10" Powerbass S-10's (single coil) sealed in the front portion of my center console as mid-bass, from 60-150Hz. Will plan on running the speakers and front S-10's on a five-channel amp, most likely Skar's AP-600.5.
      I've got nothing set in stone for the 6.5's, there are literally hundreds of options - but if anyone has some reasonably priced option, please offer suggestions. My biggest dilemma is figuring out what to put in the rear C-pillars. The factory fill is a 2" or 2 1/2", only about 3/4" deep. I'd like to go bigger, even if it's a 3 1/2" or 4". Would run them in parallel with the rear door speakers, dropping the load down to 2 ohms, the same as the front doors. Has anyone ever seen the C-pillars upgraded/enlarged? I found a pair of PPI Sedona series 4" two-ways, supposedly will handle 60 watts RMS, max of 200 watts. The Skar 5-channel is rated at 90x4 @ 2 ohms, so each would see a safe 45 watts.
      Thoughts/suggestions?
    • By antoinez28
      I have for sale two crescendo bc 2000 for sale both are about 1 1/2 years old good deal power by two g31 batt juciebox, and crescendo logic...pushing 2 18" ethos strapped at 2ohm never seen below 12volt...I had to push them....got warm in this hot Kansas City weather...both will come with bass noobs and one with owners books the other might be lost during a move with both boxes from crescendo...I love these things they both went to db-r for repair but nothing major I had a bad ground and thought I blew them both
      Crescendo BC2000D
      Stable down to .5ohm on strong electrical.
      Up to 16.8v capable on BC2000
      Remote Bass/Gain knob with Clipping Indicator.
      Custom tooled, proprietary Multi-piece Thermal optimized Heatsink with patent pending interlocking slide-out CNC engraved top plate.
      2 stage copper anodized removable top plate.
      Silver plated high end hard-wired Tiffany RCA inputs and oversized 1/0 Power/Ground Inputs for efficient current transfer.
      Overbuilt Power supply with heavy copper traces and Military spec PCB/heavy duty standoffs for extreme vibration resistance.
      Manufactured using some of the highest quality and most reliable electrical components, with many 3% tolerance components throughout.
      Full 4-Stage Intelligent protection Circuitry 1 Year/1ohm comprehensive warranty with 2 year/.5ohm optional extended warranty available.
      Rated Power Output(RMS)
      Clean RMS power on 13.8v standard electrical system:
      Ohm Load
      BC2000d
      1ohm
      2250
      2ohm
      1100
      4ohm
      700
      Dimensions: BC2000: 16"L x 2.75"H x 9.5"W (at widest point)
      I want 550.00 for the pair or 300.00 each shipped no lower
      I'm upgrading to a bigger amp dd-m4a
    • By antoinez28
      So I'm been on the web looking at different types of 5k amps that are linkable amps, so I can upgrade my current amp set up...I'm looking for a amp out of these new or used- dd m4a, sundown audio 4500, crescendo bc5500, dc audio 5k, ampere audio 5000.1. It has to be able to do around 3800-4000 wire down to 1.3ohms.
      Running 3-18s DSS ethos box is in the works....
      Electrical is dual alts stock will run the truck, mid, and highs the singer 270amp will run only for the battery bank. 4 juice box blackcherry battery back, two runs of 1/0 wielding wire.
      ( would like more batts if space would allow)
      ( playing music daily and burbs on comps)
      I'm not looking for a father and son conversation here just wanting to know which amp would be better suited for my set up that's all thanks for reading.
  • Recent YouTube Posts
