Recently Browsing 0 members
Recent Topics
- 7 comments
- 434 views
- 1 comment
- 594 views
- 1 comment
- 214 views
- 3 comments
- 1,083 views
- 8 comments
- 2,005 views
- 1 comment
- 164 views
Similar Content
By THX_Elite
Upgraded my 4 channel amp from the ZRX1000.4 to the BRX1200.4, what a beast! Still running the BRX 1600.1D. Here is a sexy night view
By mikebingham34
Hey everyone,
First off I wanna apologize for changing my mind so much. My financial situation has changed, so my future setup ideas have too. Even though I have not followed through with other plans ya'll have helped me with, I have learned a lot for each comment or post I read.
On to the enclosure idea. I will be getting a single SA-10 D2 as soon as my current setup sells. I will be running it off of a BRZ1200 @ 1 Ohm (for headroom). My goals are for it to be decently loud (I have had an E-12, hope to be comparable to that), and flat sounding for all music types... From dubstep to decaf to classic rock to country. It will be in my daily which is the trunk of a 2000 Honda Civic Sedan (DX EJ6, D16Y7 Auto). I am planning on building an enclosure that is 1.4 cubic feet, with a 17" long, 4" aeroport, tuned to 34.8 Hz.
My questions are as follows:
Is the box too large? I commonly see Jacob recommending 1-1.25 cubes for a ported SA-10.
Should I keep the 4" aero? It gives 9" of port per cube (high end of the spectrum for an aero)
Or go with a 3", or just go slot port... If I go slot, what kind of port area should I use?
Lastly, is that a good tuning? I would like an F3 around 28Hz.
Thank you for all your help, as always.
By splcharger
Hey guys I have a Fi BL 15" fully loaded woofer on the way. I will be building my box very soon here. I'm going to be running a Sundown 1500 D amp to it. I will listen mostly to low HZ rap or bass songs. I am looking for 32 HZ.
Few questions:
- Can someone give me some measurements for a ported box that is meant specifically for a BL 15" with 1500 RMS going to it?
- I have read that this sub woofer recommends a 3-5 cu ft box. Does leaning towards 5 cu ft box have any benefits in SPL?
-Any internal box bracing necessary with 3/4 " MDF wood?
- Any cotton material necessary inside the box?
Thank you
By trenthonda1
My setup is gonna be 1 Fi audio BL 15" dual 2 ohms. what should i tune my box to so i get maxim SPL!!!
Recent YouTube Posts
