spare69
Selling Power Acoustik 1.4000D 110 Shipped
I got a Power Acoustik 4000 watt MONO amp for sale. I got this from a friend and have no use for it. Im selling it for $110 shipped. Lemme know if you want it!!! PM ME!
  • RMS Power Rating:
    • 4 Ohms: 1200 Watts x 1 Channel
    • 2 Ohms: 1700 Watts x 1 Channel
    • 1 Ohms: 2200 Watts x 1 Channel
    [*]Max power output: 4000 watts x 1 channel
    [*]Input Sensitivity: 200mV-6V
    [*]THD %: 0.20%
    [*]Full regulated PWM MOSFET power supply
    [*]Three way protection circuitry
    [*]Front Panel Connections & Controls
    [*]Direct Input 4 ga. Power & 8 ga. Speaker Terminals
    [*]Top Panel Status Indicators
    [*]Jet Black Texture Coat Finish
    [*]Adjustable Tuned Bass EQ (0-18 dB Bass Boost)
    [*]Hi-Speed digital circuitry
    [*]Full selectable crossover (HI,Full,Low)
    [*]1-Ohm Stable Class D Monoblock
    [*]Die-cast aluminum heat sink designed for massive heat dissipation from three sides of the amplifier
    [*]Heavy duty aluminum alloy heatsink or High-density split-dome convection heat sink for extreme heat dissipation
    [*]Platinum-plated RCA level inputs
    [*]Platinum-plated screw terminals
    [*]Variable low-pass crossover filter: 40-200 Hz, 24 dB/octave
    [*]Variable subsonic crossover filter: 20-50 Hz
    [*]Variable subwoofer bass boost EQ @ 45 Hz
    [*]Phase Control: 180 degree
    [*]Remote Gain Control Included
    [*]Frequency response: 20-200 Hz
    [*]Signal to Noise Ratio: 100 dB
    [*]Fusing: (3) 40
    [*]Dimensions: 13.77" x 8.26" x 2.16"
Still for sale?
Still for sale?
Don't buy that !!!!!!!!!!!
housing looks like that of RF power units
They are real cheap amps.
Still for sale?
It might be best to PM him about this seeing how old the thread is.
Still for sale?
Please don't post dump in the mans thread.
It's sold. It was my old throw around amp I gave to him which he gave to his brother
FYI for 100 it's really not that bad if a amp stays cool and performs as a class d amp should
    1. Recent Topics
        • 1 comment
        • 46 views
        • 1 comment
        • 36 views
        • 1 comment
        • 42 views
      1. Box for 1 15" SSA ICON
        • 3 comments
        • 892 views
        • 8 comments
        • 1,815 views
        • 1 comment
        • 79 views
  • Similar Content
    • By Ryann627
      Thanks in advance guys.
    • By Aaron Clinton
      We have finally released our new amp.  It is a tiny tiny production run to see how people like them.  Meant for the high end, SQ market, without the European price tag.  If this model moves as well as I hope, it will help spawn another model in the line up soon.
      https://store.soundsolutionsaudio.com/ssa-dm150-2-2-channel-amplifier-150w-x-2-ch-or-500w-x-1-ch/
      Introducing the all new SSA DM150.2 amplifier. An old school approach, with updated components, for the most discerning of ears. If your front stage is lacking warmth and clarity, its time to upgrade. Our first amplifier in our high-end, sound quality, Class- A/B - Demon amplifier line. The SSA DM150.2 is the elite choice for that high end active front stage, premium passive components, and especially a sound quality sub (SSA Demon). We've incorporated direct inputs for those competition installs that use an external DSP and want their amp to be a pure gain block. Stellar looks to match the design and components. Don't let your speakers or your ears down, #levelup to the all new SSA DM150.2 amplifier.
      150 Watts RMS X 2 @ 4 Ohm 500 Watts RMS X 1 @ 4 Ohm Angled Terminals for show quality installations Full Complimentary low distortion Class AB design Tiffany Style RCA connectorsFull Complimentary low distortion Class AB design Butterworth Crossover Filters for premium level performance An extra pair of input connectors for a direct input that will bypass the crossover so the amp can act as a gain block The op amps featured are TI chips w/BB technology high performance audio grade IC's Docking Pads® to reduce vibration & extend the life the amplifier DC, Short Circuit, Thermal & Overload Protection, on board fusing Diagnostic LEDs Specifications
      OUTPUT POWER @ 14.4V input   RMS per channel at 4 Ohms 150 W x 2 CH RMS per channel at 2 Ohms 250 W x 2 CH RMS Bridged Mono at 4 Ohms 500 W x 1 CH RMS Mono at 1 Ohm N/A INPUT SENSITIVITY 200mV - 6.0V FREQUENCY RESPONSE 10Hz - 30KHz +/- 0.5dB THD LESS THAN 0.01% S/N RATIO > 103 dB CHANNEL SEPARATION > 91 dB DAMPING FACTOR @100Hz 4 ohm > 200 CROSSOVER RANGE   High Pass, 12dB/Octave 80-1.2K Hz Low Pass, 24dB/Octave 10Hz - 250Hz Subsonic N/A Variable Bass Boost (0 to +12 dB bass boost at 45 Hz) Yes Phase Shift (0 - 180 degrees) No Fusing 3 x 40A Size (L x W x H) in 16.4 x 8.9 x 2.2
    • By Aaron Clinton
      I am working to expand our amplifier offerings, while staying high quality, somewhat unique, and affordable.
      First up looks like a class-A/B 6 channel.  No crossover network, individual gains, 150watts x 6, will keep footprint as small as possible for the design, similar appearance to the current models.  Feeling out interest as it will effect the total amps I put into production.
      As a side note, I am considering a 2-channel of the same line, but the demand for 2 channels right now are so low.  Would not really want to build them if they are going to sit for a while.
      Just curious on any input before I get production going.
    • By Wolfram Audio
      Now available on the SSA store!
      I do NOT check PMs on here. For any questions, email [email protected]
      Wolfram Audio W-3000.1:
      RMS Power @ 1 Ohm : 3,000 Watts x 1 Channels (14.4v) RMS Power @ 2 Ohms : 2,000 Watts x 1 Channels (14.4v) RMS Power @ 4 Ohms : 1,150 Watts x 1 Channels (14.4v) RMS Power @ 2 Ohms (Linked) :  6,500 Watts x 1 Channel (14.4v) Frequency Response : 10hz~350hz (+/-1db) Working Voltage : 10V-16V Signal-to-Noise Ratio (Sensitivity) : >90dB Efficiency @ 4 Ohms : 86% Low Level Input (Gain) : 8V - 200mV Low Pass Filter : 30Hz - 250Hz Bass Boost : 0 ~ 12 dB Subsonic Filter : 10Hz - 60Hz Phase Shift : 0-180 Degrees 4-Way Protection Circuitry Built-in (Thermal, Voltage, Speaker, DC) LED Power & Protection Indicators Master / Slave (Linkable) : Yes Recommended Fuse Rating : 300 Amps 1/0 Gauge Power and Ground Terminal Inputs Remote Level Control Knob Included
      Wolfram Audio W-1500.1:
      RMS Power @ 1 Ohm : 1,600 Watts x 1 Channels (14.4v) RMS Power @ 2 Ohms : 900 Watts x 1 Channels (14.4v) RMS Power @ 4 Ohms : 530 Watts x 1 Channels (14.4v) RMS Power @ 2 Ohms (Strapped) :  3,200 Watts x 1 Channel (14.4v) Frequency Response : 10Hz - 350Hz (+/- 1db) Working Voltage : 10V-16V Signal-to-Noise Ratio (Sensitivity) : >90dB Efficiency @ 4 Ohms : 86% RCA Line Output : Yes Low Pass Filter : 30Hz - 250Hz Bass Boost @ 45 Hz : 0 ~ 12 dB Subsonic Filter : 10Hz - 60Hz Phase Shift : 0-180 Degrees 4-Way Protection Circuitry Built-in (Thermal, Voltage, Speaker, DC) LED Power & Protection Indicators Master / Slave (Linkable) : Yes Fuse Rating : 150 Amps (Linked: 300A) 1/0 Gauge Power and Ground Terminal Inputs Remote Level Control Knob Included
      Wolfram Audio W-600.1:
      RMS Power @ 1 Ohm : 700 Watts x 1 Channels (14.4v) RMS Power @ 2 Ohms : 380 Watts x 1 Channels (14.4v) RMS Power @ 4 Ohms : 200 Watts x 1 Channels (14.4v) RMS Power @ 2 Ohms (Strapped) : 1,400 Watts x 1 Channel (14.4v) Frequency Response : 10Hz - 350Hz (+/- 1db) Working Voltage : 10V-16V Signal-to-Noise Ratio (Sensitivity) : >90dB Efficiency @ 4 Ohms : 86% RCA Line Output : Yes Low Pass Filter : 30Hz - 250Hz Bass Boost : 0 ~ 12 dB Subsonic Filter @ 24 dB Slope : 10Hz - 60Hz Phase Shift : 0-180 Degrees 4-Way Protection Circuitry Built-in (Thermal, Voltage, Speaker, DC) LED Power & Protection Indicators Master / Slave (Strappable) : Yes Fuse Rating : 30A x2 4 Gauge Power and Ground Terminal Inputs Remote Level Control Knob Included
      Wolfram Audio W-125.4:
      RMS Power @ 2 Ohms : 175 Watts x 4 Channels (14.4v) RMS Power @ 4 Ohms : 125 Watts x 4 Channels (14.4v) RMS Power @ 4 Ohms (Bridged) : 330 Watts x 2 (14.4v) Frequency Response: 15hz to 35khz Low Level Input Adjustment: 0.2v to 8v Signal to noise Ratio: >90 dB Minimum Impedance: 2 Ohm Low Pass Filter: 50hz to 500hz (500hz to 5khz [x10]) High Pass Filter: 50hz to 500hz (500hz to 5khz [x10]) T.H.D. Continuous @ 4ohm : 0.05% Operating Voltage : 10v ~ 16V Fuse Rating : 40A x2
  • Recent YouTube Posts
