tc300
Xcon v1 / v2
Looking into getting an ssa woofer.. Found a v1 xcon for good price, would like to now the differences between the v1 and v2 xcons....
Any body have the t/s from the v1 woofers ???
There is a v.2?
Small upgrades, nothing to change t/s specs really. I believe it's mostly in the cooling aspect.
Ok that's what I wanted to hear.... THANKX
Been using a Q for a few years, time to update a lil. Lol
Love the flat cone look of the xcons...
i think it may be the spiders aswell. not 100% wait for mark or Aaron to confirm
Yeah the V2s have different cooling, and they recently switched to nomex spiders. When I was looking at mine Aaron said that I wouldn't have any issues running a V1 and a V2 in the same enclosure, so they are that similar.
That's exactly what I was wondering also. Thanks.
The original has a vented pole, the new model has a solid, axial CNC machined pole. :)
The original has a vented pole, the new model has a solid, axial CNC machined pole. :)/>
What advantage or disadvantage would the OP have if he used both together, if any?
So how much room should I leave behind the motor?? Mite be an issue with my install box requirements....
It needs to be at least the pole vent diameter.
The original has a vented pole, the new model has a solid, axial CNC machined pole. :)/>/>
One is a tiny bit more efficient, the other can take a little more thermal. The difference is inaudible and might only be noticeable in extreme levels.
Would it be possible to do a v2 re cone on a v1?
The soft parts should fit fine, but you wouldn't be physically changing the motor to a v2.
do you mean can put all the parts that come with the recone in, but the sub still remains a v1?
Yes.
Yes it is a V1 motor. The recone is only the coil and soft parts which are very similar to the v1 anyway.
sorry for thread jacking u guys. but quick question. what parts come in a recone?
Edited by 1two3
All the soft parts and the VC : I've always saw the recone kits in just one piece.
Use google / pictures or take a look at the store pics, maybe.
Even better idea, thanks
