Quentin Jarrell
complete list of drivers currently being worked on
I am going to try to put together the drivers I am working on here in this one topic. I'll try to give all the info that I have available including expected t/s parameters, price, ETA, ect.
This first one could cater to the SQ crowd. It's designed to work in pretty small sealed and ported enclosures. It will be available in 10, 12, and 15 inch models. Below is the expected 12 inch parameters.
Projected specs. 12'' sub
Re 2.06 (series)
Fo 32.82
Qts .4686
Qes .5022
Qms 7 (estimated)
Vas 23.01 liters
BL 17.19 T/M
xmax 22.5mm one way @ 82% BL or ~27.5mm @ 70% BL
Rms 10.29
Mms 346.1g
spl 89.8 @2.83 volts
750 watts rms
COIL
8 layer flat copper
ID 76.657mm
OD 85.83mm
20 gauge copper
30mm winding hgt
213.9 turns
AND A RECOMMENDED PORTED ENCLOSURE
1.5 cubic feet
Fb 29.6 hertz
F3 26 hertz
Pemax 1072 watts
ripple 0 DB
CUT VIEW OF MOTOR
This is a MMAG so you can see the two top plates. The silver are Faraday rings. As you can see the coil will be engulfed throughout its entire stroke.
I have samples coming with the Ethos order in March. As long as everything comes as expected I will have a production order on this model for July. It should fall around the $350 price range. The faraday rings add about 40% to the manufacturing costs of the driver.
2ND MMAG DRIVER
This is a very very stout 270mm (11 inch) OD motor. It,ll offer a daily or SPL option. I also have a sample of this motor coming with the Ethos production.
Edited by Quentin Jarrell
cool stuff brah!
This is the final sample I have coming with the Ethos production order. It uses a 3 inch 100mm long 8 layer flat aluminum coil with an Re of 1.75 ohms. That gives this motor a BL of 34.8 and a motor force factor of ~692. To their knowledge this is the largest 3 inch coil that precission has ever made. the motor uses two 270mm OD x 25mm thick magnets and a 50mm thick top plate and bottom plate.
update sir?
All these samples will be in shortly. They are being machined as of last week.
Update?
oh so now you're doing marine audio?  lol
They should be on the boat on the 30th
Any progress on those shallow mounts ?
The designing on them have been completed. The samples for them will come with my next production order.
I can't wait..
when is that?!!!!
As soon as you buy up all my Ethos wooferlers
