Mark LaFountain
Welcome to the IHoP v.2
Dawn is fine although not as good at grease removal as Palmolive.  Just make a diluted solution and soak it a bit.
With ANY chemical on clothes it is always good to rub some on an inconspicuous spot first to see if it pulls color.  Rub it in with a white hankerchief and see if the hanky changes color.
7 minutes ago, Aaron Clinton said:
A moment before screaming, obnoxious kids ripped the peace away...
A calm shot at dusk off the pier behind our house.  Excuse the image quality.
Wait, pier behind your house?
Yes, I'm in a little community off the Magothy that there is a little shared pier for the houses.  We drag our kayaks back there and a friend will occasionally pick us up on the boat.
42 minutes ago, Aaron Clinton said:
I am not as tight on the level of protein as of late.  Just doing everything I can to stick to veggies and protein...and low carb beer. ;)
Hahaha.  Ok fair enough.  That's the answer I didnt want! I'm finding I cannot loose weight unless I bring my calories down to absolute minimum, or flawless keto 5-6 days a week.
I've had success with intermittent fasting a bit, but I find myself struggling with protien.
Awesome!!
I do morning fasting.  How much lifting are you fitting in?  Lindsey might be able to help, she has seen great results.  But she eats much less than me.
5 minutes ago, ///M5 said:
Awesome!!
Door is open and top floor suite is open. :)
Hmmm.  Should make that happen.
I lift with sustained intensity 3 times a week.  Circuit ever day, mostly focused around body weight and light dumbells with focus on postural muscles and the gun show.
Legs are not hit with compound movements too hard though.  I am not squatting much and dont have a leg press so I do a lot of supplemental work and then use lighter weights for the compound  movements.
There is nothing cooler in life than traveling somewhere by boat.
I do heavy lifting 3x a day.  Sometimes more.  Depends on how much i drink but lifting tbe dick is a workout.
That's our plan for today.
Sean, didn't you buy a bike for the little ones and pull the pedals off for a strider? We are looking for lil MG
Just now, MKader17 said:
Seems appropriate
Derp, wrong picture
8 minutes ago, MKader17 said:
Screenshot_20180526-190456_zpsluymvbgy.p
Right image.... Seems appropriate
I watch that show from time to time
The Prius are in numbers far greater than the Hemi.  Take what you will from that.
Yes
Means its more likely that's true :P
5 hours ago, ///M5 said:
Yes
I need some deets or advice at some point. I'd like my kid to be mildly coordinated :P
On 5/22/2018 at 8:40 AM, ///M5 said:
Hmm, that used to be me J.
Sitting for extended periods of time definitely doesn't help. :hsughexile:
