Mark LaFountain
Welcome to the IHoP v.2
Seriously what size should my steak be?
If you are a propane jew Mike you should just use lump
Charcoal is what he means.. When i use Charcoal i let it burn down real good. Rub the steaks in olive oil and use kosher salt and cracked peppercorn. Move all the coals to one side of the grill and sear each side of each steak for a minute or 2 depending on thickness directly over the coals. Then move away from coals and cook 3-5 minutes per side only flipping once.
All steaks should be thin Mike.
A little bit less than the diameter of my cock is perfect.
So about 5 inches
Lmao 5 inches? And that's on a good day
Depending on what you want man. Also depends on how you liked them cooked and how long you wanna cook them.
10 minutes rofl. Mine takes about 60 to come to temp WITH the seat burner on.
I'm too cheap to run propane full blast for 60 min. I would normally do 15 on a grill like his.
I did butter on burgers yesterday and it really helped make a crust. I was cooking on a Weber.
Funny thing. I turned the Weber up full blast and walked away. MominLaw saw it smokin and when she opened it a flame jumped up and she flipped. She grabbed a bunch of baking soda and threw it on the "fire". It was comical.
a burger is not a shrimp lol
What makes butter worthless on the shrimp? 9 times out of 10 I cook shrimp in the stainless pan and it usually involves everything O mentioned above.
What makes butter worthless on the shrimp. 9 times out of ten I cook shrimp in the stainless pan and it usually involves everything O mentioned above.
What temp do I need to get the grill up to mike?
For either, as hot as you can. I wouldn't do them at the same time as overcooking will be too easy. PS - having flames hitting the steak consistently is not good for either.
Do you have a digital meat thermometer?
Nope..Just the temp gauge on the grill.
shrimp love olive oil
Butter just makes black shrimp shells, olive oil on the other hand makes good eats
I'd peg it for an hour
This is how I roll! #501st
If it doesn't carmelize nicely in 2 minutes a side after that I'd sell the grill
Mike, this is what you are looking to achieve with a steak. Notice that there is little gray, just sear then delicious meat. It is not easy to achieve IMO.
Note this one has a lot more grey. Now, I would still tear up that steak but the more you can get like the first one, the better.
Why does it make black shrimp but not black burgers
No need to worry about it tonight but in the future, even a $20 one was revolutionary for my cooking.
What about ghee?
mass
What about ghee?
if you are pan wearing without the shell great!
Cooking shrimp on a grill without the shell makes Zero sense. Smoker ok, but not at high heat. Leather is not good eats
Shrimp love high heR though
Her is heat in spell check wtf
I pan dry shrimp in ghee all the time
How is a pan different than a grill. Is it that a pan holds the fat?
I never understood the concept of cooking with the shell on.
Grill is at 300.
