Mark LaFountain
Welcome to the IHoP v.2
Senior Ball tomorrow night!
The crazy started yesterday!
Holly shit it goes by damn fast!
Going to raise the 4runner front end up to 1.75" and get it aligned. After measurements on the rack is will be where I want it. :)
Pointed at her shin and asked my neice what body part that was. "This is the tibia, and this is the fibula". God damnit you're three! Act three damnit!
Edited by Penguin4x4
Finally get my new DSLR tomorrow. Next on the list is some further upgraded glass.
The FX (full frame) body works with both FX and DX lenses. The DX body I had before, does not work properly with FX lenses. Hence not buying FX glass before. Now that restiction is removed and I'll be looking around.
J
That is confusing. The crop sensor lenses shouldn't work with a FF body.....
Finally get to go HOME
I need to look at your wine cellar.
Cellar is a strange word. Space under the stairs with a rack on the other hand.
Potato potato
J
http://www.nikonusa.com/en/Learn-And-Explore/Article/g588ouey/the-dx-and-fx-formats.html
J
You ignorant fuck
Sigh... walks off to tie noose...
Seth and other mechanically minded people...
How would a superglue + baking soda repair last on a radiator end tank ? Stupid previous owner had the end tank gasket repaired, hammered a few tabs too hard and cracked the end tank.
I fixed a crack in the overflow bottle (it's pressurized, unlike petrol engines and leaked quite a lot of coolant before the fix) and it lasted nicely over the last 200 miles but it's a different plastic.
I've the same repair an intercooler end tank, so similar pressures, oil instead of coolant and lower temperatures, it held nicely.
I can't say, Adrian. Pressures aren't really high, and if you did it and it held on the overflow I assume it would work, but without any real experience I will have to claim ignorance on this one, my friend. Sorry.
It held on the overflow, I mean I was supposed to leave the house, quickly sanded the crack, added superglue, baking soda, repeat 3 times to make a big patch, change clothes and drive. No leaks, no x hours to cure. Last I recall the overflow cap has a 15psi valve. When squeezing the top radiator hose I can't feel much pressure.
I have the old radiator from the Miata, I can use it to test how well the mix sticks to radiator end tanks.
Slightly related...if I buy another used radiator, I'm afraid of transmission cooler failure. What if I just ditch the in-radiator cooler and use a normal radiator for the transmission?
External is fine... better than internal, in fact.
Bought 50 grams of Wurth superglue, much stronger than regular stuff. I'm going to go full retard and fill the entire end-tank to core seam.
I like the Wurth glue. The accelerant makes it even more awesome. Wurth is an awesome company.
J
That has always been the one advantage of Nikon. Of course they vignette out, but you can crop that easy in Lightroom with an automatic macro at import
My colleague shoots a FF Nikon and uses a 11-16mm crop for outdoor shots. WIIIIIIIIIIIDE
You ignorant fuck
I have that effect on people
Finally get my new DSLR tomorrow. Next on the list is some further upgraded glass.The FX (full frame) body works with both FX and DX lenses. The DX body I had before, does not work properly with FX lenses. Hence not buying FX glass before. Now that restiction is removed and I'll be looking around.J
It helps in the transition from DX to the FX format. Makes the hit to the wallet easier to take.
I'll be using the DX lenses for the first few weeks but soon I will get some of the FX formatted lens sizes you have previously suggested. Hopefully Saturday I can go test drive the new body on the old glass.
J
Got a 1/2 year bonus check today..smile.png Fixing to order me some carpet for the Camaro..And deadening as well,fixing to gut it.And prepare for the wall to come.
You ignorant fuck
Don't do it!!!!
You ignorant fuck
Smart three year old :)
And will buy the bare block for the National motor swap,Looks like I will have to piece together the top half and electrical.
You ignorant fuck
You make people tie knots for no reason?
You ignorant fuck
Cans will be here tomorrow. Think I decided on my amp, now I need to grab up some upgraded tubes... if I don't change my mind.
I found a few amps I really liked. I was going to take the plunge on a Jolida unit that was a demo, but it is 30 ohm capable. I liked one of the high end little dots... 32 ohms. All these damn units I like are 30 ohm systems.
