Mark LaFountain
Welcome to the IHoP v.2
Tried my first crack at coffee roasting. Bought a popcorn popper recommended by sweet maria's and 8 lbs of sampler beans.
Seems like by beans only made it through the first crack but they seem to have come out vienna. I was shooting for full city (oops). Not sure if I need to do something to slow down the roast.
I tried to keep them moving as much as possible to keep things even, but I'm not sure if that will be the best method as once things got going they moved pretty well.
The roast doesn't seem remarkably even and it looks like there is quite a bit of chafe left over. Not sure if that is normal, but I cleaned it up the best I could.
We will see how they taste tomorrow. It's got to be better than the Folgers at work :P
Mmmm coffee.
I enjoy the aroma of coffee and tea, but cannot drink either without filling them with sugar.
The reaper is going to have fun with you brother....
We will see how they taste tomorrow. It's got to be better than the Folgers at work tongue.png
Replaced the fuel filter on my truck and man was it dirty tapped.it against the ground and a bunch of shit came out, also cleaned the MAF sensor and its still running rough, couldnt find an OBD meter to hook up to my truck, called the peice of shit mechanic I took my truck to last month and he said 50$ just to hook it up and see what codes it throws..Fuck Him!
Next time suck your filter out.. and take it to a local parts store and get it read for free....
OK, so Seth bought his first set of cans. They are easily driven, 18 ohm cans. Sennhieser Momentums.
Who here uses cans and what amps are you using? Interested in tubes.
Requirements:
  • must be able to roll so they have to be socketed.
  • down to 18 ohms, 20 should be safe
  • I would really like 3.5mm and RCA inputs
  • small footprint
  • under $250
Shoot!!!
Went to autozone and oreillys they dont hook OBD's up anymore they said
That is why you have to hit them in the mouth and make them...They will do it in my area for me huh2.gif
Its because you give them a quick hand job before you ask to use it.:P
Its because you give them a quick hand job before you ask to use it.tongue.png
No it is because I have respect from people in my area believe it or not... .10 fold cool.png
awesome, if they dont respect you punch em in the mouth
 And how is your welding going by the way? Tried aluminium yet?
No need....
Its going ok, did aluminum mig a handful of times comes out nice but you cannot "whip" back ito the puddle like regular mig it leaves black shit on the aluminum. And have tried aluminum tig a handful of times I can also lay down a nice bead on it. A few months back tried to TIG weld aluminum with DC, the filler rod melted like playdo... i was like WTF is going on, later on I figured out Tig aluminum is AC lol
What wire?
Aluminum .035 on a miller pulse mig welder
Edited by Stephen93s10
Mostly what i deal with is .045 solid/flux cored stainless steel wire "Hyundai" ...And seldom ESAB marathon pac's will lay some nice beads with aluminum..
Barrels 661lbs for hyundai..
You said you work with HVAC? Which is like AC's?
That's one of my least favorite attitudes about mechanics. What is it you do for a living? Do you like to do it for free for someone who just walks in the door? By your statement I am to assume that you expect me to take 15 minutes to work for free just for you. Not only that, but I should hook up my $15,000 scan tool up and provide you with my years of experience for free.
Why do people feel like mechanics should just do shit for them for free? Just because I am greasy means I don't deserve to make a living?
Requirements:
  • small footprint
  • under $250
Shoot!!!
I keep my wire speed at 300 and voltage at 6.25 roughly on carbon steel and aluminum any where from 2mm to 5mm in thicknees with no burn through's all day long when I need to and laying a bead 200mm + long not just a tack...It is all in your control of movement and the distance of your nozzle and speed on your pass...I will keep my nozzle about 10mm from my weld prevents porosity when using a gas mix and not flux core.. And pause a bit after the bead for all the gas to remove from the orifice of the diffuser ..
That and with robotics, and many other things brother...HVAC is my favorite,But I have to do a whole lot of other shit...
