Mark LaFountain
Welcome to the IHoP v.2
Okay, computer geeks.  I need to connect to a security gate controller via serial cable.  According to the controller manufacturer, I need to configure something on my modem.  Unfortunately, I have no modem on neither of my laptops, and I can not find any information on another way to do it.  Does anyone know if I can get a USB modem and use that.  I don't quite understand why I need a modem when I will be connecting via serial cable versus telephone cable.  Computer stupid here.
Is there a manual online I could read?
http://www.linearcorp.com/pdf/manuals/AXNET_226505.pdf
Here are the instructions for connecting:
http://www.linearcorp.com/faq/pdf-638.html
Negative!! go to network adapters left click and scan for hardware changes..
If you have no modem why do you have a security gate?
The security gate is at work. The controller got messed up in a power outage and I am trying to hook a computer up to it to see if I can reprogram it versus spending thousands on a new controller.
Faaaaaaawk. Like a real physical gate. God Damn. I thought you meant some digital security check.
Roflmao.
Sorry man. I was stymied.
I'm retarded. Just spent the last hour trying to curve fit data that I got from an equation. rofl2.gif
Did you use excel trend line?
From reading that it sounds like you can set it up with either a serial port OR modem. If you do the serial port way then you make a pseudo modem on the computer but it's actually using the serial port. Your computer has a port like the one on the far left here: http://www.libertycable.com/RUB_IMAGES/images/hi-res/DIGI-HDE-S_RS232_side.png ?
I tried using the solver in Excel but it wasn't working out, the plot was sigmoidal and the actual equation was just y=b+log(x/(1-x)). I suck at Excel though.
You can access it via serial modem "tcp" to any network access as long as the returning party sends a sny to establish connection ..
Why would you need a modem for this huh2.gif  Enable remote access....and pm me your ip.....
How would you connect from outside the local network? Unless the router is setup for port forwarding or using a reverse connection.
UDP.. ...requires no handshakes.. excluding port 0
Yes. I do know what a serial port is. I am lost on the rest of the shit you guys are talking about though.
I don't believe you need a modem to connect to it, the serial port alone is enough (hardware wise). Then follow the instructions in that PDF for setting up the connection.
That doesn't make any sense to me.
The Remote Desktop Protocol: UDP Transport Extension Protocol has two distinct phases of operation. The initial phase, UDP Connection Initialization (section 1.3.2.1), occurs when a UDP connection is initialized between the terminal client and the terminal server. Data pertaining to the connection is exchanged and the UDP connection is set up. Once this phase is completed successfully, the protocol enters the UDP Data Transfer (section 1.3.2.2) phase, where Coded Packets are exchanged.
The protocol can operate in one of two modes. The operational mode is determined during the UDP Connection Initialization phase. These modes are as follows:
  • RDP-UDP-R or "Reliable" Mode: In this mode, the endpoint retransmits datagrams that have been lost by the underlying network fabric.
  • RDP-UDP-L or "Best-Efforts" Mode: In this mode, the reliable delivery of datagrams is not guaranteed, and the endpoint does not retransmit datagrams.
The connection between the endpoints is terminated when either the terminal client or terminal server terminates the connection. No protocol-specific messages are exchanged to communicate that the endpoint is no longer present.
Can't connect through port 0 regardless VIA udp...
port 3389 trumps!!
What I'm saying is the router filters incoming connections, so unless the router is setup to port forward than the computer won't connect. Or if you use a reverse connection where the computer behind the router connects to the other computer (that is either open to the internet like a server, or itself is behind a router that has port forwarding setup).
Aside from the above I don't see how you can connect to a computer from outside it's local network, regardless of whether it's TCP or UDP. Are UDP connections not filtered on routers? If so, then how would you know which internal ip to connect to?
TCP and UDP is filtered but that is useless with the right tools......as far as the ip the history of the packets sent and received is helpful...that can be obtained from certain programs..
I'm beginning to think you're retarded, or know a lot more about networking than I and just make no sense when explaining.
UDP  remote access is the easiest by "defualt" your pc grants this with the ip and port 3389...and can manipulate the router settings by a simple imput of the ip in the address bar..
AKA changing the router settings for port forwarding. So if I give you my router's IP and tell you to connect to my windows computer, you can't, unless I setup port forwarding on my router.
Lets bet than...$100.00 paypal for your ip...I'm good for it...
As a retard I should be able to figure out paypal hopefully..
I'm not betting anything, I barely have enough to pay rent. Let me plug in my win8 tablet and enable remote access then I'll pm you my IP--if you still want to try.
no...you could have a bill....enabled/disabled does not matter wink.png You know this biggrin.png
Try? reallly??lol
I really have no idea what you just said. Do you want to try or not?
sure
