Mark LaFountain
Welcome to the IHoP v.2
sweet tool box design
Figured out why injectors 2 & 3 aren't working on my truck and cause it to run rough at low and mid rpm ranges....  The god damn things aren't even hooked up.  No fricking wires to them.  I'm actually somewhat impressed now that it runs as well as it does two injectors down.  I've just been thinking they were crapped out and stuck open and had to buy new ones, been to lazy to drop the money on something that just runs around town but now that I know the problem I get to pull the intake off and play electrical fixit man.
Wow, um, how the hell could you NOT notice that?
Hidden under electrical loom and that big ass manifold.  Plus of all the busted crap I've worked on, never had a wiring issue on injectors before, some loom going to them, sure they are hooked up, not in this case...
Go slow, good drill bit, 135* split point a normal drill bit will be fine no need for TiNi coatings, cobalt probably isn't needed either.  Cutting fluid wouldn't hurt either.  Keep the drill bit under ~60 surface feet per minute, (4*60)/dia of bit.  Drill bits from most stores suck, Fastenal sucks.  McMaster carr has good stuff, normally from Precision twist drill.
Shoot me a PM some time...
I LOVE Fastenal bits!  I get the Cleveland ones though, not the cheap HSS shit.  Parts Master or something like that, they have awesome cryo bits.  I used to buy those exclusively,  but that was when I wasn't drilling 1" stainless so often.
Last one I got, 15/16" I think, shattered on the first hole it ever drilled.
A dremel with a cutoff wheel might work. At work when we have to remove stainless rivits that is what we at times.
It's my understanding the self piercing ones don't come off so easy that way. The stainless pin needs to be pounded out in reverse once the mushroom is cut off. Thought drilling it first made sense, but I am a bit concerned as the pin is stainless and the riveted material aluminum which I don't want to overbore.
Tapered carbide burr would knock it out too without an issue.
I will spend $ to save time...
I've read a bunch of shit on removing rivets. Need to save the metal I'm taking off. Want to pull the tunnel (part over the track) of my snowmobile and have it powder coated/anodized black. smile.png It's riveted on so I need to yank it to have it done. Since the track and tank will be off I have access to all the rivets, but if it takes too long I won't do it. Limited shop time for me, but I want to smile.png
Drill slightly larger than the mandrel, head pops off, rest falls out.   Pretty simple.
Doesn't that increase the risk of ovaling the hole? For everything else that is exactly what I tried.
Pop rivets?
Stainless self piercing, 3/16" ones. Hell on drill bits. Cobalt/Ti or bust I guess. Thought maybe there was a trick smile.png
If you have a steady hand, you can always grind the heads off as well.
Should I drill first?
Looks like you are going to have to drill the center out, then grind the head off.  Since you are going to have to put solid rivets back in, I wouldn't worry about it to much if the hole gets just a bit bigger, you could always size up your rivet.
Ought to be a fun 12 beers, lol
Part of me wants to be lazy and not do it and just wrap the tunnel in vinyl. tongue.png
Bitches ain't shit but hoes and tricks. And naproxen doesn't seam to do dick for the immediate pain.
If this doesn't get better in short order I'm calling up for some of the good stuff. Papa bear needs some synthetic opiates.
Sean if you like I can put a tapered carbide burr in the mail for you to use. I will check tonight and see what sizes I have.
Fuck today. Joints be hurtin.
But you are Super Matt! NO PAIN!
Hey, someone must be squeezing the kryptonite around me somewhere.
I'm extremely positive that I have a plan and someone in my corner.... but reading between the lines it means it will be at least a week before any real relief if any at all yet. Then once I get the pain and more importantly inflamation managed. I have to basically make my life all about being physically fit.
Just having some direction and a plan and a specialist who is in my corner is an amazing feeling.
You can do it MAtt!
Don't rush, I am not 100% that I am doing it...90% yes
Just let me know, I should have something you can use.
Just sent to my BIL.
Edited by dem beats
Funny shit there!
I wanna get home and ride my new quad. I skipped school last night to get a couple hours in. That thing is a fuckin beast.
Sounds so fun.
I know the feeling, looking out the window right now is KILLING me.
Best looking snow of the year and I have to get on a plane. When I return it'll be shot.
Going to make an all beef meatloaf tonight, and fingerling, blue, and purple potatoes.
Give me some ideas for how to flavor the meatloaf.
What makes this snow the best?
