djphilly
(2) SUNDOWN SAZ1500-v3 amps for sale
As the title says, I have 2 sundown saz-1500v3 amps for sale. SELLING AS A PAIR. unless I can have two buyers to split price. They come with original boxes. MINT CONDITION!!. less than 1 month old. never seen below 13 volts. never put into protections. I need to upgrade power and need to sell. asking for $700 shipped. willing to trade for amps 5k-7k of power plus cash on my end depending on amp. specifically Soundstream x3.71, RD D9, Hifonics XXV Goliath or XXV Sampson, or similar
Rated power output
----RMS power, 2 ohm linkable/dual mono 3000W x 1CH
----RMS power, 1 ohm mono 1500W x 1CH ----RMS power, 2 ohm mono 930W x 1CH
----RMS power, 4 ohm mono 530W x 1CH Signal to Noise Ratio >90dB Low pass frequency crossover 35Hz~300Hz Subsonic filter 10Hz~60Hz Bass boost @ 45Hz 0~9dB Phase shift control 0~180 degree Frequency response 15Hz~270Hz (+/- 1dB) T.H.D @ 4 ohm <0.1% Efficiency @ 4 ohm 86% Fuse rating 150A Dimensions 8.25"(W) x 2.32"(H) x 16.53"(L)
SOLD!!!
  • Recently Browsing   0 members
    1. Recent Topics
        • 7 comments
        • 331 views
        • 1 comment
        • 405 views
        • 1 comment
        • 161 views
        • 1 comment
        • 148 views
      1. Box for 1 15" SSA ICON
        • 3 comments
        • 1,006 views
        • 8 comments
        • 1,920 views
  • Similar Content
    • By Pitt
      Hey guys what's up...so I'm new to all this car audio forum stuff and am trying to fumble f__k my way through this post....so here it is...I am old school and have all old school shit....I'm looking at powering this beast of a system.....I have all of this in an 04 toyota tundra access cab limited.....basically I have around 20k of power needs....I'm running 2 DVC 10's by cerwin vega...2 DVC 12's by cerwin vega...3 different cerwin 6.5 component systems...head unit is 10.6 inch touchscreen with every bell and whistle imaginable....for power I'm old school also with a lanzar 8k velocity amp..(2 channel) for the 10's...a lanzar 2.5k velocity amp...(4 channel) for components.....a power acoustic 10k amp for my 12's.....I have a stinger 10 Farad cap.....now my problem is how to power all this equip.....I'm looking into the deka farm batteries....there was another who posted about this same dilemma....I ask....what about rv batteries....and can I put 24 volt batteries in the bed and step them down to 12 volt....and have less batteries....I don't want to go into debt for the rest of my life trying to power this system....I have pics of all this build that I will upload as soon as I figure out how...and I think yall will get a kick and some amazement out of my enclosure fabrication...I also have fiber optic lighting inside...lighted wheel rings and underglow outside....it's a lot of juice I need and I don't want 20 batteries...what's my best solution
    • By Chad L
      Question about the use of amps crossovers and sound processors. Is it best to go all active not at all or combine?? Are amp filters as good as sound processors?
      When you buy a component speaker system you are paying for a crossover too. More expensive units have better crossovers. It’s been suggested that these crossovers use up power so not using them and using HPF and LPF on your amps is the better way to go. An alternative method is using a digital active crossover that can be programmed.
      Different methods are also to influence phase shifts that can create cancellation  or have better frequency curves.
      The cons would be a dedicated amp just for tweeters and one for mids and one for subs so instead of a 4 channel amp driving 4 pairs it would drive the mids on two channels and two channels for the tweeters then not using the expensive crossover that came with the speakers.
      I’m running everything thru an Audio Control DQX with sub filter crossover point and EQ that is separating the signal at 90hz which I can adjust. Then thru a programmable crossovers The component and coax speakers are all actively crossed between subs and mids but I am using factory crossovers still. I’m assuming they are only helping tweeters but guessing they may have a filter for the mid too?
      Do you think I am negating phase advantage by leaving factory filters in? Is the phase pollution not disruptive in high frequency so phasing mids and Subs is sufficient?
       I’m bi amping a pair of JBL competition speakers that has a jumper to remove in the crossover when doing this I am also using amp HPF and running other tweeters off all 4 channels. The JBL owner manual goes into great details about phase shifts and axis to explain what this crossover is doing to help
      is there a better way to measure it sounds going to me but who knows?
    • By DeMan2319
      Good evening everybody. I have a few items to install for an Audio System upgrade; but don't know how to go about it. The Items that will be involved are -1 Distribution Block -2 Amps. -1 Capacitor. -1 Equalizer/Crossover -6 Speakers in Total (2 tweeters, 2 Front Door 6.5's, and 2 6x9's) -1 Subwoofer
      I'm trying to connect 2 amps; 1 for the Subwoofer and the Second for Speakers. My Aftermarket Head Unit has 3 pairs of RCA plug-ins.
      1) Subwoofer 2) Front 3) Rear.
      How Would I connect the 6 speakers (which I'm going to rewire) to the 1st amp? Do I wire the Speakers to the Amp or Straight to the Head unit itself? Also, how would I connect the amp to the Head unit if it only has the 3 RCA plug-ins as stated above?
      Any advice or suggestions are Welcomed. Thanks in advance.
      URL: https://able2know.org/topic/434961-1
  • Recent YouTube Posts
