Kaschan
Amp for a single GCON 10?
I'm still waiting for the GCON 10-D2 to actually arrive, but figured I'd take the time to look for a amp to power this beast now. It will be in a sealed box, in a saturn ion 2003. Looking to present a 1ohm load at amplifier, since I'm assuming that power at 4ohms is asking too much for my budget. No HO alt, or big 3 done yet, assuming it won't be needed yet though.
I was mostly wondering if I'd need to feed it the full 750w, or if I could get by with less, near the 500w level? Just wondering as my budget is a bit tight currently, and I was hoping to grab the amp for under $150.
Given what I've listed, would any of these amps work well, or are there others I should be considering? All listed are CEA-2006 compliant, so I'm assuming they all do rated.
1. Concept CC-D1200 (Apparently 750W @ 1ohm stable, manufacturer refurb, so not new)
2. Massive Audio N2 (800w @ 1ohm)
3. PPI BK650.1D (650w @ 1ohm)
4. Hifonics GLX1000.1D (1000w @ 1ohm)
5. MB Quart ONX1.1000D (1000w @ 1ohm)
Thanks for taking the time to look, hoping I get some great feedback!
You don't need the full 750. I really like my PPI Bk amps. The Mb Quart is also another solid budget amp. Nice choice on the sub!
Thanks, can't wait for it to arrive! and I wasn't positive on the amount needed, just figured those ones looked to be good enough, and the price was right.
The RMS rating of the subwoofer has nothing to do in the slightest with the amount of power you will need to reach a certain output level.
So nice he said it twice.
First rule of fight club is not to talk about fight club.
So...I'm assuming that going with PPI, or the MB would be a good choice though, or has anyone heard about the others on list? Or has anyone else heard about alternatives to those on the list in my price range?
Boston GT2125. 600wrs @ 4ohm for ~$120.
With out the budget, the IA 5.1 is a great choice.
GT-2125, if I'm looking at it right, is only 600W bridged at 2ohm...Unless I'm completely out of it.
Ah yes my mistake, I would still get it, it'll bump on 400wrms
Sonic has GT-2200 for only $149, might get one to just keep under the bed till needed.
It seems like most people are liking the PPI BK650.1D, and I'm leaning towards it now. The other three amps I'm debating between still are either Massive Audio N2, Boston Acoustics GT-2200, or the Audiopipe APSM-1500
Anyone know if I'd be ok to run the GCON @ 1ohm on the APSM, or would it have to be 4ohm, as it's almost double the rms? (Assuming gains are set correctly of course.)
Also, would I need to do the big 3, for any of these amps, or would I likely be ok?
Yes do the big three for any of the amps.
I'm assuming big 3 need to be done in 0 awg, or would 4 awg be enough? Just not sure as I have some long runs in my car as the battery is in the trunk.
Big 3 can be done in 4 gauge, but if you plan on upgrading in the future then use 1/0 for big 3 wiring.
Good to know on the wiring, I'll have to see the cost difference between the 2 sizes then. Any opinions on the 3 amps, from a budget build standpoint?
i just bought a gcon too and have been looking at some of these same amps. which one did you go with?
I decided to go with a Massive Audio N2, going to pick up the sub tomorrow morning, and waiting on the amp to arrive shortly too. Will post back after it's all setup! I'm assuming you went with the 2ohm version, otherwise this amp won't be ideal.
  • Recently Browsing   0 members
    1. Recent Topics
        • 7 comments
        • 332 views
        • 1 comment
        • 414 views
        • 1 comment
        • 167 views
        • 1 comment
        • 150 views
      1. Box for 1 15" SSA ICON
        • 3 comments
        • 1,010 views
        • 8 comments
        • 1,925 views
  • Similar Content
    • By Wolfram Audio
      Now available on the SSA store!
      I do NOT check PMs on here. For any questions, email [email protected]
      Wolfram Audio W-3000.1:
      RMS Power @ 1 Ohm : 3,000 Watts x 1 Channels (14.4v) RMS Power @ 2 Ohms : 2,000 Watts x 1 Channels (14.4v) RMS Power @ 4 Ohms : 1,150 Watts x 1 Channels (14.4v) RMS Power @ 2 Ohms (Linked) :  6,500 Watts x 1 Channel (14.4v) Frequency Response : 10hz~350hz (+/-1db) Working Voltage : 10V-16V Signal-to-Noise Ratio (Sensitivity) : >90dB Efficiency @ 4 Ohms : 86% Low Level Input (Gain) : 8V - 200mV Low Pass Filter : 30Hz - 250Hz Bass Boost : 0 ~ 12 dB Subsonic Filter : 10Hz - 60Hz Phase Shift : 0-180 Degrees 4-Way Protection Circuitry Built-in (Thermal, Voltage, Speaker, DC) LED Power & Protection Indicators Master / Slave (Linkable) : Yes Recommended Fuse Rating : 300 Amps 1/0 Gauge Power and Ground Terminal Inputs Remote Level Control Knob Included
      Wolfram Audio W-1500.1:
      RMS Power @ 1 Ohm : 1,600 Watts x 1 Channels (14.4v) RMS Power @ 2 Ohms : 900 Watts x 1 Channels (14.4v) RMS Power @ 4 Ohms : 530 Watts x 1 Channels (14.4v) RMS Power @ 2 Ohms (Strapped) :  3,200 Watts x 1 Channel (14.4v) Frequency Response : 10Hz - 350Hz (+/- 1db) Working Voltage : 10V-16V Signal-to-Noise Ratio (Sensitivity) : >90dB Efficiency @ 4 Ohms : 86% RCA Line Output : Yes Low Pass Filter : 30Hz - 250Hz Bass Boost @ 45 Hz : 0 ~ 12 dB Subsonic Filter : 10Hz - 60Hz Phase Shift : 0-180 Degrees 4-Way Protection Circuitry Built-in (Thermal, Voltage, Speaker, DC) LED Power & Protection Indicators Master / Slave (Linkable) : Yes Fuse Rating : 150 Amps (Linked: 300A) 1/0 Gauge Power and Ground Terminal Inputs Remote Level Control Knob Included
      Wolfram Audio W-600.1:
      RMS Power @ 1 Ohm : 700 Watts x 1 Channels (14.4v) RMS Power @ 2 Ohms : 380 Watts x 1 Channels (14.4v) RMS Power @ 4 Ohms : 200 Watts x 1 Channels (14.4v) RMS Power @ 2 Ohms (Strapped) : 1,400 Watts x 1 Channel (14.4v) Frequency Response : 10Hz - 350Hz (+/- 1db) Working Voltage : 10V-16V Signal-to-Noise Ratio (Sensitivity) : >90dB Efficiency @ 4 Ohms : 86% RCA Line Output : Yes Low Pass Filter : 30Hz - 250Hz Bass Boost : 0 ~ 12 dB Subsonic Filter @ 24 dB Slope : 10Hz - 60Hz Phase Shift : 0-180 Degrees 4-Way Protection Circuitry Built-in (Thermal, Voltage, Speaker, DC) LED Power & Protection Indicators Master / Slave (Strappable) : Yes Fuse Rating : 30A x2 4 Gauge Power and Ground Terminal Inputs Remote Level Control Knob Included
      Wolfram Audio W-125.4:
      RMS Power @ 2 Ohms : 175 Watts x 4 Channels (14.4v) RMS Power @ 4 Ohms : 125 Watts x 4 Channels (14.4v) RMS Power @ 4 Ohms (Bridged) : 330 Watts x 2 (14.4v) Frequency Response: 15hz to 35khz Low Level Input Adjustment: 0.2v to 8v Signal to noise Ratio: >90 dB Minimum Impedance: 2 Ohm Low Pass Filter: 50hz to 500hz (500hz to 5khz [x10]) High Pass Filter: 50hz to 500hz (500hz to 5khz [x10]) T.H.D. Continuous @ 4ohm : 0.05% Operating Voltage : 10v ~ 16V Fuse Rating : 40A x2
    • By Godsmack
      - 27 Raptor 1/0 AWG Ring Terminals $20
      - Install Edge 5 pack remote wires [IEC P 3x5-6] 6 feet $15
       - 2 packs Install Edge 6.6 ft RCA cables [IRC GAC2] $7 each or $10 for both
       - 8 4 way Knu Konceptz 1/0AWG in 4 8AWG out $8 each or all for $55
       - 50ft 16AWG speaker cable spool $5
      - Install Edge Remote wire [IEC P18 X5-6] 18AWG $5
      - Knu Konceptz kolossus Flex 1/0 AWG Red power cable 44 ft $125; 8ft $25; 10.5ft $35 (all for 175)
       - 13 ft Q power 1/0 AWG Super Flex on spool $25; 15ft on spool $30
      - Approx 400 ft 16AWG Q power speaker wire on spool $40
       - Stinger 150 amp circuit breaker $25
      - 6 Install Edge Speaker Savers [IEC CAP 133] $6 per pack or all 6 pairs for $30
       - 2 2packs Rockford Fosgate 8AWG Ring Terminals $5 each or both for $7.50 -
       2 Rockford Fosgate Side mount battery terminals $9 each or both for $15 -
       Rockford Fosgate 2 output top mount battery terminal $10
      - Rockford Fosgate RCA coupler $5
      - Rockford Fosgate 10 AWG Amp kit (no RCA wires) 17 ft $30
       - Rockford Fosgate pack of 2 100amp MAXI fuses $10
       - Knu Konceptz Negative top mount terminal $10 -
      Metra Honda Harness [BB-WHHDI] $10 -
       Metra Inpala/Monte Carlo [XSVI-2105] $35 - Metra GM 88-05 22 pin harness [70-1858] $5
      - Pair of Dynex square box terminal cups $2
       - Dynex OEM Ford Radio removal tools $8
      - Stinger Blue HPM voltage meter [SVMB] $15
      - Tsunami Marine ANL fused distro, 1/0 AWG IN, 2 1/0AWG out $20
       - Generic ANL fuse holder, no cover $5 -
       Mini RCA stereo Y cable $2 - 14ft Raptor RCA cable $10
      - 16 ft Monster RCA cable $20 -
       Stinger 1/0 AWG ring terminal $4 -
       2 2male 1female RCA adapter $5 each or both for $7.50
      - 1 RCA to RCA dual male wire 9" $2 -
       2 Street wires RCA cables in bags 19.69 ft [ZN1260] $7.50 each or both for $10 -
       ANL fuses, 2 200amp, 4 250 amp, 2 300 amp, 4 100 amp, 2 500 amp. 500 amp are $5 per pair others are $3 per pair, or all for $30
      Total price when purchased individually: $761 Buy the whole lot: $650
      Open to trades, Nikon FX lenses and other photography equipment are of special interest. Feel free to contact with questions. Thanks for looking!!
      - Viper 500.4, missing xo cover, and right mounting feet. $300
      - MTX Road Thunder XO's for componants. $20 for the pair
      - Eclipse SC-8355/8365 XO's for componants $50 for the paid
      - Phoenix Gold Octane 4.0 2 amp. $150
      - JL Audio 500/1. Missing some side screws. Not 100% on what the guts condition is, and last I remember looking it was fine. $125
      - Digital Designs DD C1. $140
      ORIGINAL RE XXX 12" to come, as well as more amps. I'd love to sell everything as a lot, and am willing to make deals. Only thing trade wise I would be after is Nikon FX lenses, but feel free to offer up. Pics are all on the link below.
    • By matj1990
      So looking for some info about amplifier and efficiency.
      I have a xcon dual 1ohm 10"  so i can run at either .5ohm or 2ohm What i would like to know is  1500w @ .5ohm or 1500w @ 2ohm the 2ohm amplifier would be drawing more power to make its wattage because of the higher resistance correct ?
    • By GarrettHarvey
      Getting two hds212s and wanna know what amp to get(sq brand) , and if i should get dual 2 ohm or dual 4 ohm. And if youve done this build, what are the box measures
  • Recent YouTube Posts
