Eldorado
Check your tire pressure !
I checked all the pressure in the tires of the 3 vehicles that are at my house
Not a single one was at the right PSI.
Some 20lbs over, some 10lbs under.
Its crazy how much air you can loose in your tires in a matter of months.
And if you just fill them up when they are low use a pressure gauge, eyeballing and using the built in gauge from the has station are not accurate.
Go buy one, they arent that expensive
I know it sounds lame but if kept neglected ( like what i did) you can really kill your mileage and get some nice uneven tire wear.
the stratus used to be extremely sensitive to air pressure, i could watch the MPG drop big time when the pressure got anything more than 3-5lbs low
Especially in colder climates!
Check your tire pressure as part of a weekly schedule.
Mine are way off...probably should get that corrected.
I should check the sled since it really has not moved since the SWVA meet #2
Deflated.
I bought one of those air pressure nozzles for my compressor with a built in gauge, it makes it way easier especially when you have 3 cars, 2 trailers, a motorcycle and some other she-i-o.
I forget where my guage is at
  Renegadesrun said:
Can i borrow it when you find it?
:fing34:
