Austin863
Parallel and Series
Okay i have a question. how do i wire a sub in parallel and how do i wire a sub in series. and how does it effect it in ohms law. Like if i wire my 4 ohm parallel that puts it at 2 ohms. so thats what the amp output would be at 2ohms. So if i have 2 4ohm woofers and i wire them both parallel that would make it 1ohm correct?
but parallel is plus-plus and minus-minus correct? and how does series get wired?
Series is one wire to one negative, one wire to the other positive, then wire the remaining positive and negative together.
ohhh okay gotcha. i see how it works now (:
