KenC210
Midbass woofers
So i have been looking around at some midbass woofers but i am not to sure what to look for. What i would like from my midbass is that it sound good between the rages of 60hz-300hz. the midbass woofer will be placed in the door, 2007 ford escape. I would like to keep it under 65 per woofer.
What processing do you have? What else are you running?
No processor just deck and off a AQ120.4 using the Bandpass. Also with 4 AQ pa mids and 2 AQ super tweets. Just looking to achieve a good low end midbass because i am not sure that the pa mids will get that low.
Was looking to get an 8. I was looking at a few but was unsure.
http://www.parts-express.com/pe/showdetl.cfm?partnumber=292-570
http://www.parts-express.com/pe/showdetl.cfm?partnumber=295-376
http://www.parts-express.com/pe/showdetl.cfm?partnumber=290-312
http://www.madisoundspeakerstore.com/approx-8-woofers/silver-flute-w20rc38-04-ohm-8-wool-cone/
Where are your subs crossed over? The last thing that you need is more drivers up front.
I was going to have them either at 60 or 80 from the deck but still undecided until everything is hooked up and i could tweak it. But if you think i will be fine without a midbass woofer then i will most likely not be getting any, but i am pretty sure i wont be able to have these pa mids to low
Yeah I was joking. Your brewing a disaster.
You don't just add speakers, and expect it to sound good.
Cross your subs higher and you will be fine.
I have 2 DC Xl 15's. Will they be alright crossed a little higher? My box will be tuned at 33hz. My deck is a pioneer 8300ub i am not sure what the low pass is i think it might be 120hz the highest point
