KenC210
2007 Ford Escape build...
I have had this in for a while now but never did add this to my build log....
A 17 inch monitor and a power acoustik dvd plaer.
As flush as i could get it without cutting the headliner
Vids of the dvd player and monitor to come soon it finishes loading...
So just a small update of the work i got done....
Started with an amp rack and it is going attach to the box...
Here you see that there is a little air space on the bottom to help let them breath a little...
This is a shot of it from the top...
A shot of it put into the truck...
Here you see around the box it is going to be attached to the box surrounding the amps. I am going to have it covered and cut out a portion of it so you could see the AQ of all the amps.
looking good man. have you thought about plasti dipping the moulding on the side? the black rims look good. i need to do that for mine for winter since salt in michigan is rough
amp rack is sexy
looking good man. have you thought about plasti dipping the moulding on the side? the black rims look good. i need to do that for mine for winter since salt in michigan is rough amp rack is sexy
Thank you.... yes i did think about the plasti dip on the side and that will be something i am going to look at. I was also going to get a buddy to paint it matching the body but still undecided.
Alright so i decided it was time for me to get these to start playing... So i did just that got this thing playing, i know i still have a lot of work to get done. So on to the pics.
Since i was going to start getting the subs playing i went ahead and opened the other box today and that contained the DC XL. To my surprise i seen a lanyard in there with a sticker. Was pretty excited about that as i was going to be buying a lanyard.
Well i started to get all the wiring done for the subs.
Using these to wire the subs to the correct ohm i need. I had them just laying around so i decided to use them.
Got everything wired up, yes i know they need to get cleaned up. Also the subs in
Just a little disappointment. I had the holes cut out good but i still seemed to have some of the material lift up and peel away.
Got my second battery installed and my be getting another one
Got them charging before i check everything out.
So i will try to get vids up tomorrow. But first i must say this seems a lot louder than my previous setup. They are more vicious and do really get down. Although my overall satisfaction was down a little as i thought i would achieve a hair trick... No big deal there by any means as i do get some movement of hair and a good shirt trick. I am pretty sure it has a lot to do with the box and may play around with different tracks. Aside from hair tricks i am very happen with the setup.
Lookin good. All those amps are sexy in the back like that. Post some vids of the shirt trick :)
Lookin good. All those amps are sexy in the back like that. Post some vids of the shirt trick :)/>
Thank you.
