BigShug
Help with batteries
Picked up a Re XTX 5000.1 to run a 15" Z V.3. Right now i'm running a rockford t400-4 to 2 sets of t1675-s. I just put a new 170amp H.O alt and my lights are already dimming. With the new sub arriving friday i will be putting the Re in and don't think this batt will hold up. Any suggestions on a good batt that will keep this thing running smooth?
Kinetik 2400 but have u upgraded your wiring as in a big 3?
i've got 0 running from the alt to the stock batt now.
I would say a yellow top for up front and a 2400 or an xs and i would finish the big 3
why a yellow top?
why a yellow top?
just a suggestion or better yet he could do a khc 1200 up front
:WELCOME:
i personally would stay away from anything
Kinetik
You really need to upgrade the grounds as well.
I'm a big fan of the Diehard Platinum. For a little cheaper I'd go for a Deka Intimdator/rebadge.
Great, I'm looking for a strong under hood battery also! This post is right on time BigShug!! A great way to make an entrance!!! Welcome
could also save 15% at sonicelectronix right now with promo code install15
I would also say finish the big 3 first, with just power wire your bottlenecking.
batteries go with what you can afford.
Welcome aboard!!!! see how much drop you get and if voltage gets to low maybe add a xspower D1200 in the trunk. Good luck! trink40.gif
You can take lights such as led lights which consumes much less battery.
