krb1991
need help on picking an amp for two sundown e tens
Title says all. Will be running 1 ohm. Need amp around 150 that does rated. Thank you!
Any input on the mb quarts onyx 1000d?
Get it. Probably the best amp in your budget range.
Damn lmao must have posted at exact same time.. Rofl. Thank you. Anything else.
I'll second the onyx.
Alright guys. Thank you. Ive definitly heard good things about it. But havent heard of mb quarts really.
The onyx only has 1 70 amp fuse and isnt fan cooled.should i still give this amp a go. I want an amp to do rated and push the sundown e tens to limits. Will i get that with this amp?
I doubt you can do better within your budget for a new amp. There is no reason to "push them to the limit". Even if the amp only does 700 rms at 1 ohm you would not be any louder with 1000 rms. I have heard that the onyx amps are capable of doing rated power, but as I already said it won't make an audible difference.
A lot of amps are not fan cooled. That's what the heatsink is for. 14.4v X 70amps= 1008w. Yes stick with that amp.
I second that.
Have you bought subs yet?
No am goibg to order friday and amp
What is your total budget? Is this going in your Tacoma? What are your goals?
Really about a grand. Had already built box and yes in my single cab tacoma. Box is tuned to 32 htz. Planned on amping infin door speakers. My stock doors are 5x7 or 6x8. Going to deaden the the doors. Just trying to getas loud as i can bass wise o. Stock electric
That being said it sounds like you are on the right track. However I would recommend getting a 6.5 adapter so that you can run a decent component set.
If you're going to run a 1000 watt amp, you'll want to do "the big 3".
That is what id like the 6.5s tbh but the adapter? No experiance with that?price? Easy to install?
Lots of places sell adapters to mount a 61/2" woofer and 1" tweeter in a 6x9" opening. Check Crutchfield or Sonic Electronix. Probably less than $20.
If you can build an enclosure you can make adapters. Just cut an mdf ring to fit your door and use an adhesive to bond it. I used liquid nails with good results, I'll try to find a picture.
Alright thatd be nice thank you
Yeah ill def do the big three in 0 guage and run a good batt under hood.
These are the best pics that I could find. If you need more I can get some.
Alright that works plus my door panel over the speakers stick out a bit so it should be a go. Thank u everyone for your help.
No problem man! Good luck, and get some pics of the final setup if you can.
