Down South
Port calculation help
I'm looking into building an enclosure that measures 34W (left to right) x 18.5D (back to front) x 14.5 in height. The speaker is going to sit on top, port firing back. This is an L port design. The port will be 3 inches wide. My question is, if I want to tune at 33Hz how long would the other part of the port have to be (the one that runs across the back of the box)?
I used RE's calculator for my last box a few years ago and it couldn't catch the lows for nothing, so I know something is not accurate about that calculator.
If someone could help me with this, I'd appreciate it.
Thanks for all of the replies guys. Looking into them now.
Use this instead for now: http://stefanhinote.com/bitpusher.in/
When aero port is selected and you select that it's a flared port. The figure that it gives you for the length, is that from flare end to flare end, or is that just the tube length?
flare to flare.
flare to flare.
Thanks man, really appreciate it.
