Aaron Clinton
IS signal input ?
there was a mention of input sensativity issues on TP about the IS's, someone said anything more than 4 volts could cause problems?
is this true? :huh2:
  02BlackOnBlackSS said:
I have no problems with my 6.5v preouts.
:fing34:
You generally wouldnt have issue @ 6.5.
One, most deck dont do exactly what they say.
Two, your volume would have to be maxed to do its rated v if it did.
Three, unless it was a solid tone, it would only touch 6.5 infrequently, and therefore, would not be enough to cause issues. (theory)
TP'ers (DB Drag'ers) generally run solid tones. IE...solid 6.5+ depending on the LD or HU used.
I understand that, I like to run as much signal as possible,
but if I get one it will be for Amandas scooter and will be getting less signal
