swift
*Swift's Rebuild* 3 SP4 18's, 12k Walled F250
DCR reads .7 but the load on the amp is still 1 ohm
When I put a dmm on the terminals on the outside of my box it reads .5 ohm.
Ok regardless. When you wire 3 dual 1 subs they wire to .67 load. Now when I add a second amp I will wire them to what 12volt says will give me a 1.5 load making each amp see a .75 load. At .75 or .5 they will be drawing more than I have now and need more battery power.
I really like diehard plats. That's what I have for my main battery. Awesome warranty and sears is right down the road.
They have a friends and family night every month with special discounts on everything. November was yesterday haha.
153.0@37hz headrest in Meca yesterday. Did a 131.0 in Park & Pound DB4. That was on 300amp of fusing.
Two 1st place trophies, best truck and best install medals as well. I really want to pull a 55 at the headrest though.
Now its time to add more batteries, distro blocks, more 2/0, add the second 5500 and also incorporate this DD 2 channel amp I have to run just the tweeters while the 4 channel runs the mids. Also gonna be doing my doors and will probably be running all Rockford Pro Audio gear soon. Crescendo cant seem to keep anything in stock so I will probably switch tweeters too. Will more than likely have 3 6.5's in each door and one or two tweeters in each door. Whichever one disgust M5 the most is what I will probably go with. lmao
Man after seeing this build your making me jealous I sold you the 5500!
Good shit bro
Thanks for selling me a good amp. lol Cant wait to see how 2 act
Congrats on the score and trophies!
I don't know why M5 would be disgusted. He helped design the supertweeter. He wanted a tweeter that mated perfect to a 10" mid. I also believe his rule of thumb is 2 to 1 ratio. So if you plan on 2 mids per door that would equate to 4 supertweeters. You can do a 1 to 1 but that wouldnt be a true sq setup. That would be more of a ""SQL"". Which is a phrase he coined as well I believe.
maybe 5 3100's with a good batt under the hood
I have a 3100 under the hood and 3 in the back on one [email protected] and the voltage is pretty good
If I got a 2nd I'd want to add a couple more 3100's
Edited by Tim Harmening
Hey Swift, anything over a 130.0 in Park n Pound is great.
You makin me not wanna finish my build now... lol.
I got something that's in the way right now but as soon as i am able to finally cut it out completely, my build will be progressing.. how should i say it? Fast? Near completion type fast, :)
Picked up 4 of the Die Hard Platinum 31's today. Now have 8 batteries total. Should be enough I hope. Those batteries are kick ass!
Good scores bro! :)
It's a Mac sighting =-O
Got Power?
Thinking this will be the new amp placements
Decided to start getting everything out and get this going. I will be doing some very loud doors while its all out aswell. :)
Looks great swift!
Anxious to see the results.
Did you manage to fit all the batteries under the floor or are they going in the tool box?
The new amp is a C1100.4 to run the front doors. Gonna be doing a large very loud front stage. All Rockford Punch Pro Audio. All batteries are going in tool box. 4 Die Hards and 2 3400's in the tool box and the other 3400's under the hood. I hope thats enough battery power. I think I may order some Knu Krystal RCA's. Now I just have random shit in there, some are tsunami, rockford and maybe even a Memphis set. lol
That's awesome buddy!
I can't wait to hear what you think of the fosgate pros. no one in michigan has them. love the new equipment you're getting
Decided to just make my own bus bars. The trick will be making them for the Die hard batteries as I have .5in thick Aluminum and only .5in studs.
These are the copper bars I got in to use as my fuse blocks. They were suppose to be 2in wide but these are only 1.5in wide. I still think this will work. I have a 3rd bar that will be used for the ground block. 6 runs of power to the block from battery bank and 4 runs going to amps and 1 run to the 4 channel. Bad thing is I cant run dual inputs on the amps unless I double up lugs. These will be mounted on pass side when you open the rear doors for easy access.
The ground block will have 5 runs coming off the amps and 4 2/0 runs from there going to the frame where they meet the 4 ground runs off the battery bank. I hope this will be efficient. This will be mounted on the driver side when you open the rear door aswell.
That' should be beast then.
At Home Depot they sell the copper screw down terminals that you can use to terminate 2 1/0 wires in a single terminal. Not sure if they make it for 2/0 but that would work if you wanted to run dual inputs off a single terminal.
After hours and hours of labor I basically have the copper power fuse blocks, copper ground block, battery terminals, and XS bus bars done. I will have to run jumpers on the Die Hard batteries unless I buy wide copper buss bars but I dont think its needed. Jumpers will go parallel and will also have runs going straight to fuse block and ground block/frame from each battery too. After spending hours among hours doing all this shit myself its very rewarding when each step is done.
Pics
No I can finally start cutting on the truck and running all the 2/0 under truck and up into bed / tool box, through the floor into cab and get the blocks mounted, amps mounted. Then I can focus on the front stage.
damn son, do work
    1. Recent Topics
        • 7 comments
        • 266 views
        • 1 comment
        • 251 views
        • 1 comment
        • 100 views
        • 1 comment
        • 93 views
      1. Box for 1 15" SSA ICON
        • 3 comments
        • 947 views
        • 8 comments
        • 1,863 views
  • Similar Content
    • By Burke
      1. Product: 2 Fi SP4 18s with Carbon Fiber Dust Caps
      2. Specs: Both are dual 1 ohm (0.7 ohm)
      3. Description/Condition: Ran them for a little under a year on low power (Audioque 2200). Magnets have some scratches but the surrounds, baskets, spiders, and coils are in excellent condition. Does not include the original gaskets. A couple of the pictures are next to a 10" Kicker "Competition" (lol) for size comparison.
      I threw out the original boxes some time ago, but Fi was nice enough to send me two brand new boxes to ship them in. So these will ship in original Fi packaging.
      7/10 Cosmetically
      10/10 Mechanically
      4. Price: Asking $900 SHIPPED OBO for the pair. Because they are dual 1 ohm, I would like to keep them as a pair. NO TRADES, just trying to get rid of all my stuff.
      I'm located in Huntsville, AL 35810. Would be willing to drive to meet someone within reason.
      5. Pictures:
    • By cloud77
      12" Fi BTL UFO D2
      Item(s) for Sale:
      12" Fi BTL UFO Dual 2 ohm
      Item(s) Description/Condition:
      -pie slug style Fi UFO motor
      -12" 12 spoke aluminum frame painted hammered gray
      -PSI recone rated for 3k RMS
      -triple sewn leads
      -quad spiders
      -Longer coil to mimic Fi's HiXmax coil. Good for daily. Uses .25" spacers to accommodate coil length.
      -HD pulp cone
      -High roll surround
      This sub has been nothing but great to me. Can't say enough about it. Sadly I have just sold my amp and made a bunch of space in my trunk for a lot more business. ( (2) 12"s )
      This 12" can do it all..handled my MMATS m3000.1 with ease, hit the lows, and was great for a daily woofer.
      Has always been on a good supporting electrical cast. I am pulling the sub tomorrow because I'll be pulling my amp as well. Can take more pictures for people with more interest then.
      Recone has a date of 9/xx/14 and actually didn't use it for about 4 weeks it was installed because I had to wait on a warranty claim on a battery.
      There is a bit of a glue splotch on the top plate, but no biggie, just CA. bottom of motor looks mint.
      Minimal chips in ferrite. Included is the motor boot and 12" gasket.
      Price:
      275$ plus shipping
      Shipping and Miscellaneous Item Information:
      Ask me for a shipping quote
      Will be using UPS.
      US 48 only.
    • By antoinez28
      I have for sale two crescendo bc 2000 for sale both are about 1 1/2 years old good deal power by two g31 batt juciebox, and crescendo logic...pushing 2 18" ethos strapped at 2ohm never seen below 12volt...I had to push them....got warm in this hot Kansas City weather...both will come with bass noobs and one with owners books the other might be lost during a move with both boxes from crescendo...I love these things they both went to db-r for repair but nothing major I had a bad ground and thought I blew them both
      Crescendo BC2000D
      Stable down to .5ohm on strong electrical.
      Up to 16.8v capable on BC2000
      Remote Bass/Gain knob with Clipping Indicator.
      Custom tooled, proprietary Multi-piece Thermal optimized Heatsink with patent pending interlocking slide-out CNC engraved top plate.
      2 stage copper anodized removable top plate.
      Silver plated high end hard-wired Tiffany RCA inputs and oversized 1/0 Power/Ground Inputs for efficient current transfer.
      Overbuilt Power supply with heavy copper traces and Military spec PCB/heavy duty standoffs for extreme vibration resistance.
      Manufactured using some of the highest quality and most reliable electrical components, with many 3% tolerance components throughout.
      Full 4-Stage Intelligent protection Circuitry 1 Year/1ohm comprehensive warranty with 2 year/.5ohm optional extended warranty available.
      Rated Power Output(RMS)
      Clean RMS power on 13.8v standard electrical system:
      Ohm Load
      BC2000d
      1ohm
      2250
      2ohm
      1100
      4ohm
      700
      Dimensions: BC2000: 16"L x 2.75"H x 9.5"W (at widest point)
      I want 550.00 for the pair or 300.00 each shipped no lower
      I'm upgrading to a bigger amp dd-m4a
  • Recent YouTube Posts
