mrpowerpunchhx2
sa-8 v1 sa-8 v1.5????
so can i just change the frame on a sa-8 v1 to a as-8 v1.5 NOT sa-8V2??????
Huh? You can do whatever you want and name things whatever you want, but...
what???
what makes the # 2 so important to you ?
and if you need to know im sure it was because it was a very simple change... not worthy of a full model change
If you were take the time to look in the exact same sub-section (sundown) you will clearly see the first sticky about the different sa-8 versions and what you can and can't do between the different models. That's too easy I guess??????? What?
